105
On another board, there seems to be a trend of fuel overflow from automatic nozzles not shutting off. If anyone here has noticed the issue on there new vehicle a note to NHTSA is probably called for. In addition to possibly damaging the vapor recov. system, there is a environmental issue as well as a safety issue. Someone might get torched! fyi
check; http://www.subaruoutback.org/forums/showthread.php?s=&threadid=3&highlight=intake http://www.subaruoutback.org/forums/showthread.php?s=&threadid=148&highlight=intake for an idea As for the K&N - there is quite a bit of controversy over at http://www.bobistheoilguy.com about the amount of silicon in the oil of users of these type filters. Most folks claim at least some small improvement in HP. Caveat Emptor.
We had to replace my wife's Windstar van (teen wrecked it - everybody OK) and have had 'her' '03 H6 3.0 for a few months. I am shopping for an Impreza to replace my '96 Dodge Avenger. Shopping slowly for a '99-'01 Outback Sport (Impreza RV in Oz?). maybe I should crack open the manual though - maybe a short cut way to adjust fan speed exists? Hey, did you ever post some photos of your 3 wheeled projects?
Setright says it takes 600 miles to get all the air out of his soob. I'd check the level, refill as necessary, maybe put the front up on ramps and run with heater on untill the fans come on. Let it cool, refill. Then watch it for a few weeks. If it doesn't change and there are no other symptoms, it may have just burped itself. BUT, if you're sure you've put in more than system capacity, try comparing the appearance of the plugs to each other, an internal leak may alter their surface coatings from normal and you'know it's an internal HG leak. very odd. good luck
Seems possibly 2 different problems. strange Would it be possible to smell the 'smoke on startup'? If sweet,caramel like smell, that is coolant and a definite issue to be examined immediately. Actually, now I think of it, your dealer is putting you off I think. If they are telling you it's normal, have them start one up and show you the smoke. It can really only be 4 things, fuel, oil, condensed water or coolant. 3 of those are not good in a newish car.
Possibly being sprayed or 'boiled' out when driving and blowing back under the car. Though it seem like it would also be on other components. Have you looked at your coolant level? How long since you had a new rad cap? Any overheating or other probelms lately? What mileage,history,mods,etc? I think your engine is prone to external headgasket leaks, exacerbated by cold weather.
My answer won't be what you expect but; 1. I want to call and get an answer - not an answering machine. 2. I don't want to increase your profit margin by overpaying for 'shipping and handling'. 3. I don't expect you to be perfect, but own up to mistakes and fix them so well I brag about it to my friends. 4. I want knowledgable assistance with my purchase but don't want to be wheedled into something because you make more money with it than another item. 5. I don't want to hear "You'll need to contact XXXX to get warranty service - it's not my problem now - I just sell 'em" 6. If I use a CC for purchase, it'd be nice if your company's name actually shows up on the statement instead of me trying to figure why someplace called 'Mumble dogface at the Banana patch' got $462.97 from me. 7. Superior packaging - I mean, stuff can't bang into other stuff in the box and is an inch or more away from the inside surface of the box. NO PEANUTS! 8. Clear, easy, return procedure. If I think of any more I'll get back to ya! Carl 1 Lucky Texan
Road Trip II: TrashWagon's RETURN
1 Lucky Texan replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
"Mr Stubbs! Start the tryworks, we shall go forward laden with fire!" (I'd double check the spare tire(s), take a couple road flares, gloves, flashlight(s), some premixed coolant, if the other wagon has been sitting for a while maybe some Heet additive. Make sure the wipers are in good shape too. Watch for semis with antennas and pace 'em. Definitely slow down when they do.) good luck man! -
Well, the creation of multiple revision HGs obviously shows us the REAL problem is elsewhere in the design. But the only approach to the problem is HGs. I've read the 'open deck' design on the 2.5l may be a little TOO 'open' and the 'jugs' move around too much - thermal creep, vibration, whatever, something is compromising the HGs - it's not the gaskets per se.
