Spark #1 and #2 NO spark #3 and #4
Legacy777 replied to jimshih's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....have you looked through all the engine and wiring diagrams in that manual.....just to make sure everything was wired properly?
90 Legacy - Check Engine Light
Legacy777 replied to AK Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the codes active codes? Like is the CEL blinking while you drive? Or do they just show up again when you check the black connectors? if the CEL isn't on, or blinking while driving, then these codes are probably stored codes, and not active. Try disconnecting the EGI/TCU fuse (which I think is fuse # 14 at the driver's kick panel) for 30 minutes. Drive the car around, and then check codes again.
Legacy777 replied to jimshih's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's controlled all in the ECU. If you replaced the ECU, it shouldn't be that......but something just isn't adding up....
Legacy777 replied to AK Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, clear the codes, and see what comes back.
Legacy777 replied to jimshih's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk....I guess let's recap some things here. It sounds like the ECU ground and power supplies are good. It also looks like the cam and crank sensors are working properly. I don't remember if you told me, but have you tested the ignitor signal directly at the ECU pins? They should be pins 9 & 10 of the F47 connector. You should see voltage varying while cranking. If you only get the one output working there....I'm really lost....
'96 Sub Legacy won't restart when parked on a tilt
Legacy777 replied to kayakerx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen it fails to start, does the engine turn over, or does it do nothing?
ej22 problem
Legacy777 replied to camosuba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpretty much, yeah....the car won't run without it.
Legacy777 replied to jimshih's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm.....I'll have to think about this....
ABS light comes on at highway speeds
Legacy777 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshould work....give it a try.
Legacy777 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat error message did you get or what exactly did it not do? I had someone else mention the links didn't work. They are working fine at my work. I've attached the file, so you should be able to get it. 2002_wrx_abs_diag.pdf
2.2 GX Legacy???
Legacy777 replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless they imported it, it's just the badge
Legacy777 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore then likely, the diagnostic procedure for your 98 is the same as the 02 WRX. You can check out this scan for how to pull the codes from the abs computer. http://www.main.experiencetherave.com:8080/subaru_manual_scans/2002_WRX_FSM/scans/2002_wrx_abs_diag.pdf
ej22 problem
Legacy777 replied to camosuba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCode 11 is the crank angle sensor Code 31 is the throttle sensor more info on all the rest of the codes can be found on my site. Have your friend reset the ECU, again the procedure can be found on my site, and see if the codes come back. If one or both come back, then I would investigate further.
Speedometer and Odometer dump + codes
Legacy777 replied to Brass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're very welcome! Glad it worked. Only other thing I might suggest doing is resetting the ECU. The learning maps can be more heavily altered by negative things, like sensor error codes and other stuff, so you may want to reset the ECU to clear those things from the learning maps. It's entirely up to you. If you do, pull fuse 14 EGI/TCU for 30 min. I'm pretty sure it's fuse 14, but just verify it says EGI/TCU.
Installing new stereo in '05 Subaru?!?
Legacy777 replied to mgiddings's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if they are integrated, however replacing just the radio would be kind of difficult since the trim and everything is all integrated. You might want to try asking your subaru dealership, to see if they know or will tell you.
Knocking Legacy Turbo
Legacy777 replied to dave.marchment's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDave I moved your first thread here, and replied to it. The knocking noise is the ac compressor. The ac system turns on when the defrost mode is selected to remove excess moisture from the air. You can try shooting some more refrigerant/oil in there to see if it quiets down. If not, you'll need a new compressor. You can probably just keep running it.....I ran mine that way for a while.
Binding, AT Oil flash, Solenoid...AGH!
Legacy777 replied to BlueSubes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStick a fuse in the FWD fuse holder. If the binding goes away, I'd say the duty c solenoid is still good, and it's probably the clutch pack. If the binding does not go away with the fuse in there, the duty c solenoid is probably bad. If the fuse method cures the binding, I'd suggest changing the transmission fluid. If it's real bad looking, drive it for a while, and change it again to get the nasty stuff out. Also there is an additive you can add that has helped others. I don't remember the specifics however on the additive.
Legacy777 replied to Brass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi replied to your pm, but so everyone has the benefit of following the problem and hopefully resolution, here's my reply The speed sensor is tied into the speedometer. The odometer and speedometer are all driven by the same cable. So yes, it doesn't surprise me at all. The cam or crank code that was there may be a fluke. I'd fix the speedo issue, drive the car, and then check the codes to see if it comes back. The no speedo issure will also mess with how the transmission shifts. The TC will not lockup and the radiator fans will be on constantly. Follow the cable down to the transmission to find that base piece. Take the cable out of the piece, stick it in a drill and see if you can make the speedo move. If you can, the cable is good, and more then likely it's the base piece. Once you take it off, you should be able to tell right away if it's bad or not.
Replace Fuel Tank 93 Impreza L AWD?
Legacy777 replied to DMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup.... there are three screws holding in at the top and a screw clamp at the bottom rubber hose.
Legacy777 replied to Brass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have an auto tranny? If so, the base cable piece probably broke. It's relatively common. I replaced mine a while ago. It's not hard, and the piece isn't expensive. You need to make sure to get the old washer and rubber piece out when you replace the piece. here's a pic http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg
Legacy777 replied to DMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore then likely the filler neck is rusted out, rather then the whole fuel tank. I have a buddy who had this problem in his 95 legacy. There is a plastic cover over the filler neck tube. Remove that and you'll be able to see more clearly at the filler neck. If the tank does need to be replaced, you'll have to drop the driveline, and maybe the rear subframe, depending or not if you can get access to the bolts that hold the gas tank straps on. I've got a few pictures of the gas tank out and some other misc pictures from my awd & 5mt swap that might help www.surrealmirage.com/subaru/swap
Legacy auto trans issue-Help!
Legacy777 replied to boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like something's gummed up in there. I had this occasionally when I was AT. How old is the fluid in the tranny? You might want to try running some transmission specific seafoam through the auto tranny and see if that helps.
1990 legacy audio wire color chart
Legacy777 replied to legacy1901's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis should help get you started http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Legacyradiodiag.jpg
'92 Legacy missing...
Legacy777 replied to daveM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah.....clear codes and then see what comes back
Subaru Manuals, Service Bulletins, and more
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've added some more goodies. All can be found here http://www.main.experiencetherave.com/subaru_manual_scans/ Again, Please right click and save the pdf's. Thanks 1980_Subaru_Manuals 1990_Legacy_FSM_Supplement 1990_Legacy_Owner_Manual_Scans 1990-1994_Legacy_Parts_Manual_-_Engine 1992_FSM_(Engine_&_Electrical) 1992_Subaru_Service_Bulletins 1999_Legacy_FSM 2000+_Legacy_FSM 2002_WRX_FSM 2004_Impreza_WRX_STi_Factory_Service_Manual Chiltons FSM_Scans Subaru_Service_Bulletins Technicians_Reference_Booklets
