105
seems more like HGs but, if you saw mal-functioning fans, that needs to be investigated I'd guess. If they sre intermittent due to -what? - a failing relay or bad ground conections. w'ever - you will def. get overheating when stopped. has the car blown coolant OUT of the overflow tank? Does the car have a working OEM-style thermostat?
definitely inspect the fuel pump assembly - cheap/easy insurance. but it does seem like you have typical HG problems. There is a chemical test from the parts stores but people have had variable results with it. best to use if you see bubbling in the coolant. You might email Blackstone labs and see how much/if they can sell a test for bad HGs. probably need to sen din a few ounces of coolant.
first, yes the Gauge has it's on sensor, separate from the ECU. They MAY share the same housing in a 2000, in the 90s, they were 2 separate sensors near each other. If you have one sensor with 3 wires, it performs both functions. You also need to discover why your fans aren't working right. They should probably be running on low, or one should be on, then the other strtas when the a/c is selected. It can be a little confusing as to the logic used to decide when to turn the fans on high vs low but - You may have a bad relay or other electrical issue. Any work done on the car recently? Something related to electronics or the cooling system? Could the thermostat have been replaced with a non-OEM unit?
it may very well be that your car has a problem that the ECU is 'barely' able to correct. Such that, when trying to run on the ECU's default map, which assumes all positive factors, it exhibits poor running. Then, after a few drive cycles, the ECU has made ,perhaps drastic, changes to ignition timing and A:F ratios to get reasonable performance. Getting freezeframe data or using FreeSSM or some other deeper scan technique to look at fuel trims and similar data would be a good next step I think.
he may have been referring to some 'performance' camber bolts as opposed to OEM-style replacements. i have seen bolts sold to increase negative camber for (supposedly) 'motorsports' purposes. H&R, Whiteline, Eibach and others may have something that would help but , usually these parts are made for the WRX or STI models. another option could be camber plates for the strut mount. It should be noted, these items can sometimes lead to tires rubbing.
you could also try cycling the key to ON, wait 8 seconds, then to OFF, then repeat 3-4 times before STARTing the car. If there is low fuel pressure, this will cycle the fuel pump several times before the fuel is needed to start the car. If the issue is a leaky injector or poor fuel delivery, this could 'overiride'/mask the failure to allow a normal start.
OK, anyone else think this could be a problem with the jet transfer pump? when it starts bucking at half tank, opening the fuel tank, closing it, test for bucking. If it still bucks, try adding just 1 gallon and testing again. I think running some SeaFoam or maybe Techron thru a tank or 2 of fuel might have a chance at cleaning the jet pump out. But, I'd say evap issue is also a possibility. Ever have to 'nurse' fuel into the tank? like it won't accept the fuel quickly enough? Evere have any 'whoosh' from pressure or vacuum when you open the tank?
one difficulty is the differences from US vs non US models, but, next time the car is warm and you expect to experience a problem, hold the accelerator pedal to the floor (completely depressed) - that signals the ECU to withold fuel. If the car is 'flooded', mayy start more smoothly. Then , we proceed to check for flooding causes; leaky injector or bad Engine Temp Sensor or? If the problem is worse with the pedal down test - we might expect a low fuel pressure problem and proceed from there. If it seems the same, perhaps there is a spark or air problem ? I know the above seems vague, and the 'differences' you will be trying to detect could be subtle - but, it's just an idea. Also, scanning the ECU for 'pending' codes might help find a system that is having a slight problem.
this defintely seems like failure of the Viscous Locking Center Differential's viscous coupling. Every failure of this part ahs involved the symptoms being worse after the trans is warmed up. The hotter, the worse it is. With the tires being proper size, the only 2 things left would be, a mismatch in final drive ratios (like wrong rear diff or trans swapped) or bad center diff. a used 5 spd swapped in would probably be your best approach. (must be the same FD as stock.)
