8
It's possible the oil pump may need some attention. There are screws on the backing plate that some times come loose, as well as an o-ring between the pump and block (however they don't usually fail). I'd suspect a screw on the backing plate. Here are some pics of my timing belt change which have some pictures of the oil pump and screws. http://www.main.experiencetherave.com:8080/subaru/images/timingbelt Have you tried changing oil viscosity higher or lower to see if that changes anything? Josh
Are you sure it's not just the throw out bearing? I'd suspect that before the input bearing. If you were to replace the input bearing, I'm not sure whether it would need to be pressed on or not. Here's a scan of the main shaft...not sure if it helps http://main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_main_shaft_assy.jpg
