6 disc cd changer for 2001 Outback
Legacy777 replied to park86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo is this the 6 disc changer that is separate from the head unit? I know the newer ones have the changer unit in the head unit. If it's a separate unit, I'd probably start by testing to see if it has power and all the stuff at the changer. However, without a wiring diagram, it might be a little difficult.
idle screws
Legacy777 replied to 90rulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull fuse 14 EGI/TCU for an hour. It's easier and doesn't screw with the radio settings. Some say you need to let the car warm up/idle for like 10-15 minutes or until warmed up. However I think you can probably do without. I didn't do it the last time I had my battery out.
1991 Legacy LS AWD Connecticut overheats
Legacy777 replied to fgug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd burp the cooling system. there is a little burp screw that needs to be opened on the top passenger side of the radiator. If you don't do this, you can get very weird issues. I'd start there, and see what happens.
Stuck Crankshaft Pulley
Again....don't do the starter thing. There is an access panel on the bell housing. You can stick a pry bar or something down there and catch one of the openings on the back of the flex plate, which will keep the engine from turning over. Here's a pic http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2486.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2487.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2488.JPG
Legacy777 replied to park86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the rest of the head unit work, radio, etc? Or is it dead too?
AT pan bolts -- size?please
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure of the bolt thread & pitch size, but I'm sure you could call your local dealership and they could help you out.
The first gen 2.2L engine....
Legacy777 replied to ndu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90-94 legacies, and I believe some earlier imprezas.
Looking for a new Sube; multiple questions
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think 99 was the last year for the 2.2 liter. The whole 2.5 headgasket thing is really a crap shoot. I've heard of some people having no problems, and others having tons..... I really haven't heard of too many issues with the 2001+ models. whether that's because they just don't have enough miles on them, or they fixed something. I don't know.
1991 Legacy runs jerky on highway
Legacy777 replied to zwempa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the check engine light coming on? You may want to try pulling the codes and see if any codes are stored. Instructions on how to pull the codes are on my site. Have you done a routine tune-up recently: wires, plugs, pcv valve, air filter, fuel filter, etc? You may want to try that if you don't find any codes.
Legacy headers-anyone heard of them
Legacy777 replied to sixiron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey look decent......they're probably just borla knock offs.
Head Unit Replacement - 99 Forester
Legacy777 replied to MEX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWiring diagrams can be d/l here http://techinfo.subaru.com but you have to pay. You may also want to check out www.scoobymods.com and http://forums.nasioc.com/forums
headlamps 95 impreza coupe
Legacy777 replied to twoff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat bulb type do you have? The 9004 bulbs have a color that you need to unscrew. The H4 bulbs, you remove the connector, and the protective rubber boot, and there's two metal clips....squeeze them together and move the clip out of the way, then remove the bulb.
Impreza fuel capacity?
Legacy777 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have an owner's manual? If so, it should state what the tank's capacity is.
98 Legacy AC Question
Legacy777 replied to quailman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat exactly do you mean by the low pressure valve? Do you mean the low pressure fitting?
94 Legacy Crank Sensor?
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpretty sure it will keep the car from starting if it's bad/dead.
EJ22 turbo swap with EJ20 turbo
Legacy777 replied to 93LegSportTurb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can't really do the swap and expect no issues. It would probably work, however there are going to be issues, one the injectors are different size, and that will play havoc with how the car runs, but you could probably swap the intake manifold over and keep the injectors, etc. Personally, I'd look into troubleshooting a little bit before you write off the motor.
4WD not working, '92 loyale
Goin to move this to the old gen side. You should get a little more response.
Susie K Decides to Sell car...Excellent 1999 Legacy Outback
Legacy777 replied to Susie K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSusie, You may want to post a separate thread in the marketplace if you plan on selling your legacy.
Stripping the 91 Legacy(under dash picture) for Ea82 swap
Gotta love wiring messes
general Interchangability?!... and o2 sensor conversion..
Legacy777 replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check the codes and see if there is anything pointing to the O2 sensor. Also, you may want to find a pinout for the O2 sensor system, and check that the wires do actually go to the ECU, and you should check that there is a pin out on the ECU for those leads that does something.
Engine Problems in 1991 Legacy 2.2L
Legacy777 replied to DeanB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst, replace the spark plugs & wires, air filter, fuel filter, & pcv valve. You're basic tune-up stuff. You may want to check the codes before, just to make sure. It's not the cat converters, it will typically get worse as the car is driven, and won't allow you to rev real high due to back pressure in the exhaust. I'd start with a tune-up and check the codes.
94 SVX - Airbag module
Legacy777 replied to snelljr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to try asking over on www.subaru-svx.net
Looking for a 91 Legacy diagram to help document wiring EJ to EA82 swap
welcome
This is for the 90 legacy, but should be the same as the 91 http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page3.jpg
Legacy777 replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell...if you wanted to put an O2 sensor in there, you'd need to make sure the ECU could handle it. I don't quite understand how it can be a fuel injected car and not have an O2 sensor. Are you sure it doesn't have an O2 sensor? There are some components that swap over from the imprezas, but unless you're trying to replace a broken part, I wouldn't bother swapping stuff over to give you any more power.
