dave valiant
Everything posted by dave valiant
  1. Turbone is it normal to be completely out of advance at 15 degrees btdc.I double checked my timing because I had timed it off of cylander #2 instead of #1.It was only off by 2 degrees but when I put it to #1 at 15 btdc it is out of adjustment.Thanks for the help,Dave.
  2. I got it set at 15 btdc.It was at 5 btdc.What a difference correct timing makes.Thanks a bunch Turbone.
  3. I was wondering if any one out there knows the correct procedure for adjusting the ignition timing for an EA81T.I assume you disconnect the vacuum advance but I am unsure what RPM the engine should be running at or what the timing should be set to.Any help would be greatly appreciated.Thanks,Dave.
  4. That is pretty cool.I did notice a couple of mistakes though.For 84 engines it has the 1.8 listed as over head cam.It also lists the 84 Turbo or automatics as full time 4wd.
  5. I know I am just repeating what others have said but my sube gets NGK and the wifes Jeep gets Autolites.Domestic Autolite,Import NGK.
  6. Well when I get the EJ in that EA81t will be for sale.From what I have read on this board I would be getting to my limit with the EA81t at 130 hp,with the EJ I would be starting at 130.Who knows I might want to get even more out of it at a later date.I just like having the flexibility of starting at 130 and not ending there.As for the purists,if someone out there is that offended by this they can buy it off of me.If someone wants to start a restoration on my very rusty Brat that just happens to have a rare engine,hey more power to ya,all you have to do is buy it.You would be alot better off getting McBrats turbo it is in ten times better shape than mine.I'm not trying to be a jerk here it's just that it seems like whenever I post something about modifying my Brat I get responses like "Oh No you can't do that to such a rare vehicle" well actually if it were'nt such a basket case I wouldn't consider doing such things.If you go to the midwest meet you will see me and my Brat there and you will understand that I wont be carving up a museum piece.Well I feel better and if I offended anyone out there that wasn't my intention.If you want to yell at me just make sure when you post that your caps lock is on.If it isn't I wont know if you are yelling or not.
  7. I've got a line on a 92.I just have to hear back from the seller.And as far as power is concerned I'm sure that I will be way better off with any year EJ over the EA it will be replacing.
  8. Well I'm thinking of putting an ej22 in an early 80's sube.I am just trying to get some info on the engines and so far it sounds like the ej22 is a very solid unit.Since you brought up having a couple of engines what do you want for one and the ecu?I really like the looks of the older gen subes but there doesn't seem to be any real perfomance parts out there.I had thought about going with an EA82t but from what I understand the NA EJ22 makes more power and doesn't have the head problems.
  9. Hi,I've never posted here on the new side but I am planning a project involving the EJ22.I was wanting to know if there were any years to avoid or if there were any specific things to look out for.Any help would be appreciated.
  10. Thanks for the help.I will go over to the new gen side and ask them.
  11. Does anyone know when the EJ22 first went into production?Were there any model years that had specific problems?Was it ever turboed from the factory.I am thinking of doing an EJ22 project but I know absolutely nothing about them.What I am thinking of doing will take a lot time and planning so I am trying to get as much info as possible about the engine.I saw a template for ataching a dr 5 speed to an EJ22 which is the trans I want to use.Any help would greatly appreciated.Thanks,Dave.
  12. My Accell took a dump on me 3 weeks after I installed it.I also had the same problem as Stupidru with my tach jumping all over the place at idle.
  13. That looks amazing!You should have all kinds of fun torturing the honda boys in a Gen 1 Brat.You should drag it and post some quarter mile ETs and trap speeds.To Sweet!
  14. High performance downpipes for the EA81T,poly bushings,high performance shocks and struts,5 lug hubs for our 4x140mm so we can run modern sube wheels without a complete conversion.
  15. If I can get the loan for your coupe she will be called the little quad coupe.Why,because I'm a dork who has to name every car I own.
  16. Shawn I'm gonna be leaving Saturday night as I have to be home Early afternoon so my wife can work(no babysitter).
  17. It almost sounds like you are somehow getting an air bubble in your coolant somewhere and when you open the cap the bubble is vented out.I don't have any ideas of how this could be happening or if I am correct but thats what it sounds like to me.
  18. I had an old Plymouth Valiant I thought was in need of new wiring because 2 lights were burnt out.I would have to agree to check for a burnt bulb.If that isn't your problem I'm afraid I am quite useless to you.
  19. If I am leaving I will call her the Bratmobile,as in "to the Bratmobile".But if I am discussing about her it's usually Braticus.
  20. I am currently getting any where between 19-22MPG.I'm sure it would be better if my trip to work wasn't almost all uphill.When I go to the Midwest Meet I'm hoping to be in the 25 MPG range since South Dakota east of the Black Hills is so flat.
  21. Have you tried the basic tuneup stuff?My Brat's mileage was way down before I did plugs,wires,cap,rotor,fuel filter,and air filter.After I did all that my mileage went back to normal.Give it a shot if you haven't done it already.
  22. I just got my ebay intercooler and my our world is flat shirt.Its like christmas in march except I actually got what I wanted.Oops,sorry I'm rambling.I was wondering if silicone hose is the way to go when hooking up my intercooler?Any one know if I could get something like that at Napa?
  23. Just got mine today and it is absolutely amazing.I should have ordered 2 because this one will be worn out in no time.
  24. Thats what happened to me this morning.I was going to work just fine and it sputtered and bogged and quit.It took me half an hour to drive two miles to a buddy's house,and I had to push it the last block.I got off work and put the stock one back on and vroom.I only had that coil on my car for three weeks!I'm gonna take it back and get it replaced put it back on and hope it doesn't leave me stranded again.
