Front Left Side Header pipe crack
Legacy777 replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know how common you problem is....but I would say from an engineering point of view that the point where the pipes come together will have more thermal stresses, and probably over time the weld failed.
2008 Legacy Integrated Key's
Legacy777 replied to beautofawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably not....I'd try asking the subaru dealership.
05 Legacy Stereo Pre-Amp
Legacy777 replied to pldawg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope. what are you looking to do?
need sube mechanic b'ham alabama
Legacy777 replied to cvincent's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to post in the meet & greet forum.....and/or post on the regional forums on NASIOC http://forums.nasioc.com/forums
99 OBS advice
Legacy777 replied to Arethusa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a little high IMO, unless it's in immaculate shape.
Same shocks/struts on 98 Impreza RS as 98 Impreza OSB?
Legacy777 replied to Infidel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you should be able to use RS struts. It may lower your ride height some, but that's it.
Crank gear sprocket presses on radius?
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo answer your question, yes the crank gear is held in place against the crank lip by the crank pulley & main bolt
cone filter or air box?
The MAF is a separate unit, and shouldn't be modified...... Personally, I'd go with the airbox. The cone filters can cause issues with sucking hot/turbulent air, and the MAF sensor not reading the air flow correctly.
4EAT slow to engage
Legacy777 replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's an anti-drain back valve in the line that supplies ATF to the torque converter. Over time this valve fails, so it takes a little bit to fill the torque converter back up. I do not know if this valve/line is internal or external, but I experienced this with my 90 legacy when it was AT, and had an trans tech mention the valve.
00 Cruise parts work on a 98?
Legacy777 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey should.... I have found though that there are some differences. I got a cruise setup from lmdew from a 94 or 95 impreza to put on my 97. The throttle cable length coming from the actuator is shorter then what's on my 97. I don't know why that would be the case, but it is. I'll either have to get a different cable, or try fabbing up a bracket to move the cable mount closer.
oil catch can
Legacy777 replied to Steve455's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, they're more beneficial on turbo cars, but even on turbo cars, unless you run them hard, or on the track.....I can't say they'll improve anything.
hydraulic clutch piston vibrating on clutch fork
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGary, You have the push style clutch, which is a little different from my setup, but I believe it still should have the spring. Anybody have a picture they could post up or take? I'll host the picture if need be.
99 Outback headlight adjustment screws
Legacy777 replied to pulloff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're probably not going to find any screws specifically for the headlight. You may be able to find some generic ones that work at your local autoparts stor or hardware store. Your other option is to see if a member has one, or get a broken headlight from a junkyard for cheap.
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGary, What year Legacy do you have?
engine error codes - Veh Speed
Legacy777 replied to mrfeh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease try and keep all related items in one thread. It makes it easier to follow and doesn't clutter the board. I'm going to close this thread so everything is kept in your original thread.
My iPod FM transmitter stinks!
Legacy777 replied to TarHeel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure.....try posting in the thread and see if you get any feedback. I think there's also a forester board around....you may want to ask on there.
Legacy777 replied to TarHeel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out this thread http://legacygt.com/forums/showthread.php?t=18504 I recently installed an XM radio into my GF's Outback using the aux kit, and works great. Here's some pics http://www.main.experiencetherave.com:8080/subaru/images/outbackxm/
Supercharger idea. Need help with parts
Legacy777 replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe may be under the username reddevil
Legacy777 replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would suggest talking with douglas vincent. He's one of the few people out there that have successfully run a custom supercharger setup.
Rain guard/vent visor/deflectors?
Legacy777 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru used to sell them, however I don't think they do any more. I think I have haerd someone looking at some of the dealers overseas that still had stock....but I don't know if that is really an option.
Window control not working!!!
Legacy777 replied to wrcRabbit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like an odd problem. The switch may need to be replaced. You may also want to try posting on http://forums.nasioc.com/forums and see if anyone else has experienced this problem.
Help me understand my AWD
Legacy777 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your 98 AT or MT?
'05 OBW Stiffer Gas Pedal Spring? Warrenty Fix, Cruise Control Humping On Downgrades?
Legacy777 replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy suggestion would be to pull the accelerator pedal assembly out, find out where the spring is, and see if there's any way to install another one, or replace the stock one with a heavier duty spring. Either way, it's going to be a custom job.
Using 100W H4 lamps in 91 Legacy
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll probably be fine. An upgraded wiring harness & connectors with relays isn't a bad idea, but you'd probably be ok.
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be a spring that holds the clutch fork against the piston. Also, you can put a little bit of grease in the indent where the piston goes. That will help quiet the noise.
