Cooling fans not turning on- 1990 legacy
Legacy777 replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe there is also a sub fan relay. It's weird, some legacies have it wired up where both fans come on when the ECU tells it to, and others, only the man fan comes on when the ECU tells it to. However in that case, the sub fan comes on when the AC kicks in. The coolant temp sensor is very weird....it can be bad, and not work right, and not get a code. I think when they fail their resistance stays within the "normal" range, and the ECU doesn't have the advance programming the OBD2 ECU's have where it times the coolant temp sensor, and if it doesn't change/warm up in a certain amount of time, it'll give a code.
Fuel sending unit compatibility
Legacy777 replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFWD & AWD sending unit assemblies are different, and can not be interchanged.
OEM Naviagtion lockout hack?
Legacy777 replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure it puts the nav into lockout when the car receives a speed signal. Removing the signal won't work since the nav needs it. Short of a programming change, I don't think you'll be able to get around it.
99 Legacy with whine when rolling
Legacy777 replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich does it change with....engine speed or vehicle speed? If vehicle speed, I'd probably lean towards wheel bearing. I'd suggest jacking the car up and try wiggling the wheel and other components to see if they feel loose.
missfire codes on all 4
Legacy777 replied to Steve455's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, it'd probably be best to start with the plugs as they are a relatively inexpensive fix.
Airbag light in 1998 Forester
Legacy777 replied to JSX-974's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend going to the dealer and have them see if there are any codes stored in the airbag computer.
Legacy777 replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the whine change pitch with engine speed or vehicle speed?
SS 4EAT doin' the two step
Legacy777 replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe valve body type should be similar, and as long as it was rebuilt correctly, that shouldn't be an issue. It's possible the TCU may be acting up. If you get the part # off of it, I can check it to see what application it's for. You could try posting on the legacycentral bbs to see if other SS 4EAT owners exhibit similar issues.
Legacy777 replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis may help http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/coolingfanwiringdiag.jpg
a/t temp light blinks 16 times
Legacy777 replied to litender's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX16 blinks means absolutely nothing. It's just a standard sequence that lets you know there is a code in the transmission computer. I guess what you need to find out is if the tranny guy actually got a code 15 or if he miscounted. On the older transmissions, code 15 indicated shift solenoid 1. However I couldn't tell you whether that code is still the same.....I sort of doubt it. If you can't get any answers...take it to a subaru dealership, and have them check the TCU for codes.
Cruise Control from '95 into '91
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat I couldn't say. The cruise control module for the 91 is on the right side of the glove box....(for a left hand drive car) Do you currently have cruise now? Is something wrong with yours, is that why you want to swap it out?
TD05 turbo upgrade Q's
Legacy777 replied to 4WDFrenzy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust swapping the turbo probably won't require you to do anything, however if you start upping the boost, which is usually what most people do when they put a bigger/better turbo on, then you will probably need to look at larger injectors. Are you just running stock boost levels? What boost levels do you plan to run with the TD05?
AC belt smoked off
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, the compressor is probably toast. I've had several go, and one seize up on me.
OK EJ22 folks...Non-interference '93 and 95 legacys- different timing belts?!
Legacy777 replied to backwoodsboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore then likely the difference in belts is that one is a 60,000 mile t-belt, while the other is a 100,000 mile t-belt. Either way, the belts should be 100% interchangable.
Need part breakdown 95 Legacy trim
Legacy777 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXemail me if you don't get any other responses.
thermometer - slow responding
Legacy777 replied to jib's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this the only time it has happened, or is it happening again? Did you try turning the car off and on again?
Window tinters in Northern NJ
Legacy777 replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to try asking in the meet & greet forum or on http://forums.nasioc.com/forums in the NE regional forum.
Madison WI. -looking for mechanic
Legacy777 replied to tiredandwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't get any responses here, you may want to try posting in the meet & greet forum or off topic.
Confused about the tapping sound
Legacy777 replied to motojeff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the sound is speed related, rather then engine related, then I would probably not suspect the oil pump or the related issues I mentioned above.
Neutral postion switch
Legacy777 replied to kaptainkr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the AT cars, the neutral switch is part of the inhibitor switch, and while I believe it can be removed from the outside of the transmission, it may not be fun. You can see it in this pic, it's where the cable goes to. http://www.surrealmirage.com/subaru/images/swap/09/DCP_3215.JPG
Swapping a AT to an MT in a 97 Leg???
Legacy777 replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake a look at my writeup. It should be similar, with the exception about maybe having to get a MT ECU. www.surrealmirage.com/subaru/swap
6 disk cd not working
Legacy777 replied to benebob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried cleaning the the cd player? Does it do it with all discs, or just certain ones?
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....I'm not sure if they'll work. To be honest, if you've already bought the parts, I'd just hook it up and see if it works.
tat-tat-tat-tat goes my turbo @ max psi
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd just keep an eye on the plugs, and you may want to check the plug wires. You may also want to run some injector cleaner or something to clean things out a bit, because you probably were depositing some carbon build up from the plug being fouled.
Legacy777 replied to motojeff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible the oil pump may need some attention. There are screws on the backing plate that some times come loose, as well as an o-ring between the pump and block (however they don't usually fail). I'd suspect a screw on the backing plate. Here are some pics of my timing belt change which have some pictures of the oil pump and screws. http://www.main.experiencetherave.com:8080/subaru/images/timingbelt Have you tried changing oil viscosity higher or lower to see if that changes anything? Josh
