105
back when 2nd gear grenaded on my WRX the shop didn't want to install an axle because of a split boot. I gave them the go-ahead to put in a new axle. (FEQ ? that they get from worldpac) when I picked the car up, I asked for my old axle - I think they at first thought I was suspicious of their work, I told them I was gonna re-boot it. They got it outta the recycle bin (shoulda asked if the had any more) got that done today (Beck-Arnley kit, nice, includes grease, bands, boot and new snap ring) - gonna put it on when I do the struts - probably next weekend . Just mentioning because I noticed there are markings on the end of the axle that seemed lined-up with the 3 ears on the spider/tripod - I've always wondered about 'clocking' or timing of the radial position of the 2 CV joints to each other. My guess is, it may be important, at least important enough to mark the axle.
nice! better than grinding it out myself! those risers/mani will fit my 06 WRX 2.5? will my injectors move over? if you have a set/one to sell, how much to buy and ship one to DFW area? (this means I'll have to re-learn how to use ECU flash to kill some codes too right?) might be a nice future project. Right now I'm looking at some strut replacement work.
WRX got a 4-corner brake job - very, very close to the backing plate on one rear caliper - glad that's done. dangit if one of the tabs on the bottom part of the intake filter box isn't broken on this car? had to rig zip-ties to try to make sure it seals. Our Outback had the same problem, that bottom part on it is around $150 I had to postpone maintenance on my WRX, should have don it last month. Still needs oil change and a/c repaired. I also have a strut mount that is cracking - great, I'll probably put new KYB struts on the front and get group n mounts. Just not great timing for me money-wise....
went up Rampart Range Rd. a few miles - awesome views, easy drive though surface very rough(wonder if dropping 3-4 pounds from the tires would help?). But, I saw no ruts or wash-outs. Went in the middle of the week, saw 4 other vehicles. highly recommended - hoping to go farther next time I visit. https://goo.gl/photos/y6hpNgjEEypgY6U7A https://goo.gl/photos/GGdYMmesxKNFMU4k8 ritzy 'enclave' up there!; https://goo.gl/photos/WXckpHqpHsaacJWGA
the dipstick level is already a coupla inches higher on a sitting trans vs an idling trans so, I'm not convinced any more fluid is gonna go where it needs to go...? aren't wet clutch plates jammed into each other on pre 05 autos if the trans isn't running? probably still need to unhook the driveshaft but, I'm not sure. but I'm willing to learn if this is really a good approach interesting
consider a pre-purchase inspection. If soobs have been thru more than one owner, it's easy for them to have been abused. A good shop should know where to look for issues. RUN if you see mis-matched tires. start locating a soob-friendly independent repair shop near you. Ask about pre-purchase inspection as well as if they have a customer thinking about selling.
well, for car models that have a version with a wing, there are thicker/stronger bars to cope with the extra weight. But I think your trunk behavior is close to normal. I suppose you could order new heavy bars but, that could damage hinges I'm thinking. did you check for broken parts? is the there any sign the car has been rear-ended? I suppose if there's evidence the trunk got an excessive amount of use by a salesperson or delivery jobs (....?) it may be possible for the bars to be a weakened - maybe get some from a low miles junkyard car or buy new ones?
that doesn't seem unreasonable but - there may be an adjustment inside the trunk? I have seen sedans in the past with some type of slots or other option to adjust the lift force I think....? did a quick search - some folks have a support piece sheared off or broken; http://legacygt.com/forums/showthread.php/trunk-torsion-bars-can-someone-post-pictures-diagrami-117466p2.html evidently they ARE tricky to work on. If you find a problem inside there, maybe the car had been rear-ended in the past? I might ask a coupla collision shops how much to repair if something is actually broken.
