Legacy777
Moderator
  1. You should be able to keep the hyd. clutch setup. To my knowledge the pivot ball is just moved to the other "boss" (you may have to tap it) and you can swap over the hyd clutch fork & slave cylinder.
  2. The idle switch is in the TPS. The only adjust that needs and should be done to the TPS is to adjust the idle switch. Follow these instructions to adjust the idle switch. http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/TPS_testing3.jpg
  3. The pumps tend to last for quite a while. I hear of a very few amount of the first gen legacies on the boards that have their pump go out, and the 1990 MY is coming up on 20 years. It probably couldn't hurt to replace the pump, but it certainly wouldn't be high on my list of parts to replace.
  4. I don't know if the forestor uses the same cruise diaphragm setup, but if you could snap some pictures, that'd help. Thanks! Josh
  5. It's a 5spd. I'm not sure that the trans type matters. I think the fact it is a 2.2 vs. 1.8 is where the difference is. I think after a certain point, subaru made cruise an option and sold it as a kit. That kit is no longer available, or I would have just got the kit.
  6. He was trying to get the cable out to get the heater control unit out. It's definitely the control unit. The solder joints are a common failure point. Stan, I'll see if I can find any info in the manuals regarding getting that heater control unit out. From what I remember, the cable shouldn't be limiting you getting it out. Did you take the stereo out? There may be screws just above it. I don't recall exactly. Josh
  7. My impreza is a 1997 outback sport. Your cable length appears to be the same as mine, which kind of confirms my thoughts it was pulled from a 93 MY. Is your impreza a 1.8 liter or 2.2 liter? Would you mind taking some pictures of the throttle body area, and throttle cable mounting to the intake manifold? Thanks Josh
  8. I've been trying to get cruise installed on my Impreza for a while now. I bought the parts from another impreza to install. When I went to do the install I found the cruise throttle cable is too short. The donor car was a 93 Impreza I believe. I know for my MY Impreza they had a cruise add-on kit with everything you need. So I don't know if something changed between then...but the cable is about an inch too short. What I'm looking for is some other Impreza owners that wouldn't mind measuring the cable from the mount point to where the cable end point is on the throttle cam. Mine was about 6", and I'm pretty sure I need around 7" to make everything fit. Here's some pictures I took that may help explain. http://www.main.experiencetherave.com/subaru/images/imprezatb/ Any help is greatly appreciated. Thanks Josh
  9. There is no fuse, just a relay for the fuel pump. There is also a connector under the rear seat that you can disconnect to remove power from the fuel pump.
  10. Does anything else not work? Chances are there are other components on that fuse. The fuse is probably in the cabin, but I can't say for sure. If you get a test light or volt meter you can test each fuse to make sure you have voltage on both sides of the fuse. Josh
  11. That's most likely the torque converter unlocking or locking.
  12. Yeah, means the torque split will probably be more towards 50/50 then it would if the manual button wasn't depressed.
  13. All the manual button does is keep the transmission from shifting into 1st gear when the gear selector lever is in the 3 or 2 position. When the gear selector is in D or the 1 position, the manual button doesn't do anything. Here's another post from the sticky http://www.ultimatesubaru.org/forum/showthread.php?p=410273#post410273
  14. The TCU will not let the torque converter lockup, and possibly not into 4th on the newer models if it's not receiving a speed sensor input. Fix your speed sensor issue, and you should be good.
  15. Looks like a cool place to go drive. I like the first gen Legacy with the wheel in the air
  16. Use the stock n/a one. I've been using it since I did my swap. If you have both radiators, I'd be interested in side-by-side pictures and dimensions. If you use the stock n/a radiator you need to tie the fitting near the radiator neck to the turbo coolant resevoir tank. You tie it to the port that was meant for the line that comes off the passenger side of the turbo radiator. You also need to remove the lower rubber gasket on the radiator cap so that coolant can flow to the turbo coolant resevoir tank. I know that sounds kind of complicated, but if you search the BBS it was discussed when a few times, including by myself. Josh
  17. You don't need the complete harness. You just need to run the pins for the boost related sensors back to the ECU connector. Besides that, you need to swap the positive leads for the crank & cam sensors, and move the coolant temp sensor wiring down slightly on the engine harness. Much easier then swapping a complete harness. Also, the turbo legacy radiator won't fit in the non-turbo cars. It's taller.
  18. I'll put in a good word for the Jazzy kit. I put one in on my ex gf's 06 outback so she could have XM. Here's some pics from the install. http://www.main.experiencetherave.com/subaru/images/outbackxm/
  19. I'd have to find the info....but there is a place in the Seattle area that makes a reduction type gear thing that fits into the cable to correct the speedometer reading. I looked into a little while back, but never followed through.
  20. Glad to hear you're giving the Legacy some attention now Mines been getting more attention after sitting for a while.
  21. Hi Bob, The problem is intermittent, and sounds like a short or possibly a pinched wire. What I'd probably try and do is trace all the wiring back from the TCU to the transmission connector and verify continuity, and then check the transmission wiring/components to see if their resistance measures up with what they should be. While you're checking wire resistance, I'd suggest pulling/moving the wiring harness around to see if that gives you an intermittent loss of continuity.
  22. That area under the wipers is where the windshield drains, so chances are you'll get more water there then you will in the stock location
  23. Yeah I just checked at the 92-94 MT non-turbo legacies appear to have the same gear ratios. The turbo legacies have the same gearing, but different final drive ratio.
  24. The 92-94 had some changes in gearing, but I believe that was in the automatics. I'd have to double check in regards to the MT's.
