W series Toyota trans adaptors
My project is progressing slowly so Bill's shifter probably is probably in time for me. I just don't know yet what length I need as I want to drop the engine by 2 inches and move back in the chassis. Maybe I can just do with one of the stock W-series shifter locations.
  • Replies 579
  • Views 191.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • bill hincher
    bill hincher
    wish I could go with you, I was in st petersburg Russia when the wall came down .;o) ( true story) all I can do is keep updating my posts and you can watch me here
  • GeneralDisorder
    GeneralDisorder
    Count me in for a B.H..... Just bought a t-cased hatch (THE t-cased hatch?!?) and it's pretty much a no-brainer to go over to the Yota transmission.   Any way we can get on a list for one of the fi
The fortunate thing as far as I know bills shifter can be located anywhere because it is going to utilize a Mitsubishi eclipse cable style shifter, so it will be about getting the cables the right length.
  • 2 weeks later...
I had to build a universal remote shifter that would fit both the W series and R series transmissions, so I used as many existing parts as I coould to hold the cost down
the rotation of the second shaft will be produced from the rotation of the shifter handle while the forward and back motion will be from the handle itself, the reason for that was because I had to have two seperate motion ratio's from the two seperate movements
the sideways motion through the 'gate' of the shifter can be adjusted by the hiegth of the two pivot points while the length of the 'throw' can be adjusted by the length of the shift arm
here you can see how the rotation to the right and then to the left works through the pivot pionts
what you dont see here is how this appies to the length needed for the subaru adaption, well, a u-jiont is attached to the two shafts and the shifter is placed as far back as you want, then two 'drive' shafts are placed between the shifter and the remote controller to provide a front and back motion to one shaft and the rotation of the second shaft
Edited by bill hincher
Very nice! So I'm assuming the aluminium bit that's in a proto-type looking stage in your pictures will be one of your famous castings and then you will provide the shafts that exit it to interface the u-joints with?
I can see an application for this setup on both street and off-road applications and many different generations of Subaru's.... what (if any) model of shifter were you planning to have this interface with? Or are you going to provide the basics and we just buy tubing to build the length rods we need?
Also - what about vertical support for longer shafts? I'm not seeing how to anchor it to the body if you had say... 14" of shaft before the shifter... Subaru uses a body mount at the back of their shifters to give them support.
Edited by GeneralDisorder
what this will wind up being is a box that bolts on the the transmission with two shafts out the back, then the shifter will be on a plate that mounts to the floor of the given car and then the shafts cut to size
Working miracles again are you :)
Can't wait for the finished product!
  • 3 months later...
Hey Bill,
Ive got a fella intersested in a subaru conversion in his toyota rock crawler.
Whats the best way to steer him your way for info/pricing etc other that these 50 plus pages?
I have mine going into MY toyota rock crawler RIght rump roast we speak!!!!
Just a teaser!!
Is the motor going to clear the frame and steering? It's the reoccurring issue with swapping a Subaru motor in something else.
I am amost to that point.Like so close it is ridiculous.I will have family here for the next week, so I'll find out in a week or so :)
FRom measurements it looks like I will need to relocate the ford shock towers, then flatbelly to clear the bottom of the valve covers.
We shall see.
It will get mounted in there.Period.;) Whatever I have to do to make it fit....
Cheers
:cool:
Just a teaser!!
I will absolutely post pics.I probably won't make a build thread here
As this is a Subaru board.
It's kind of like my mazda swap, I feel like it should be on here but really doesn't belong.
There's a non Subaru section though.......A build thread would be great to watch. Just add it to your thread you already started.
Fair enough.I feel differently about it all the time....
But I would never leave you guys out :)
:drunk:
  • 3 weeks later...
Bump!
How's this coming? I'm really interested in putting a Subaru EG33 in a Toyota 4x4 pickup. :D
  • 6 months later...
ok- im ready to buy bill- do these fit only w and r series trans (no g series?)
have we come up with a remote shifter yet?
thanks
  • 1 month later...
After reading the pages where you were dealing with a reverse mounted starter I'm thinking that something like that with a subaru might be pretty neat,because for a RWD/4WD transmission  that rear facing starter does kinda limit how far back the engine can be.In my minds eye there should be enough room to flip the starter on an EJ22. Can anyone with one of the adapter bellhousings see if that might be possible.There is no point in that if the smallish starter interferes with the intake manifold but it might be nice to check out.
  • 2 months later...
Hi bill,
I'm In awe of your work and just wanted to ask you a few questions if you don't mind.  there are too few with your skills around anymore.  you are doing the buckeye state proud keeping manufacturing alive, a true AMERICAN.
1. What was your education/career path to allow you to establish such a high level of skill in so many trades?  you seem to be a tool and die machinist, fabricator, engineer, mechanic, and sculptor wrapped into one.
2. have you considered,(or do use) CAD/CAM technology for what you are doing with bellhousings?
3. how do you indicate a complicated rough casting such as a bellhousing for a first cut?
4. how did you calculate/measure for your allowed 1% shrinkage in your casting form, or how did you establish a register for those measurements if that question makes sense? radially from center of crank?
5. how can I learn to do what you do, or find a similar occupation? Currently I am a custom architectural metalwork fabricator but am bored with railings and stairs and interested in getting into more of a custom machining, prototyping sort of career.  have no formal training except my desire to learn.
thanks for your time,
Jeremy
  • 2 months later...
Interesting thread, very much interested in getting one for my latest project. Anyone got any more info? Thanks.
