April 7, 201213 yr 2" SJR Lift kit, with 14" Peugeot wheels and 27" Bighorns. Everything else is stock Awesome /me makes a note
April 7, 201213 yr Author Gave the old girl a workout today going down to IL. I used the downgrade to my advantage, once I got up to 80mph it held up there pretty easy all the way back (Even on upgrades) The car felt more alive once I got into town, sure does 55mph a lot easier and quicker. Needed the old Italian Tune-up!
April 7, 201213 yr My god it turns high RPMs with the auto 5speed swap it :cool: I wish my speedometer worked though....
April 7, 201213 yr How far off is the speedo with the larger tires? You have me dreaming of the same look for my Loyale.
April 7, 201213 yr Author How far off is the speedo with the larger tires? You have me dreaming of the same look for my Loyale. Its about 5mph off. So if m Speedo says 75 I'm really going 80.
April 9, 201213 yr have you ever checked it vs a GPS or anything? with my setup, when my speedo says 65, im going 75, i would bet that if you are sittin at 75, your probably lookin like 85 or so. or were your tires less dia than mine??
April 9, 201213 yr Author have you ever checked it vs a GPS or anything? with my setup, when my speedo says 65, im going 75, i would bet that if you are sittin at 75, your probably lookin like 85 or so. or were your tires less dia than mine?? Mine are actually slightly bigger then yours (Thats what she said) (My Spare Grabber is a little smaller then the Bighorns) I checked my speed via Speed radar on the side of the road, but god only knows how accurate that really is lol...
April 9, 201213 yr I checked my speed via Speed radar on the side of the road, but god only knows how accurate that really is lol... I'd say those are pretty good. Every one of those I pass always show the same ~3mph slower speed then my speedo does. I'd say they are pretty good to within a mile/hr or two
April 9, 201213 yr Mine are actually slightly bigger then yours (Thats what she said) (My Spare Grabber is a little smaller then the Bighorns) I checked my speed via Speed radar on the side of the road, but god only knows how accurate that really is lol... hmm, yeah, if they are larger than mine, you should be seeing a slightly higher spread between the speedo and actual speed. i would hope the speed radar on the side of the road is correct, although, it wouldnt suprise me if they set it offset a couple of mph to make ya double check.
April 9, 201213 yr Author Either way, if I'm going 65mph on the interstate, people still pass me at whole sale.
April 9, 201213 yr Author this is true, no one actually goes 65 on the hwy. haha. Which is why I pushed my car up to 4500rpm and started passing the people whom passed me Lol! I can't imagine what it sounded like as I passed them. Although, this car is not squirrly with these heavier wider tires!
April 28, 201213 yr Author Just rolled over 122,000 lastnight! Now at 122,102. This is now the full-time DD.
April 28, 201213 yr Just rolled over 122,000 lastnight! Now at 122,102. This is now the full-time DD. oh to be young LOL my old girl is about to pass the 295,000 mark;)
May 11, 201213 yr Author So, I am working on a few extra little things for this car come the Don Miller show. We'll see if I get them in time...!
May 22, 201213 yr Where did you get your tires. What is the ratio on them? like 175/85r13 or whatever
May 22, 201213 yr Author Where did you get your tires. What is the ratio on them? like 175/85r13 or whatever DLS Tire Center. Any tire chain will get them. They are 27x8.5.
May 22, 201213 yr DLS Tire Center. Any tire chain will get them. They are 27x8.5. Would these fit on 14" pugs? http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO&sidewall=Raised%20White%20Letters&partnum=975R4ARAKORWL&tab=Specs the 195/75 r14? and witha 26" sidewall I wouldnt need to cut or trim right?
May 22, 201213 yr Author Would these fit on 14" pugs? http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO&sidewall=Raised%20White%20Letters&partnum=975R4ARAKORWL&tab=Specs the 195/75 r14? and witha 26" sidewall I wouldnt need to cut or trim right? They will fit the rim fine, you will still need to trim the front fenders to allow for turning clearance.
May 22, 201213 yr They will fit the rim fine, you will still need to trim the front fenders to allow for turning clearance. Well then might as well get the bighorns. saving up to get big horns, 14" wheels, and a boss 2" lift. How hard is it to cut the fenders?
May 22, 201213 yr Author Well then might as well get the bighorns. saving up to get big horns, 14" wheels, and a boss 2" lift. How hard is it to cut the fenders? Get a thin metal cut-off disc for an Angle grinder, or air cut-off tool, You want a thin disc, so you remove as little material during cutting. It is very easy, if you take your time and have a steady hand. Draw a line on the fender where you want to trim, then score it with the cutting disc first, then make the final cut. You will need to repaint the area you are cutting, because the paint will bubble due to the excessive heat.
May 22, 201213 yr How slow are you going that it is bubbling the paint?!?!?! I've done a LOT of skinny wheel cutting, and have never ever had that problem:eek:
