2000 Outback H6 driveline vibration
1 Lucky Texan replied to RodA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you swap tires around - any change? Rims OK and straight? if the car were on 4 jack stands and run, would it still vibrate? just thinking this 'might' help point towards bushings/axles/brakes - vs, engine transmission drive shaft. because some components would still receive 'close' to typical stress, while others are spinning mostly stress-free. I know it's a longshot/oddball idea, but it is cheap to try
Subaru Mechanical Problems
1 Lucky Texan replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometimes you have to take a service writer or tech for a ride to demo the problem. And when you pick the car up, do a test drive nearby so you can leave it if it isn't right.
2013 base Outback
user botenredwolf at subaruoutback.org is a car sound guru - sign up over there and message him.
ej204 AVCS timing belt replacement
1 Lucky Texan replied to pitscars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdunno why it wouldn't be similar to this;
What is this part?
1 Lucky Texan replied to Marcmoberg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat kind of difference is not ideal - much worse too if the tires are not all the exact same model. Could be an indication of prior abuse. Subaru want the tires to be the same model and size and within 1/4" in circumference. if you do all the math, 2/32" is over that spec a little.
latest catastrophe 03 WRX turbo
1 Lucky Texan replied to RustyBob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, it's a balancing issue, don't want to severely limit the ability of someone going into business for themselves and end-up protecting big companies from competition, but , the consumers need to know that, a business can be 'found' and held liable for any issue with fraud that might come up. A guy here at work got busted for flipping too many cars too quickly. He's a really good guy and actually kept some cars from going to the junkyard while helping some relatives and friends get cheap transportation. As long as it's fairly easy to get 'registered' or w'ever - I'm OK with some regulation in this area.
What is this part?
1 Lucky Texan replied to Marcmoberg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif someone responds here, that info would be great, otherwise, for an iPhone, I would just read thru some reviews at amazon, if you scroll down on the screen, usually on the right side there's a search window for the reviews and you can specify Subaru, or iphone, etc. there ARE some reports of very cheap harbor freight and ebay units not linking with Subaru s, but I think most folks have good luck in general - just make sure you can return a problematic unit I guess?
1 Lucky Texan replied to RustyBob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXafter-cat sensor will throw a code. but has zero affect on a:f ratio. Other sensors are VERY important. did you use an oem style t'stat? also, a new rad caps, and a tiny clamp or a coupla small zipties on the little overflow hose at the nipple on the rad neck are good ideas. Also check for crud blocking the o'flow hose's end in the o'flow tank. I cut mine at a 45* angle. You can pull the o'flow tank and shake some ice cubes back and forth inside it to clean it out if required. Bad cap or blocked o'flow hose could lead to collapsed hoses from vacuum.
What is this part?
1 Lucky Texan replied to Marcmoberg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlow usage is considered 'severe duty' - new fluids everywhere would be a good place to start. details on vehicle? also, if you have a smartphone, an ELM327 BT (less than 20-40 bucks) adapter and an app like Torque can get you reading your own codes +more.
1 Lucky Texan replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaside from mentioning that EZ engines are much less common than EJ and are experiencing 'some' HG issues (not sure about HG 'rate' of failure) I otherwise agree with this. mmboys07, are you the original owner of the '14? did the '14 experience any overheating from a different issue that led to the HG failure?
1 Lucky Texan replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think everyone has had quite the same 'garbage' experience you have. But, I admit, I'm not happy my WRX needed a transmission rebuild at 65K miles. - however, if I had quit Honda when my first one dropped a valve in cyl 2, I wouldn't have had 19 years of reliable service from my second Honda (well, except for no a/c the last 10 years). My BIL thought I was insane for buying a second Honda. I knew it was a one-off event. easy to find people with anecdotal problems with any brand.
1 Lucky Texan replied to RodA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseems like a remote chance but, I didn't see carrier bearing on the list. is there any noise with the vibration? feel it in the steering wheel or 'seat of the pants'?
moisture building up in the car
short answer is, they have a space for a cabin filter, but having it installed was an option. cars101.com will have instructions for cabin air filter.
Diagnostic code P000A-Oil control valve
1 Lucky Texan replied to lorigar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be as simple as a poorly re-connected wiring harness.
Dry gas/gas dryer?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo not get cheap aftermarket, they are known to not work reliably on Subarus. OEM is best. NGK or Denso will probably be $25 to $50 on am,azon depending on what part number you need.
2013 base Outback
you might check crutchfield.com too.
Installing a 2012 engine in a Outback 2007 2.5 EJ253 AVCS
1 Lucky Texan replied to Jordan8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD - do those short blocks need the oil pump upgrade? any concern about his heads/cams being oil starved?
Changed coolant temp sensor => + 3mpg!!
1 Lucky Texan replied to phil527's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnext time you feel it will fail to start - cycle the key from OFF to ON (not START) , several times(4-5-6 ?), wait 3-5 seconds at ON each time. then, try to start it. If it reliably starts better, somewhere you are losing fuel pressure - maybe tighten fuel line clamps.
Could extreme cold cause a c-clip in the differential to fail?
1 Lucky Texan replied to Scott545's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould some kind of snow/ice build-up contribute to this happening? but, as said above, the initial problem was likely left-over from the bearing work.
clogged a/c drain ? maybe blocked cabin air filter? have you checked your coolant level? look in the radiator - don't only trust the line on the overflow tank. does the inside of the car smell sweet-ish, like toasted marshmallows? if so, heater core might be leaking.
Dry gas/gas dryer?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhile it's wamed-up an idling well, you could use a plant mister to spray water on/near each plug wire and see if it causes stumbling. Some folks say if you do that at night you can see arcing. seems like plug wires or coil. the moisture is driven-off after the engine bay warms up.
97 outback
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you considered getting a key fob? probably get one from a forum member with a WTB listing in the classifieds ,or check ebay.
92 Subaru Legacy Oil leak
1 Lucky Texan replied to bcourter98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoil pressure sending until would be my first guess.
Knocking shimmy
1 Lucky Texan replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall 4 tires the same size,brand, and model? check the rear bushings on the front lower control arms too. will the car idle smoothly thru tight circles on dry pavement of does it jerk/buck?
Dry gas/gas dryer?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ what FF said dew/moisture on old plug wires can cause issues. Failed Engine temp Sensor could as well.
