how does TCU determine AWD or FWD?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked the TCU for codes? Usually if the trans light blinks, that means there's a code stored.
Replacing 03 Legacy Fog Lamps
Legacy777 replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to replace them yourself.
Need Fast Clutch help
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's your transmission type? Pull or push?
Rear EJ knuckle/hub assemblies interchange?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossibly, but there may be superceeded parts on the newer hub.
What is the failure mode of the PURGE SOLENOID VALVE
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe air bypass valve is again something different. It's also known as the idle air control valve. Here's a picture of the IAC valve http://www.main.experiencetherave.com/subaru/images/injectors/DCP_2470.JPG Picture of the canister purge solenoid valve http://www.main.experiencetherave.com/subaru/images/injectors/DCP_2471.JPG The pressure exchange solenoid can be seen near the top left of the picture. It has the brown connector facing up http://www.main.experiencetherave.com/subaru/images/ej22t/32/DCP_6012.JPG
It's all about timing
Legacy777 replied to bratsrus1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow did you set the timing up? All you need to do is align the marks on the cam pullies to the marks on the timing belt cover, same goes for the crank gear mark. Did you use the arrow on the front of the crank gear instead of the mark in the back?
Aftermarket Car Alarm Install Documentation?
Legacy777 replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTim, I'm not sure you're going to find a write-up with the info you want. I'd suggest following the instructions that came with the alarm, and/or talking with a local alarm install shop for recommendations/help.
A/C Not Workin'
Legacy777 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you should be able to find uv dye for the ac system in a can.
1990 legacy modification questions
I'd recommend you look over my swap write-up www.surrealmirage.com/subaru/swap Parts from any of the 90-94 legacies and even some newer subarus can be used. The 4WD route would be more difficult as the engine/transmission mating points are different. If you search, you'll probably be able to find some more details on that. Josh
A/C Not Workin'
Legacy777 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you do open the system up, a strong vacuum (around -29 in/hg I believe) needs to be drawn for at least 30 minutes to boil off any moisture in the system. If you don't have to open the system up, I'd also recommend adding some PAG oil to the system, as the oil may have leaked out over time, and if the system is low on oil, it could cause premature failue of the compressor.
A/C Not Workin'
Legacy777 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, you shouldn't discharge 134a into the atmosphere either. It's a greenhouse gas and is toxic.....but anyway...here's some info http://www.eng-tips.com/viewthread.cfm?qid=156670&page=1
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably not. What context was Haynes using the term bypass valve?
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually what he described is for the canister purge solenoid. The pressure exchange solenoid is used to switch between taking readings from the atmosphere, and intake manifold vacuum readings. This is done to compensate for barometric pressure changes due to weather and elevation.
Air suspension swap - front only???
Legacy777 replied to subyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't recommend swapping just the front. It might be a little difficult, plus could produce unexpected handling characteristics. If you want to try it, you'd have to cap off the air lines in the front. I'm not sure how the computer would handle not seeing the front struts....it may not like that.
Hot/Cold Resistance of ECU Coolant Temp Sensor?
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper, Did you measure those values or get them from a manual?
Question about Mass Air Flow sensor
Legacy777 replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy legacy had similar problems which yes were caused by that MAF, so it looks like your MAF is needing to be replaced.
New Outback springs
Legacy777 replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEmail Rallitek & see.
why aren't 1995 ECU's different AT to MT?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ECU has an AT/MT identifier pin. Depending on how that pin is setup, will tell the ECU whether it's connected to an AT or MT equipped vehicle. So it should know whether or not the vehicle you plugged the ECU into has EGR or not.
Subaru Newsletter - March 08
Legacy777 replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo worky.....here's the link on the diesel. The legacy looks pretty nice! http://www.caranddriver.com/reviews/hot_lists/car_shopping/green_machines/2008_subaru_legacy_outback_2_0d_first_drive_review.html
New noise - maybe from the transmission?
Legacy777 replied to meddler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. It could be a couple things, but I'd suspect it may be the throw out bearing on the clutch could be making the noise. That'd be the cheapest and probably first thing I'd replace if I was going to replace something. Josh
bad plastic headlights! down!
Legacy777 replied to isleymerl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah...you need to put a protective coating over the headlight lense. That keeps the air out, and lense from oxidizing.
EJ18 exhaust redcommendations for best gas mileage?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stock EJ22 exhaust is probably pretty decent in terms of flow for the EJ18 engine. I don't really see you getting a huge gain in gas mileage by doing anything to the exhaust. If you want to try something, I'd start with the muffler since it's the cheapest. Anything else IMO the benefit doesn't outweigh the cost....if you're just looking for gas savings.
07 Stereo
Legacy777 replied to jurgyman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump I'm pretty sure they don't have line outs for amps/subs.
'03 outback catalytic converter
Legacy777 replied to spearman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have any kind of annual inspection, that won't fly.
Legacy777 replied to spearman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can't really do that with OBD2 cars as you'll get a CEL for cat inefficiency.
