easiest/best hose to use for intake vacuum level
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe manuals state vacuum at idle without ac should be 19.96 in HG or something like that. And yeah, you shouldn't have any fluctuations in vacuum if you're using a good vacuum source. The brake booster is alright, and that other spot you mentioned yarikoptic sounds like it's vacuum, so you could tee into that.
Doing EJ axles.....
Legacy777 replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLoosen the bolt holding the anti-sway bar onto the Lateral link (a-arm). Also, loosen the front bolt holding the lateral link to the front crossmember. This should give you enough room/play to remove the axle. Others remove the ball joint or struts to get the clearance needed to remove the axle, but the above method allows you to do the axle without needing an alignment or chance messing up the ball joint boot.
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure if on the 95 MY's....but there may be a vacuum hose point on the top part of the passenger side of the intake manifold.
'05 OBW Stiffer Gas Pedal Spring? Warrenty Fix, Cruise Control Humping On Downgrades?
Legacy777 replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou shouldn't be "resting" your foot on the accelerator. Use the cruise control. When do you experience/most notice the fact you are accelerating?
Disabling Automatic Door Locks - '03 OBW
Legacy777 replied to freebeing's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome. This may help http://www.randomsoup.com/subie/huggyalarm.html
Tire question
Legacy777 replied to ctoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may also need new struts. The wavey or intermitant spots wearing on the tires can be a sign of work struts.
Independent shop, Albany/Troy, NY area
Legacy777 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMay want to try the meet & greet forum if you don't get any replies here.
Cost on motors
Legacy777 replied to faithless88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt really depends on where you get it, and what vintage you're looking at.
2 plugs vs. 3 plugs
You don't need to do anything with the timing gears
Tire question
Legacy777 replied to ctoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe offset isn't going to cause that. The +48mm offset will move the wheel further outward, which is better for keeping things from rubbing on the inside compared to the +53mm offset wheels. Your issue is with the alignment. Did they give you a sheet that said what the final alignment specs were? Did you hit any big bumps/curbs or anything like that since the alignment? Are all the tires like this?
coolant hose diagrams
Legacy777 replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to call your local subaru dealership or one of the online subaru dealerships. They can probably help.
code 45 and no boost :( (kinda long, need help)
Legacy777 replied to bmxkelowna's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you get this figured out?
Palm Pilot / PDA Based OBDII Scan tools?
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Another what is this a picture of?
Legacy777 replied to mattgold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably the canister purge solenoid. It looks like they relocated it from the older legacies/imprezas.
Mixing engine parts EJ22 and EJ25
Legacy777 replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't say for sure off the top of my head....I'm pretty they'd be swapable. Matt Monson, who is a member on nasioc and the legacycentral bbs would probably know for sure. I would suggest trying to post on the legacycentral bbs or PM him.
Back seat window off track
Legacy777 replied to ScoobyDooOK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to search/post on www.legacygt.com/forums as the posters there are mostly new gen legacy owners.
What would be the ideal hybrid 2.5/2.2 build??
Legacy777 replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me ask you this.....what power levels do you want to make. If you plan to stay n/a, don't expect anything more (probably less) then 200 chp at the VERY MOST from a superb/excellent setup.
Aska interchangability
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot a picture of one......never seen one to my knowledge.
98 Impreza Hatch Rattle
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 OBS is doing the same thing....I adjusted it a little bit....but sounds like I need to do something similar.
Help w/ underseat CD changer
Legacy777 replied to tiredandwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Legacy knock sensor installation?
Legacy777 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Haynes manual is wrong. All you need is a long socket extension. Shouldn't take you more then 30 minutes at most.
1st gen Legacy, Different Injectors from Auto to Manual?
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn 92 all the n/a MT legacies went to the JECS control system as well. There are injector differences between the AT & MT 90-91 MY's, as well as the 92-94 MY's.
Safe Rev Range
Legacy777 replied to deks69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRedline is where it's at for a reason.....lugging the engines, and not revving them can sometimes be worse, because more sludge and junk tends to build up, and not be blown out by higher revs.
No VSS - how do I fool ECU?
Legacy777 replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe gear is probably fine. The problem is probably this base piece. It's fairly common for the shaft to break. http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg
Legacy777 replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your 92 AT or MT?
