Retro GL-10 TURBO build
Those are some damn nice wheels.
thanks i could not pass them up for this build
Exciting when all the pieces start to come together a bit, isn't it? :headbang:
LOL so true its moving very nice soon, this weekend have a wedding and monday start to rip this ea82T out and drop in the new heart.
well this was Franz's idea on welding the cap set up and my Tial Bov set right on the AWIC and it turned out F amazing
and push lock hose PARKER and fittings PARKER which cost more then the hole awic set up LOL
  • Replies 479
  • Views 153.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • a company in the usa makes them out of fiber yours looks to be the same        so
  • well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone
  • my guys are so busy they made mine and told me its going to be a while.. but i have another way of doing this with out costing so much which you will see in the wagon build i have going on... got new
Posted Images
also this came in my new calsonic OEM 1986 subaru gl-10 turbo radiator 5mt version.
real JDM LOL
my STi clutch slave & 4 Port brake master all OEM factory brand new Subaru.
so today i look at my car and i find that my CV boot has ripped so right away i put it up on hoist to fix her up !
as i fix the CV boot i might as well add the 20mm xt6 sway bar and my whiteline control arm bushings. i notice my exhaust header has this big un wrapped section ! i got extra header wrap might as well !!
so how does it drive with a 20mm sway bar and whiteline bushings !! :D:D:D lets just say look out STi's ! your Great Grand Father Subaru go show you how its done young wipper snapper's :P
well my spal made in italy fans came in
mounted ready to drop in.
a special treat the front OEM Subaru front skirt for my car brand new ! slice the wind !
is there another part number i can't use that one for some reason
Wow! They still had a new one?!
dealer did not have one, some body shop in cali had it on ebay with the oem part number after i did a search
it was a 1 and a million lucky find on ebay
This dream is what threads are made of.
:headbang:
lol so true i'm a very lucky subaru fan that got this car for sure !
had to put it on just did it
I both love and hate this thread all in the same time.
Do you have the proper mounting brackets for the front lip? My first one didn't, and it's junk now....
lol thanks & sorry i guess hehehe
well from my model when i put it on the front fenders need 3 holes drilled in them at the bottom. i guess the two door has the 3 holes each side all ready from the factory.
i am missing one bracket under the the signal light's, there is two holes for clips i see in the factory service books and on the skirt.
ill check tomorrow and order them new, but i really dont need them its on there pretty good.
Yea, those.
Here's what will happen if you only have it mounted on the sides:
What size are these fans, 12"?
This car is looking outstanding in everyway!
I. Love. This car. lol Can't tell you enough times how amazing this process is. Thanks for sharing the whole process with us and for many many many pictures of everything.
We appreciate :headbang:
This is so badass.
My first car was a lowly GL wagon, latest car is a '94 SS, your work inspires me on many levels!
^ thanks for the kind words
it has started ! tomorrow drop motor tranny in start work on other things.
new clutch set up and brake cyl.. pedals in also
I really can't even comprehend how factory clean this car is! Its mind boggling for sure.
Can't wait to see the build!
Why is this car always wet? lol.
Its like a show car with only 25,000kms 26years old.
Lol it's all ways wet because I got OCD bad and I have to keep cleaning it or I get messed up in the head thinking how dirty it is.
But I just washed the engine bay also so tomorrow I will drop that motor I made in it !..
When it's all done I want a nice appraise of all I done and how clean the car is !
I'd love some more pics and info on what pedal box you used, and how you went about putting in that hydraulic clutch.
the pedal box is from the normal subaru (wrx, legacy turbo, gc8, sti) ones that use hydraulic system, all i did was drill the bolt holes and the huge center hole for the slave. ill take some pics for you.
also the gas pedal is not in yet...... i wanted to cut the one off the gl-10 box but my father likes to keep everything in perfect condition lol, just weird like that.
ill take some pictures under the dash for you tomorrow of it
I'm not hating or trying to flame you, but tell me you cleaned up that engine bay. I can't believe how clean that car is lol.
no worries, but this car only has 25,000kms on it, it was stored or forgotten about in a garage for 26years. and yes i degreased the engine bay and thats how clean it came out.
This is some sick ************.
:headbang:
LOL thanks man
well i wanted to keep my oem steering wheel in for cruise control but the pedal box is a bit different. then i found the oem horn button on jdm leones on ebay for nardi wheel's, i had to i could not resist. i also found the real momo hub for the leone in germany on its way specific for my car.
Edited by Nico
