How many hp out of an EJ22T without cam/head/block work?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurbo...turbo....turbo. The engine itself really doesn't need to be fooled with. A bigger turbo, and the supporting systems to handle that larger turbo will yield very nice results. There's guys on the legacy central BBS around 200, and more. The biggest limiting factor with these cars is the electronics, specifically the MAF sensor. It maxes out around an airflow of 200 gm/sec....which equates to about 200 hp. So to "properly" measure airflow you need a larger sensor, but then you need to have the computer to utilize it.....and as you can see, it snowballs from there. That's pretty much where I'm at. I've got a brand new TD05 from deadbolt sitting in my living room, and STi injectors waiting to go in.....but without a decent engine management solution..... When I'm done, I would like to be around at least 250 chp, if not more....and I think that is a very doable setup with what I'm planning to run.
installing motion detector in alarm system
Legacy777 replied to whiteoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a factory item, you may want to ask on www.legacygt.com/forums and see if anyone has any experience with it.
Trailer Hitch Wiring Problem on 05 Legacy
Legacy777 replied to charlierh2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow is the wiring tapped into the car's wiring? Is there a plug & play harness type of thing? Or were wires cut and tapped into? It almost sounds like something is not wired properly.
harness compatibility
moving to retrofitting forum.
Quick ? about power steering
Legacy777 replied to sketron13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll probably work, you may need to swap out the PS pump bracket that bolts to the engine, but I don't see why you couldn't do that.
1990 Subaru Legacy TCU codes 12 and 24...
Legacy777 replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe duty b is on the valve body, and the duty c is in the tail housing of the trans. Both require removaly of components from the transmission.
rust above windshield
Legacy777 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the rust under where the windshield seals, or above it? You could probably remove the windshield, clean the rust and put in a new windshield.
97 Legacy GT questions
Legacy777 replied to haretoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Cel P1505
Legacy777 replied to Mark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does the car run? Is there anything that seems out of the ordinary?
Manual steering rack in an SVX or any later subie that came with PS
Grew up in the Seattle area & went to school in PA, so I might have been around a few hills Either way....the subject has been brought up on NASIOC. If you truly want a manual rack, find out what, if any is available for the impreza and use it on the SVX.
What's the advantage to "Manual" mode?
Legacy777 replied to Vez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the light come on when you depress the manual button on the shifter lever?
Tuning `92 Legacy 2,0 Turbo
Legacy777 replied to Kashmir_'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to search www.bbs.legacycentral.org
2.5 dual cam, wont start
Legacy777 replied to byronc10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should roll the engine over by hand when you have the timing belt & tensioner put back on. That will help take up slack in the timing belt and help prevent the t-belt from skipping a tooth at startup.
Cel P1505
Legacy777 replied to Mark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the CEL stay on all the time, or did it just come on, and go out?
Upgrading from 2.2 to 2.5 in a 93' Legacy
Check out www.bbs.legacycentral.org JasonGrahn did this swap on his first gen legacy. Do a search by his name, and you should find his post.
This question has been asked a tons on nasioc. I don't know the outcome or anyone has found one, but I'd suggest searching, and see what you come up with http://forums.nasioc.com/forums Personally, I'd want some form of power steering...but that's me.
2002 EJ25 advice/help in Maryland area
Legacy777 replied to DaveO's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't get any takers here, you may want to also post in the meet & greet forum.
Sneezing 2000 Forester
Legacy777 replied to jtarne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you please try and describe the sound a little more?
Cold air intake in a Loyale
Going to move this to the old gen forum.
Need exploded view of Forester front body assembly
Legacy777 replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to try posting on nasioc. Someone may have something http://forums.nasioc.com/forums
2.2L knocking sound (sound clip attached)
Legacy777 replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe way it sounds, and the fact it comes and goes would rule out exhaust leak IMO. It does almost sound like piston slap.
Leafs and and stuff in heating system
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen yeah....you could have leaves further up the system.... However that should make getting at things easier. There should be ducting/box behind the glove box. If you can remove that, you should be able to access the ducting from the motor to heater core. You may not be able to get everything, if something went past the heater core, but you should be able to check things out before.
top speed limiter? Why only 112 mph
Legacy777 replied to sc850r's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs nipper mentioned, the speed limiter is set based on the speed rating of the tires that come on the vehicle from the factory. If you upgrade to higher speed rated tires, then technically there shouldn't be any real reason you couldn't bump the speed limiter. With OBD2, you should be able to find software that is capable of doing this.
A/C receiver Dryer question
Legacy777 replied to anastij's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's odd. I've bought new receiver/dryers for my 90 legacy from the parts store and they've been fine. Have you tried a different autoparts store, or just gone back to the same one?
P0400 and C0300 codes (MY02 WRX)
Legacy777 replied to ddk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good.
