boo-boo, need advice
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust an fyi on the wiring harness thing. The 90-91 engines had a three plug electrical harness, while the 92-94's only had a two plug harness. This was the problem you ran into correct? As for which injector is which. I can take a look at the factory manuals when I get home, or you can look through the one I posted in your other thread.....or was that someone else's thread. Here's pics from my injector swap. Maybe you can find a clue about which connector goes where from them. http://www.main.experiencetherave.com:8080/subaru/images/injectors
an idea on aftermarket twin turboing
Legacy777 replied to JonOfScio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwapping the manifold around has been done. It's usually to reduce the amount of intercooler piping if you're running a large front mount. Still not sure how much more room you're going to get by doing for a twin setup.
Where to purchase OEM rotors?
Legacy777 replied to kjadams2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.subaruparts.com www.1stsubaru.com
shuddering when pulling out
Legacy777 replied to mark786's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtire circumfirence is what you're looking for.
Big F up need help asap
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust be careful pulling that seal out. The way I usually get seals out is jab a small screwdriver in the sealing surface of the seal at a 90 degree of the shaft. However with that in so deep, I'm not sure it would work. If you had one of those pick things, you might be able to snag the seal enough to pull it out some. This is only the engine & engine electrical sections of the fsm, but probably a lot better then what you have. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ There's various other misc scans here http://www.main.experiencetherave.com:8080/subaru_manual_scans
93 AWD 1.8 Impreza Brakes barley work FIXED!! See last post
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got ya now. According to the fsm, it is a dual circuit design, and it looks to have two independent pistons that are separated by a spring. There is also a spring in front of the first piston.
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I'd recommend pulling it out, and yeah it's just supposed to be flush with the rear of the crank. Like this http://www.surrealmirage.com/subaru/images/swap/11/DCP_3275.JPG http://www.surrealmirage.com/subaru/images/swap/11/DCP_3274.JPG
My feedback on driving a 2005 Legacy GT sedan.
Legacy777 replied to cruzan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah....$4800 markup is crazy. I'd look into buying one in another state or the other side of the mtns. If you find a good dealership, you'd be surprised how accomodating they will be to work with you, since you are going out your way to come to them.
Legacy777 replied to cruzan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's BS.....so what are they selling for?
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you elaborate on what you mean by the "piston can move full forward.." I've swapped around MC's and tried to bench bleed...it was for the most part unsuccessful IMO, yet successful in making a mess....I said screw it and just put everything together and bled it on the car. I don't notice any adverse affects from doing this.....?
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeith, The proper bleeding sequence according to the FSM is Right Front Left Rear Left Front Right Rear. Subaru does it backwards for some reason. I've bled both ways, and for some stubborn air, the sequence in the FSM was the way I got it out.
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow did you bleed the brakes? order, method, etc? How did the pedal feel before you bled the brakes? I don't think thin rotors would cause what you're experiencing. I'm not sure what the run out spec is for that car. You may want to call the dealer and see if they'll tell you.
My poor Impreza
Legacy777 replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStarter solenoid contacts. here's tiny clark's document http://www.main.experiencetherave.com:8080/subaru/techinfo/starter.doc here's some additional pics (starter solenoid pics towards the bottom) http://www.surrealmirage.com/subaru/images/swap/13/default.htm http://www.main.experiencetherave.com:8080/subaru/images/startersolenoid1.jpg http://www.main.experiencetherave.com:8080/subaru/images/startersolenoid2.jpg http://www.main.experiencetherave.com:8080/subaru/images/startersolenoid3.jpg
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou sure you got all the air out of the lines? Does the pedal feel soft initially? If so, does pumping it again firm it up?
Engine Miss?
Legacy777 replied to OhChit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk.....let's get a little background on your custom application, and what you have modified and how. Without that....we're just guessing. That aside, you can check the codes. The pins for the diagnostic connectors are still there on the ECU, and you can hook up a little 12v light to the output of the CEL circuit. have you had the battery & alternator tested? Have you checked for a short? That almost sounds like what's goin on with your latest issue.
Speed Dips with Cruise On
Legacy777 replied to 04Subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's normal. my 90 does the same thing. Just how the cruise logic is setup.
90 Legacy tire ?
Legacy777 replied to roque43's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not ok to run mismatched tires....especially mismatched sizes. You'll cause quite a bit of havoc and eventually damage with the awd
More Transmission Swap Info
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can tell by looking at how the clutch fork mounts. If it's on a pivot ball, it's a push type tranny. If the clutch fork goes through a cylindrical rod, it's a pull type. Look at some of the pics on my swap site. I have a pull type
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, by the way, if you do end up needing a 3.900 rear diff, I know someone in california that has one.
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do you mean?
92Legacy LS/FWD - engine sputter/misgfire when light load/cold or wet
Legacy777 replied to jvasquez8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a simple sensor connected to the coolant runner under the intake manifold. All you have to do is unscrew it. here's a pic. It's the brown one http://www.main.experiencetherave.com:8080/subaru/images/injectrs/DCP_2477.JPG here's a better pic to orient yourself where the sensor is, in relation to the engine http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2476.JPG
Legacy777 replied to mark786's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs cookie mentioned, check your tires. Subaru says that the circumfirence needs to be within 1/4" between all tires. If your tires are ok, then first thing I'd suggest is changing the transmission fluid. Old fluid can sometimes cause contamination or issues with the rear clutch pack. If that doesn't help, you'll most likely need to have the rear clutch pack worked on / rebuilt. The automatic's AWD system is controlled by the trans computer. It has a rear housing with clutch packs in there. A duty solenoid controls line pressure to the clutch packs, which in turn varies how much power goes to the rear wheels. When you put the fuse in, it sends a constant 12v source to that solenoid which pretty much closes it, and sends very little to no power to the rear wheels. It's not a good idea to run too long with the fuse in, because the solenoid is designed to get a pulsed signal from the TCU, rather then a constant signal. So you could prematurely wear out the duty c solenoid. here's scans from the factory manuals of the auto's awd system http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs thawa mentioned above, the wrx uses a 1.1:1 stepper. So if the tranny is 3.900 and not a WRX, then you can not use the WRX rear diff, because it is 3.545. You'll need to find one out of a car with 3.900 final drive ratio and a 1:1 front/rear center gear ratio.
Where is Cruise Controller?
Legacy777 replied to hklaine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo the right of the glove box, assuming it's the same as the first gen legacies. http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location05.jpg
Does the automatic start in 2nd ?
Legacy777 replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, your torque converter locks up. I'm pretty sure it only happens in fourth gear though. The TCU will adjust the amount of lockup via a control solenoid.
