4x140 to 5x100 bolt pattern adapters
  • 5 months later...
  • Replies 164
  • Views 90.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • matts87glsedan
    matts87glsedan
    hi everyone   I finally pinned down the waterjet today. he will be delivering 'some' of the 28 pcs that i need this week, so i will be running some on friday.  Friday is the only day i have availabl
  • matts87glsedan
    matts87glsedan
    hey guys, disappearing Matt is back   Leeroy, yours are in the mail, i PM'd you   everyone else, i will tot up a list and consider another run... i have realised I am pretty bad at internet busine
  • matts87glsedan
    matts87glsedan
    Done, this is now   The Official List:   86BRATMAN - 1 pair edrach           - 1 pair dudesmccool - 2 pair subaruguru    - 2 pair    soobydoo       - 2 pair 86GLAK          - 2 pair ftwneon
Posted Images
well there's been some interest in my adapters, so im starting a vendor thread.
heres the prototype: I have about 5000km on these, no problems yet.
Stock material is 6061 T6 aluminum. standard material for all internet wheel spacers.
MOUNTING INFO
  • the 4x140 pattern is tapped with a M12 x 1.5 thread to facilitate bolting through the original stud holes to the hub. i will supply M12 x 30mm class 10.9 mounting bolts. you need to knock out your studs and put the bolts in their place, torque is 72 ft-lbs, blue locktite MANDATORY! retorque after 100kms.
  • Note how the bolt sticks thru a TINY bit on the above pic. This needs to be touched with an angle grinder or just filed off. I wanted max thread engagement, so you have to live with this.
STUD INFO - DORMAN 610-320 is recommended
  • the 5 x 100 pattern is drilled for an M12 1.25 stud with a 12.8mm knurl. the stud head size that i used was 19mm dia, by 4.5mm deep. check your stud head diameter and thickness before installing. you may need to grind them a bit. these holes are a PRESS FIT. i had to put about 1000psi on mine to get them seated, but you really don't want them to spin, so tight is good. Length of studs needed is M12 x 40mm long. Nissan pathfinder studs are M12 1.25 x 41.5mm - they should be close enough, you make the call. I am not providing studs.
  • When pressing - make sure the receiving die under the adapter is as small as possible, while still clearing the stud threads. A bit of oil is ok. Freezing the studs overnight may help too, but dont heat gun the adapter you may wreck the temper.
CENTER BORE
its 1.98 inches. you may have to grind your 36mm socket. mine fits.
RIM CENTERING
these provide a 7/8 offset, with a 3.5mm tall lip to center the rim on.
price will be 60$ a piece. for one adapter and 4 mounting bolts
thanks soobydoo, capn_r , 86BRATMAN, and bratman18 for the initial interest here: http://www.ultimatesubaru.org/forum/topic/137844-matts-gl-sedan/
edit note - i am filling in the necessary finalized details in bold , as i nail it all down.
I really need a pair of these for the rear end.
Edited by Suber_Tony
  • 2 weeks later...
I am Also looking for 4 of the adapters if there's a will there's a way I am willing to work with / provide deposits pleas let me know thanks!
  • 1 month later...
I desperately need these as well and would be able to pay for them if they can get shipped to 89431...Studs aren't a problem on my end. Thanks
  • 2 years later...
Anyone have a pair of these for sale or know someone who does?  I'd like a pair if possible.
This is a poor way to update the lug pattern.  A 5-lug swap nets better geometry, stronger wheel bearings, larger brakes and a wider array of replacement items like rotors, pads, calipers, etc.
If that's too large a project, redrilling the hubs for a 6x5.5" lug pattern gets you bolt on wheels that can be found anywhere, in any size.
  • 3 months later...
That's fine and dandy if you can find xt6 parts.
You don't NEED XT6 parts these days.  The front end can use EJ parts and there are a couple sources for reproduction XT6 rear hubs.  Wheel adapters and wheel spacers are TRASH.
Where can you get the XT6 hubs from?
  • 2 years later...
Hi all, New on this LOL
Have 93 JDM CARB SUBARU GL(LEONE-LOYALE) EA71 5MT 4x2 WAGON with OEM wheels (4x140) and what to adapt /convert to 100 or 114 mm. It doesn't matter if 4 or 5 lug nuts.
Any easy non expensive solution?
Note: I live in Costa Rica so it's incredibly difficult to find car yards with or spare parts
Thanks!!
Edited by Costa_Rica_Mike
Adding info
Thanks!!
paging @Loyale 2.7 Turbo , he is in Honduras but may have a suggestion.
Welcome fellow from Costa-Rica,
Greetings from Honduras...
On 4/4/2023 at 2:11 PM, Costa_Rica_Mike said:
... I live in Costa Rica so it's incredibly difficult to find car yards with or spare parts ...
...The same thing here.
Yes, you can see how I drive my Subaru "BumbleBeast"
with a Redrilled 114.3 Pattern, since the 1990's Decade:
~► https://www.ultimatesubaru.org/forum/topic/174295-reverting-6-lug-to-4x140-then-adapter-to-4x100/?do=findComment&comment=1441832
Kind Regards.
