93 Legacy Automatic Gerabox broblem
Legacy777 replied to Luis_H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can try adjusting it a little more I guess. But if you go too much in either way, it won't feel right. It's up to you, and how much you want to play with adjusting it. You don't need to worry about the internal metal screen. It's meant to stop the big particles/chunks. If you have big particles that are trapped by the screen, there's more then likely other issues. Either way, you can remove the screen and clean it with kerosene or mineral spirits
1st gear only when FWD fuse installed..WTF?
Pull the codes from the TCU and see what codes it's throwing. Instructions are on my site.
1990 Legacy fuel tank removal????
Legacy777 replied to JaySun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might want to try the marketplace or the parts shed on www.bbs.legacycentral.org I believe there are a couple people parting out first gen legacies.
repair shops in Houston
Legacy777 replied to treeman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only place I have had experience with, and continue to go back to for stuff I can't do is Autocheck on kirkwood & westheimer. I really don't go there for much, but friends of mine have been going there for a long time. When I had issues with my cooling system, Mike the asist manager let me borrow his pressure tester, and helped me out in a couple other situations. I'm not sure how mechanically inclined you are, or if you're even interested in getting your hands dirty, but depending on when you want to do this, I could probably give you a hand in changing the clutch. I'm around the galleria area.
AT/MT identifier, and gas guzzle?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup the connector in the engine compartment. It should be the same pins as my car. What I'd do is check the continuity between the pin on the engine connector and the neutral switch pin at the ECU just to verify the pin outs are the same.
Legacy rear brgs.
Legacy777 replied to svxcess's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if I'd say it's super common, but it's common enough where I have heard of other people needing to replace the bearings.
90 Legacy doors - interchangeable between wagon and sedan?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah they should be swappable. I don't see why the 92-94's wouldn't work either. Some of the trim/moulding may be slightly different, but that's it.
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you need to connect the neutral switch to the ECU. If you route the MT's neutral switch wiring through the existing AT's neutral switch wiring you'll be good. The only issue with this is, on the older cars you got backfeeding of power through the AT lights on the dash. The newer cars used a different setup, and this wasn't a problem. However, without an electrical diagram for your car, I couldn't really tell you. for sure. You could try just hooking it up like I mentioned. If the neutral indicator on your dash comes on, then you'll need to do some tweaking.
Comparison of awd technologies?
Legacy777 replied to occupado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's really only 3 different AWD types. The manual tranny's viscous coupling. The automatic's MPT technology, and also the newer VTD transmission found on most new automatic transmissions. To be quite honest, the automatic's AWD system is going to be superior. It's going to react quicker, and actually provide 45/55 torque split under normal driving, which is more a benefit. With the addition of the VDC system to the VTD automatics, you have one very advance and very capable AWD/traction control system.
Legacy777 replied to JaySun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can remove the fuel filler neck pipe without removing the tank. Just get a new filler neck pipe and put it back on. What happens is the plastic cover over the pipe collects dirt and crud, and can increase the chance of rusting.
Legacy777 replied to Luis_H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can change the transmission fluid your self. It's pretty straight forward. The dipstick for the AT fluid is on the driver's side of the transmission. There's another dipstick on the passenger side. That's the differential fluid. When you change the AT fluid you have to refill the fluid through the AT dipstick hole. There's no filter that needs to be changed. There is an adjustment for the brake band on the top of the transmission on the driver's side. It's a real pain to try and get at. You can see the bolt on the top of the transmission in this pic http://www.surrealmirage.com/subaru/images/swap/09/DCP_3217.JPG
Legacy777 replied to Luis_H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the brake band might need to be adjusted. Have you changed the fluid in it recently? Brake band adjustment procedure http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/transbrakebandadj.jpg
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou've got some wiring issues you need to take care of. I'm assuming you've read over my write-up. You need to wire everything similar to my setup. The neutral switch needs to be wired to the ECU's neutral pin, not the clutch switch. So the MT/AT ident pin did not have a wire hooked up to it? If it didn't and you grounded it, it "should" be setup properly. What year is your impreza again?
1990 Legacy Wagons speedometer dead but not other gauges
Welcome, Most of the stuff I respond to....I know about because I had it happen to me
It's the speedo cable base piece that goes into the transmission. All the first gen legacy speedo's are cable driven from the transmission into the gauge cluster. It is VERY VERY common for these to fail. The swivel piece inside sheers off, and the speed just doesn't work. When you take it out, make sure to get the rubber piece and the metal washer out of the hole. here's a pic & the part # of the piece in question. It's pretty cheap. http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to make sure that identifiy pin is properly snipped or grounded. That pin tells the ECU to adjust timing as well as fueling, and when to do it. Also, the neutral switch operation is backwards for the AT & MT setups. So if you leave it so the ECU thinks the car is AT, when it's MT. The ECU will think the car is in gear when it's actually in neutral, and vice versa. It should be pretty obvious to know whether the pin is wired properly. If it's still setup for AT, the rpms should raise up when you move the gear shifter in Neutral, but then drop back down when you put it in gear.
Speedometer Dead/AT Oil Light Flashing
Legacy777 replied to Dan Canning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can drive it like it is. I'd suggest verifying which speed sensor it is before you go ahead and replace it. Depending on when they switched speed sensor styles, you may or may not be able to access speed sensor 1 on the outside of the vehicle. Vehicle speed sensor 2 is the one that controls the speedometer, etc. So more then likely, that is the one that is bad, and you can get at that one from the outside of the vehicle. If you look at this scan, it'll tell you which pins on the AT connector are the vehicle speed sensors. Put an ohm meter on them to verify if one is way out of spec. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/3_Transmission_and_Differential_Section/3-2_Automatic_Transmission_and_Differential/MSA5TCD99L185.pdf This scan is for the 99 MY, but should be the same for the 97 MY......hopefully.
Legacy777 replied to Dan Canning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah a busted/malfunctioning speed sensor will cause all these problems. I'd check to see if the sensor is good or not.
Help! Air suspension problem - 1993/94 Legacy automatic station wagon
Legacy777 replied to 1993 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool, glad you got it working
Why replace an oil pump?
Legacy777 replied to shimonmor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's no reason to replace the pump, just the o-ring that goes between the pump and block. Also it's a good idea to check the screws that hold the backing plate onto the pump. pics can be seen from my t-belt change http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/
location of atmospheric pressure sensor?
Legacy777 replied to gsheng's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe normally aspirated legacies came with an atmospheric pressure sensor to compensate for altitude changes. The sensor is in the ECU, and can not be changed. Just curious, why do you want to modify this? The stock sensor won't output exactly at 760 mmHG, simply because of the reference voltage can vary. In Houston, which is essentially sea level, my barometric sensor reads 752 mmHG
AWD Transmission R&R How big of a pain?
It's not that bad. The MT tranny is pretty light compared to the AT. It'll help to have a second person there to tilt the engine back while you're under the car. This will help align the tranny & engine. I've got pics from my swap of various tranny and other parts if you want to take a gander. www.surrealmirage.com/subaru/swap
90-94 legacy turbo sedan w/5speed
Legacy777 replied to gbianchi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, they made the turbo legacy from 91-94. It was available in a 5spd all those years in sedan body. The 91 had a VLSD rear diff and a few other goodies the 92-94's did not. You can find out a lot more info about them on www.bbs.legacycentral.org
Ball Park cost for timing belt parts
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXultra gray rtv silicone stuff to reseal the oil pump. that sounds like everything.
what first?
check out my write-up on my AWD & 5spd swap. It's pretty invovled, however it can be done. Engine swap would "probably" be easier, but there's still items you need to take into consideration if you want to do it right. www.surrealmirage.com/subaru/swap
