My '92 Loyale: Safariwagon
  • Replies 935
  • Views 185.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • TheLoyale
    TheLoyale
  • Removed the Headliner to check out the Supporting slats in the roof, everything seems solid. So I will be applying FatMat on the entire roof to dampen any noise.     I am also removing all the or
  • TheLoyale
    TheLoyale
    Oh and heres the little extra on the rear gate!
Posted Images
Gave the old girl a workout today going down to IL. I used the downgrade to my advantage, once I got up to 80mph it held up there pretty easy all the way back (Even on upgrades) The car felt more alive once I got into town, sure does 55mph a lot easier and quicker. Needed the old Italian Tune-up!
My god it turns high RPMs with the auto :eek:
5speed swap it :cool:
I wish my speedometer worked though....
How far off is the speedo with the larger tires? You have me dreaming of the same look for my Loyale.
Its about 5mph off. So if m Speedo says 75 I'm really going 80.
have you ever checked it vs a GPS or anything? with my setup, when my speedo says 65, im going 75, i would bet that if you are sittin at 75, your probably lookin like 85 or so. or were your tires less dia than mine??
Mine are actually slightly bigger then yours (Thats what she said) (My Spare Grabber is a little smaller then the Bighorns)
I checked my speed via Speed radar on the side of the road, but god only knows how accurate that really is lol...
I'd say those are pretty good. Every one of those I pass always show the same ~3mph slower speed then my speedo does. I'd say they are pretty good to within a mile/hr or two
hmm, yeah, if they are larger than mine, you should be seeing a slightly higher spread between the speedo and actual speed.
i would hope the speed radar on the side of the road is correct, although, it wouldnt suprise me if they set it offset a couple of mph to make ya double check.
Either way, if I'm going 65mph on the interstate, people still pass me at whole sale.
this is true, no one actually goes 65 on the hwy. haha.
Which is why I pushed my car up to 4500rpm and started passing the people whom passed me Lol! I can't imagine what it sounded like as I passed them.
Although, this car is not squirrly with these heavier wider tires! :burnout:
  • 3 weeks later...
Just rolled over 122,000 lastnight! Now at 122,102.
This is now the full-time DD.
oh to be young LOL my old girl is about to pass the 295,000 mark;)
  • 2 weeks later...
So, I am working on a few extra little things for this car come the Don Miller show. We'll see if I get them in time...!
  • 2 weeks later...
Where did you get your tires. What is the ratio on them? like 175/85r13 or whatever
DLS Tire Center. Any tire chain will get them. They are 27x8.5.
Would these fit on 14" pugs? http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO&sidewall=Raised%20White%20Letters&partnum=975R4ARAKORWL&tab=Specs
the 195/75 r14? and witha 26" sidewall I wouldnt need to cut or trim right?
They will fit the rim fine, you will still need to trim the front fenders to allow for turning clearance.
Well then might as well get the bighorns.
saving up to get big horns, 14" wheels, and a boss 2" lift.
How hard is it to cut the fenders?
Get a thin metal cut-off disc for an Angle grinder, or air cut-off tool, You want a thin disc, so you remove as little material during cutting.
It is very easy, if you take your time and have a steady hand. Draw a line on the fender where you want to trim, then score it with the cutting disc first, then make the final cut.
You will need to repaint the area you are cutting, because the paint will bubble due to the excessive heat.
How slow are you going that it is bubbling the paint?!?!?!
I've done a LOT of skinny wheel cutting, and have never ever had that problem:eek:
That looks so awesome there. Have you had a chance to use it yet :lol:
