1 Lucky Texan
  1. these may be the parts you need - adjustable and 'fixed' ; http://boxer4racing.3dcartstores.com/Sway-Bars-End-Links_c_166.html oops - maybe only BSR19XXZ still available ?
  2. use a 6 point socket, 1/2" breaker bar, with a cheater pipe- put the cheater on the frame on the left side - bump the starter. Some people put the breaker on the ground - guess it would work if very long. I was lucky and an electric impact took mine off.
  3. any chance there has been rodent damage to wiring? There have been some people experience ice/snow/mud pulling that connector out too. In the back around the evap canister I think. bad/loose gas cap is sometimes mentioned in connection with that code.
  4. if he has a habit of 'topping-off' the tank, the carbon canister could be flooded. there are various tubes, solenoids and valves that must be clear/functional to allow air to escape when filling the tank. That escaping air - due to being gas-fume-laden, is supposed to pass through the carbon canister so, any of that system that is clogged with a bad valve or insect nests or mud will prevent the air to pass. You can try unplugging some of the larger tubes around the charcoal canister while filling, when filling becomes easier/normal, you'll know which general area is causing the problem. the test connectors under the dash will probably cycle the evap solenoids for you - doesn't mean they aren't clogged though. others may know more about that. expect more CEL codes while doing this trouble-shooting.
  5. 93 STi ? maybe someone has added an STi badge you might check over at NASIOC if no help arrives here.
  6. WAY overdue from the 'time' side of the maintenance schedule. (105K miles OR 105Months) Do the timing system service. (I wouldn't change the waterpump, but all the idlers and the tensioner should be changed. carefully inspect the crank and cam seals and be prepared to change any that are seeping. lots of info on line, probably 2-3 youtube videos, etc.
  7. there 'may' be a way to retrofit Koni yellows inside the old KYBs. Common enough mod on Imprezas but, you might be in new territory on that Baja. (search for DIY or videos) for more exotic ideas, one source for some legacy platform go-fast bits, is boxer4racing.com . I have only bought an axle back from them in the past for my WRX but, very accommodating folks. website is so-so, I emailed Mr. Teague (i think that's the name?) and got great answers. I THINK I have read of some Tokico parts fitting some soobs - but I don't recall any details.
  8. watched a video (briansmobile ?) and that car's wheel was moving at least 3/4" - WAY more than our Outback. I'll probably leave it alone for while - and keep looking at videos and perhaps soon compare to my 06 WRX.
  9. drive by wire? some people have had to replace their pedal assemblies. You might search for those threads. my 06 WRX is DBW - trouble free so far. Didn't realize 05 was DBW on outback - or I forgot. their may be some type of code stored that requires the SSM or different protocol to read.
  10. sloshing may be due to fungus or mud or insects clogging a/c drain hose. who know how often or how severely it has overheated in the past even IF the noise is not rod knock NOW, it could develop in the future. The only way I would buy it, is with the knowledge that it likely will need a new engine or short-block in the near future, and make an offer reflecting that.
  11. get the codes read and post them here (like a letter/number combo - ex. P0123 ) maybe a boost leak could do this?
  12. it's a minimal amount of movement - I guess I'm just ignorant of what 'normal' might be.
  13. kinda seems like I'm on the edge of needing to replace something...I will further examine for excessive steering wheel play but, I have not yet noticed any shimmying. Tire wear seemed even. the car has low miles for the year, but 95%+ of its entire use has been secondary roads/grocery getter type driving so - suspension and steering get more punishment than a highway cruiser.
  14. I was doing some brake work and the front wheels of my wife's 2003 OBW can wiggle about 1mm or so in the 3 o'clock to 9 direction. Both sides do it. This is with the tire in place, maybe about 1.5 mm?, but , while noticeable, it's very slight. no movement up-down so, bearings all seem OK. just wondering how bad things need to be to warrant repair. (or, is this normal? - I don't know if i have ever really checked this before)
  15. similar to the above - I told my daughters they didn't need a car unless they had a job, and if they had a job, they could at least pay for 1/2 a car. So, the wife and I (and later, sometimes an older sister) made sure each kid got to her job until she had 2 or 3 thousand bucks saved. I told them that, I had to OK the car if I was paying for half of it. I got them 4-door sedans (a 86 Toyota Camry, a 90 Maxima and a 96 Maxima) they bought their own tires and paid for maintenance, if a repair was directly safety related, I usually paid for it, and usually paid for 1/2 of other repairs. They all 3 have an appreciation for maintaining their cars still today. The youngest one has the worst driving record, but has never hurt someone else or been seriously injured. I think she follows too closely, but, suggestions to back-off don't seem to have helped much - *sigh* at least she keeps her fluids, tires and brakes in good shape!
  16. bad/incorrect thermostat ? if it mostly happens at stop lights or at idle, confirm radiator fans are fully functional/not intermittent.
  17. if you get a t'stat, get the OEM 'style'. or, pull it and test on a stove top - do NOT let anyone drink even a drop of coolant. Animals will lap it up if you leave some outside - it will kill them.
  18. maybe pull the cover and look for a 'rubbed' spot - observe the belt while running.
  19. interesting problem. It's so hard to make a general suggestion because it depends A LOT on the individual car's prior care and present condition. i THINK I'd probably go with a 5EAT model but with an EJ or EZ engine. so, about 2005-2011 or so ?
