dash lights
heartless replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi could 3d print one of those up for you in a matter of minutes...
Clicking from dash when starting
heartless replied to Cfoust's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso verify that the clutch pedal is activating the switch properly. my old GL developed a problem because the switch had vibrated loose over the years.. readjusted & tightened and the problem went away
92 Legacy starting problems
heartless replied to Laurie Brown's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXholding the pedal to the floor when cranking is a "clear flooded condition" signal to the ECU, this signals the ECU to shut down the fuel pump temporarily... you may have one or more injectors leaking.
2003 strut swap
heartless replied to 03lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit was a direct bolt in on the earlier 90's cars, but they changed the rear suspension at some point (not sure exactly when) so the rears probably not. I did it with a 95 Legacy and loved it.. only reason to unbolt the sway bar is to make it easier to get the longer strut mounted - once in, the sway bar gets bolted back up. I am sure others with more experience with the 2000+ models will chime in soon.
dome light delay option
heartless replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhonestly, i never really understood the desire for the delayed dome light and/or headlights. To me that is just an unnecessary drain on the battery and in really cold weather, it can actually be a problem. my boss drives a mini van that has the delay on the headlights and they stay on a LONG time.. seems like at least 3-5 minutes. Why?
14 Forester Audio Upgrade
heartless replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck here for a factory service manual that should include the wiring diagrams: http://jdmfsm.info/Auto/Japan/Subaru/Forester/ you really should have invested in an adapter harness rather than cutting the factory wiring, but too late now.
99 Outback Wagon Master Window Switch Replacement
yes, the door panel will need to be removed. if at all possible, get the vehicle inside a warm garage.. cold clips are more prone to breaking look carefully for any small covers that could be hiding more screws - check at both top ends also..under or around the rubber seals. you may also want to remove the triangular piece over the mirror mount - makes it much easier to remove and reinstall the panel if that is out of the way. it is usually just held with clips - pry gently all the way around to prevent breaking things. remove the screws you have found, then with a wide flat tool get under the edge of the panel and gently pry it away from the door - there are small plastic push clips that keep the bottom edge fastened in.. once the panel is loose and hinging at the top, push upwards at the back end to get it started out of the window channel. (note: door handle can be kind of a pain, but it will come out) once you have the panel loose from the door, you will have to unplug wiring to fully remove it. from there, replacing the master switch should be pretty self explanatory - installation is the reverse of removal - plug everything back in, set top edge back into window channel, and pop clips back into their holes in the lower section, reinstall screws and any covers and you should be done.
Part needed 42026AC130 canister bracket
heartless replied to Rick Simmons's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you tried searching on car-part.com?
99 imprea 2.2 doesn't have injector pulse
heartless replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwe are not talking about the markings on the front of the cam pulley.. you need to look at the BACK of the cam pulley - there are raised marks that the cam sensor reads to determine when to fire the injectors.
heartless replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope, they need to match the ECU expectations, not the block. if the pulleys on the original block have a different pattern, then you need to swap them onto the new block
heartless replied to poorboy87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcompare the backs of the cam timing pulleys.. there may possibly be a difference. there are raised hashes that signal the timing to the ECU. if the ECU is looking for one thing, but the incorrect pulley is providing something else, it wont fire.
Help diagnosing manual transmission problem? 2000 Legacy GT
heartless replied to consmi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno - you need to get jack stands.. You should not be crawling under a car that is held up with just a jack. Jacks fail, far more often than people think. Jack stands are far safer.
2008 Impreza 2.5, Heat and A/C not working properly
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthermostat not operating correctly (or lack of one) can make warm up time take a lot longer.. and the colder it is outside, the longer it will take. thermostats are intended to stay closed until the desired temp is reached in the engine, then they open to allow full circulation of the coolant. not having a thermostat allows full circulation all the time, which increases the time it takes for the engine (and coolant) to warm up and is actually detrimental to optimal engine operation. and I hope you know not to use aftermarket thermostats in a Subaru..
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtotally normal operation. heat is provided by the flow of "hot" coolant thru the heater core - therefore the engine needs to be run and warmed up in order to provide heat. AC also depends on the engine running in order for the AC compressor to operate properly.
Airbag light cel on 96
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the light is on, there is something in the system that is causing it. the light does not come on for no reason whatsoever. a bad sensor, bad wiring, damage to the control unit (moisture or something) - something caused the light to trip.
99 Outback Wagon Strut & Spring Questions
yes, it is a part of the top mount. https://www.rockauto.com/en/moreinfo.php?pk=503098&cc=1389405&jsn=422
no, i am talking about the bearing in the top mount of the front struts. Yes, there IS a bearing in there that takes a lot of stress.
KYB is the preferred brand for Subaru struts. Springs - unless there is an obvious problem the stock springs should be fine to re-use. there are aftermarket springs out there, but i have no experience with them myself. something to pay attention to are the top mounts - especially the fronts.. there is a bearing that allows for turning - carefully inspect from the top looking for grease oozing out, rust, or other signs of deterioration... I personally recommend ordering a pair of mounts for the front at least so if there is a problem you can swap them out easily while you have things apart and you only have to do it once. once apart, if the bearing is anything but smooth rotation, the mount should be replaced.. And welcome to the world of Subaru! I am on my 4th, a 2002 Forester with over 255k on the clock
CEL codes on EJ22
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot really any more difficult with drums, aside from getting the springs off/on, lol. just pay attention to how things come apart, and put them back on in reverse. you dont need to be a "trained mechanic" to do this job. my 2002 Forester has rear drums.
CEL codes on EJ22
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow hard the drum is to get off kind of depends on how worn it is inside.. if it is worn there could be a bit of a lip that will hang up on the shoes when you try to pull it off. there is an adjusting wheel accessible from the back side that should allow you to adjust the shoes to give more clearance. recommend getting a drum hardware kit as well as the new shoes.
Cv axle install issue...
heartless replied to Cameden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can get the Suretrak axles from RockAuto for about $40 - depending on the application.. I have one in my 02 Forester and so far it seems to be fine.. was installed in August i think.. maybe late July.. This is the one I purchased for the Foz https://www.rockauto.com/en/moreinfo.php?pk=3854955&cc=1378739&jsn=407
Front strut bearings - Who has replaced these?
heartless replied to Mitchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas long as the bearing moves smoothly, it will be fine for a while longer. if it is notchy, or grinding at all, the top hat should be replaced.
09 Forester, elevated rpm after ignition
heartless replied to augustsky3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, it is normal for it to do that. The idle will drop on its own as it warms up. Every Subaru I have owned has done this.
New guy cant fill gas tank on 1998 forester
heartless replied to shredd_guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, my issue turned out to be vent lines that were rusted completely shut (the metal nipples) new filler neck with all new vent connections (and the shut off switch at the top) has solved my problem. was going to try pulling one of the vent lines to test as described above, but after removing the clamp, tried to twist the hose to loosen it, and it twisted the metal tube right off of the switch.. oops.. so ordered new filler neck and a new shut off switch.. when the neck arrived, it already the switch installed, so the separate switch got sent back. got it all installed, and YAY! I can put gas in again without fighting with it!
engine ticking when cold
heartless replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's kind of rude not to include the whole story of the car from the start..
