88 Justy onto Nissan 4x4 with a EJ
Heres the 88 Justy I just picked up its going onto my Modified Nissan runnin gear with a EJ 2.2
specs subject to change as I may have A.D.D.
88 Justy Body
2.2 EJ with Delta torque cams and daul webers
Nissan 720 runin gear
33" radial Swampers
transverse rear spring with center pivot for flex
Nuclear Flux Capacitor in the works with Austins help ' thanks Buddy '
Heres the frame
  • Replies 53
  • Views 19.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
The Justy bod is a great idea...what better soob body to put on a monster frame like that!!! :headbang:
Aww, c'mon, that's almost cheating! (I said almost :-p)
Looks like you're gonna have fun with that, may the best car win (I said CAR)
Twitch
Had a few inquirers hears the detailed spec
EJ2.2
adapter plate and redrilled EA82 flywheel
EA82 4wd dual range tranny
short driveshaft
720 Nissan devorced transfercase
Looks great!!!
What's next on the long list?
Edited by SoobieDoo
info
Looks great!!!
set the engine and tranny in , that will tell me where to mount the body, then mount everthing up, looks like the stock gastank can stay right were its at so that would be good, the rear fender area will need all cut out and modified
Everyone always wants to wheel a hatch, so why not a Justy. Looking cool there!
Keep it going, I wanna see a video of this thing in action!
Just buy looking at what hes doing, seems like alot more work to make a decent wheeling justy.
Agreed, but it'll be one of the few when its done :slobber::eek:
"Keep it going, I wanna see a video of this thing in action!"
then look up any version of nissan truck and watch it wheel.....
But it wouldn't be running an EJ, nor would it have a Subaru body :grin:
And I quote from the previous thread:
"it may not be a " Subaru" but for the record I dont really care"
~SJR
~SJR
and i quote for you....."i don't care either"....and, scott can stick up for himself.we are friends, and i am aloud to rib him...cheers, brian
though... I want to see the rear suspension in action, and also hear how it rides... and how the back end handles body roll since there's only 1 center mount point to the spring...
I would also suggest the interior of that thing be caged :)
+1, I've never seen any mod like that in action.
IDK about caging it though...It's not going to be a rockcrawler, and that would increase the weight quite a bit. Wouldn't that articulated rear actually prevent a roll-over?
for the events we have around here, if you put a diff body on a frame that wasn't built to handle the weight of the driveline/frame in a rollover, we require a cage. Example: Chevy Luv body on a 1-Ton frame/axles...
are you sure thats not photo shop?looks like it to me......:)
more Photoshops for ya brian :rolleyes:
nothing mounted will start at the radiator, mount that then set the engine to rad distance then hook up engine tranny driveline to t-case that will tell me were the body to frame will be mounted looks like body need to o back about 5" on the frame as pictured above , fun stuff , make it all fit
Edited by Scott in Bellingham
details
driver prevents rollover :)
