1 Lucky Texan
  1. I recall that some older soobs had issues with the Engine Temp Sensor keeping the car in 'choke' mode - fooling the ECU into thinking the engine was cols all the time. And that will usually not throw a code. On your car, I think its the 2 wire sensor. Mounted near a one wire Coolant temp Sensor. vacuum gauge probably comes with a few attachments and instructions. Check the web and youtube too.
  2. You may be wasting money running the premium, but I don't see how it could be harmful. I certainly am no ethanol promoter, but I doubt your car would be harmed by using the regular with 10% or w;ever ethanol.
  3. you can buy Techron otc at parts stores as well as Walmart, maybe target, etc. Just use it once as instructed. I use it maybe every year or 2 before an oil change. Some years I use SeaFoam instead. I think they have an edge on some of the other additives but, i have no experience with Lucas. Certainly though, don't use it in every tankful. (is that what you said?) that money is better spent on good gas plus, over use might throw the A:F ratio off, dilute your oil or stress the cat conv. Don't over-inflate your tires too much, You lose material in the center and therefore are not really 'saving' money overall. Plus, it can be dangerous. 2-3 pounds over is OK, maybe add 1 or 2 to that if fully loaded-out. Any weight you can remove from the car will help and don't drive with the crossbars on the roof. You said you chaged the knock sensor. Any chance you over-torqued it or the cable is stressed? Most folks wire brush the mount area, make sure the cable is positioned the same direction as the stock sensor. I THINK the torque is 17 ftlbs. (anyone?) more might crack the sensor. Both of my soobs see 95% surface streets and they both average 20 mpg. My 06 WRX goes 11 mile to work, 11 miles back home, rarely any highway. Our 03 H6 sees even shorter 'grocery getter'- type trips with rare highway use. It gets 20-21 mpg. It never got better than 26mpg on a road trip/vacation. AND, they both run Premium.
  4. if you could get freezefram data to see the fuel trims, that might help you decide if there's still some problem to track down or not. I assume the tire size is the the same as listed on the door card? A bottle of Techron 'could' help restore the injectors spray PATTERN. But i wouldn't use any fuel additive in each tank. make certain the plugs are proper for the car and all the grounds are good. NGK is best for plugs and plug wires. Maker sure you use the OEM type thermostat and that someone hasn't pulled yours out of the car. Make sure you aren't dragging any brakes. make sure the wheel alignment is OK. those could be small 'parasitic' losses to mileage. BUT, I think you are close to the best the car can do given your usage. The short trips means a higher total proportion of engine time is run when 'cold' and that means injector pulses are in 'choke' mode.
  5. yeah, seems more like a vacuum leak, possibly clogged exhaust. vacuum gauges are cheap and there's a decent sized list of failure modes that it help can detect. I dunno when TB changes are due on that model - could be a slipped timing belt I guess. has the CEL returned? can you get a blink code?
  6. did you change the fluid in the diffs? what fluid did you use? do you regularly drive thru high water? (you may need a snorkel on the diff's vent) I've never checked the diff's temp - maybe it always feels hot?
  7. what was the donor vehicle? will the car smoothly idle thru tight circles in a parking lot? no jerking?
  8. the manual advises to tighten the axle nut with no weight on the tire. Did you torque it sitting on the ground or in the air? I put a big screwdriver in a rotor vane and 'buck-up' against the caliper to torque the axle nut. no harm in checking the nut to make sure it is still staked in place.
  9. what's the source of the replacement axle? MANY people have had problems with rebuilt axles, sometimes even new aftermarket axles.
  10. if it does it reliably after you start and idle in the mornings, you could 'probably' prove it's the belt again by spraying something like this on it;
  11. more likely than you think! http://www.lonestarrallycross.com/
  12. you could bypass it by connecting the hoses. No heat for the summer. use the time to save up/shop for new part.
  13. is the CEL on? post ths codes for us. Do you mean the engine is missing? or is there a vibration in car? does it jerk when parking in a parking lot? describe what's going on with a word other than shuddering.
  14. PB Blaster is unlikely to affect rice. (test ii with some rice from the kitchen?) anything I can think of to 'dissolve' rice is too risky for the metals. (Hydrogen peroxide from the beauty shop, liquid Plumber, etc.) borescope is a good idea.
  15. weird (oh, and sorry it happened to you) any dents in the oil pan? the oil pressure thing is weird, wondering about a cracked pick-up tube. maybe a different engine IS a good idea.
  16. what code was set? checked the cam/crank timing yet? also, confirm the big IAC hose is attached to the intake.
  17. I've read in the past that CardOne re-builds the re-mans for Subaru dealerships but, I have no idea how that could be confirmed. If he had bought a NEW Subaru axle, it may have had green paint on it.
  18. MUST have pulses from crank sensor. Missing 'lugs' on the crank sprocket, bad CPS, ignitor, etc. But, seems like you could have a bad fuel pump or ?
  19. I *borrowed* this from another forum - maybe it will work; 06-09: How To Read Diagnostic Trouble Codes (DTCs) How to Read Diagnostic Trouble Codes on 2005 thru 2009 Subaru Legacy and Outback The 2005 thru 2009 model year Legacy and Outback can display Diagnostic Trouble Codes (DTCs) directly on the dashboard. No scan tool is needed. No jumper wires are required, and it is not necessary to count blinky lights. The codes are displayed in plain text on the instrument cluster. Trouble codes from the ECM (Engine Control Module), TCM (Transmission Control Module) and ABSCM/VDCCM (ABS or VDC Control Module) are displayed. This procedure was distilled from the FSM. The English translation in the FSM is not very good, so I have attempted to make it easier to follow. The FSM has this procedure in the Body Section, Instrument/Driver Information, Comination Meter System chapter. Some notes before starting: - I believe this procedure will work for all 2005 to 2009 Legacys and Outbacks. However, I have only tested the procedure on my car, a 2007 Outback 2.5i automatic. - I don't know of a way to reset the codes without a scan tool. Disconnecting the battery may or may not work. - Exactly what you will see depends on what type of display your car has. There are two images of tables below, one for the Normal display and one for the Multi-Information Display that is found on Turbo models. The Procedure Starting condition: key off, headlight switch off. Steps 1 through 7 must be performed within 10 seconds. 1. Turn key to ON position. This is the normal running position, the click just before starting, when all the lights on the dash come on, but before you twist to START. Don't start the engine! 2. Within 3 seconds, turn the headlight switch ON. 3. Press the Trip/Odometer button 4 times. 4. Turn the headlight switch OFF. 5. Press the Trip/Odometer button 4 times. 6. Turn headlight swtich ON. 7. Press Trip/Odometer button 4 times. At this point, the DTC display will begin. 8. Turn headlight switch OFF. Not necessary for the procedure, but your display may be dimmed and hard to read in bright sunlight. Besides, why drain the battery? The DTCs for each module will display in order: ECM, TCM, ABSCM/VDCCM. Press the Trip/Odometer button to cycle between modules. The FSM states that the display will cycle between modules automatically every three seconds if the button is not pushed, but that did not happen in my car - I had to push the button to cycle the display. For each module, there are three display states: - Receiving DTC from module (blinking "P" or "C") - DTC detected & displayed ("P" or "C" followed by 4 digits) - No DTC found ("P" or "C" followed by "----") If there is a CAN (Controller Area Network) bus communication error, you will see only "----" in the display. Basically, that means that the network in your car is broken. That will need to be repaired before anything else can be done. See the table below that applies to your car, depending on which type of display you have. Notes - TCM error codes will not be displayed for cars with manual transmissions. The TCM display state will remain in "Receiving DTC" (blinking "P" on display). In my case, my car is an automatic, but the blinking "P" remained, possibly because I have no codes set. - To cancel the DTC display, turn the key to OFF. - If the engine is started, the DTC display will remain until the car starts to move. (I did not test this) - Past DTCs that have been repaired will be displayed until the engine is started 3 times. (I did not test this) Display Tables Normal Display Multi-Information Display from; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/19053-06-09-how-read-diagnostic-trouble-codes-dtcs.html
