ausmattw Posted April 25, 2016 Share Posted April 25, 2016 I've been out there drumming up business on the Brumby facebook page. The itch is getting strong. Keep up the great work! 1 Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted May 18, 2016 Share Posted May 18, 2016 Dyfol, updates!!! Where are we up to!? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 19, 2016 Share Posted May 19, 2016 Still very interested in a pair. Hope this is still in the works. Quote Link to comment Share on other sites More sharing options...
Bantum Posted May 19, 2016 Share Posted May 19, 2016 Looing good - I know a few around here are also after these ... Only extra thing that I can think of - Did you check if a brake disc would fit Ok ... ? Keep at it & let us know when they ready ... Ciao, Bantum ... Quote Link to comment Share on other sites More sharing options...
wagonist Posted May 20, 2016 Share Posted May 20, 2016 For the brake disc, that part was copied directly off the "other" copy, and those definitely allowed a brake disc to fit (I used to have a set). Last time I checked with him, he'd gotten a second sample. I think still need third sample to double check the changes (increase wheel locater length mainly). Quote Link to comment Share on other sites More sharing options...
dfoyl Posted May 20, 2016 Author Share Posted May 20, 2016 Still waiting on the "final" version. May even have my Brumby back with the EJ finally all worked out on Monday too, to give the hubs a good testing. It's just taking longer than expected as the guys in the Taiwan office have to put "real" work in front of my "hobby" work I was hoping to have some sets available to take to the US in a few weeks, but that looks unlikely at this stage. Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted July 2, 2016 Share Posted July 2, 2016 Any news on the Hubs Dfoyl? Quote Link to comment Share on other sites More sharing options...
dfoyl Posted July 2, 2016 Author Share Posted July 2, 2016 They have the second set machined up, but lost the axle stub I had previously sent. I mailed up another one to them yesterday so they can do the final check before dispatching. The first set (which are the Crossbred copies and don't have the extended support added in V2) are being tested on my Brumby and have shown no issues. I will switch them out when the new set arrive and these will be offered up FS (probably the next 2 weeks). Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted July 13, 2016 Share Posted July 13, 2016 (edited) Hey Dyfol, Have you had another update yet?Also I have another (Probably dumb question...in reference to this earlier post by Bantum... Also the cross bred one is different again ... ( Found on google ... ) Add Note : They no longer produce this kit, but there are second hand ones to be had ... Note : The drawing is also missing splines for drive shaft, so you will need to make sure it will work with 4WD BRAT / Brumby with spline count to match ... Ciao, Bantum ... In regards to the backing plates pictured in the Cross-Bred Kit...What has he done to the mountings? It kinda looks like hes literally spot-welded a plate over the top of the four bolt mount and re-drilled with a three bolt mount pattern. What have you fellas done to mount your backing plates? Edited July 13, 2016 by ANIM_Hooneru Quote Link to comment Share on other sites More sharing options...
wagonist Posted July 13, 2016 Share Posted July 13, 2016 Have you ever tried to draw splines on CAD? PAINFUL I've seen a pic of a sample, the splines are there And I believe he has a brumby, but the L series & brumbies have the same splines anyway (that's how you can fit RX turbo rear discs on to the earlier models) We've also been working to fix the deficiencies of those hubs. I'm glad I got in early buying one of those kits & only bought the 2 useful parts instead of the rest of the useless rubbish... My suggestion for the backing plate. I've got the adaptors as above. They are good, but not the greatest. I'm got a template so you can mark out the holes. Then I'd suggest welding in a plate (full outside weld plus around the inner hole) which has the proper centre diameter, fill in all the holes with weld, and then redrill them. That would be stronger than using the adaptor anyway. More work however. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted July 15, 2016 Author Share Posted July 15, 2016 On the backing plates, my initial mistake was assuming 2 of the 4 holes would line up - however I found that in fact that doesn't (quite) centre the backing plate to the hub. So yes, the best option is to use an adaptor or create a template and ensure the hub is EXACTLY centered. A ackyard mechanic solution is to elongate the two front-most holes to a point where the centres of the plate AND the hub do align, and THEN drill a third hole to mate up with the third hole on the trailing arm. And I guess weld a washer around the elongated holes to add some accuracy back to the two elongated holes... And I'm still waiting on confirmation the new samples were checked against the stub axle I sent over - next week with luck. Funny story on the splines. When I sent the original Crossbed sample, they had no issue copying the splines off an original axle (the Crossbred has been chewed out) - but they were also trying to copy the splines on the wheel stud holes. I had some strange emails back and forward where they were asking for a sample with good splines for the "small holes", until I realised what they were trying to do. When I said it just needed to be a drilled hole (and gave them a sample stud) it became a lot easier ! Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted July 16, 2016 Share Posted July 16, 2016 Keen/10. I'm heading into work tomorrow to O/H my calipers and knock up these backing plates onto a spare trailing arm I have. Then all I need is your hubs and I will be the happiest bloke out! Quote Link to comment Share on other sites More sharing options...
wagonist Posted July 18, 2016 Share Posted July 18, 2016 I need to reinstall my computer, and it took CAD with it I'm happy to draw up a template. Curious if anyone's got access to a 3D printer? Could make the template out of plastic (or whatever) to accurately mark out the holes for the backing plate. Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted July 20, 2016 Share Posted July 20, 2016 Well...I went to work, Didn't do the calipers, I did however manage to totally mangle my backing plate by drilling two holes perfect, and completely (somehow) messed up the position 3rd one by itself, despite measuring it about 8 times and making up a drilling template. Anyway. I gave up and sent it to the engineer I use and he is going to fill those holes in and spin up a pair of eccentric plates that will double as an ecentric ring to centre the Backing to the Trailing Arm Stub, and as a plate to bolt through the backing plate to the trailing arm. When he is done I will upload some photos of them.So now i've just gotta play the ol' waitin' game for Dyfol to post an update. *Twiddles Thumbs Intesively* Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 20, 2016 Share Posted July 20, 2016 I might have access to one come September, if you don't find one by then. Quote Link to comment Share on other sites More sharing options...
wagonist Posted July 21, 2016 Share Posted July 21, 2016 ANIM_Hooneru, You've seen the adaptor plates above? You know how thick they are? You know which hole is threaded, and why? You know why it's the shape it is? Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted July 21, 2016 Share Posted July 21, 2016 To be honest Wagonist, I have no idea. I have never seen any crossbred gear apart from that particular kit photo that was on his website. Quote Link to comment Share on other sites More sharing options...
wagonist Posted July 21, 2016 Share Posted July 21, 2016 Can I suggest then that you wait until the hubs are ready before doing the backing plate stuff. I'm going to work on getting a template made up from the stuff I've got at home and we'll see how we go from there. Otherwise kind of putting the cart before the horse Just re-reading Dfoyl's answer about the backing plates. I'd never thought of just welding in large washers, although this doesn't solve the problem of the centre hole being too big. As the caliper is mounted to the backing plate (most other manufacturers have them fitted to the cast suspension part) I personally prefer the idea of having the centre hole fully supported and not just on the 3 bolts. Quote Link to comment Share on other sites More sharing options...
ausmattw Posted July 22, 2016 Share Posted July 22, 2016 (edited) If it's of any use to anyone, I have some photos of the x breed kit which show the backing plate in some detail. They were originally on the Ausubaru development thread which I suspect have been lost in the forum crash that happened years back. I've dropped some of them in an album here: hope this is enlightening for those that haven't seen them. I suspect I have some other gems saved away on my HDD. I'll have to spend some time digging around. cheers, Matt Edited July 22, 2016 by ausmattw 1 Quote Link to comment Share on other sites More sharing options...
dfoyl Posted July 22, 2016 Author Share Posted July 22, 2016 Supposed to have the 2nd version hubs end of next week ex-Taiwan...will post them up once in hand... Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 22, 2016 Share Posted July 22, 2016 (edited) I was trying to find the pictures, but it looks like they were all on the old USMB gallery rguyver machined a centering ring that he welded into the center of r180 backing plates so they could then be drilled for the EA mounts. He sold a few, and that's when we realized that the center hole for r160 backing plates is smaller. http://www.ultimatesubaru.org/forum/topic/88398-ea-ej-rear-brake-adapter-ring-at-wcss10/ From that thread: "i have the rings for the brembo swap but after several smaller hub rings i have determined its not worth having a ring for the smaller hole backing plates ( wrx, leg.,) STI use a bigger bearing hub so the hole in the backing plate needs to have a ring so the holes are drilled half in the ring and half on the backing plate , just re drill the 3 holes in the backing plate as needed its not overly important that its exact as long as you are with in the 1/8th that the ring would center it ." Keep in mind, the orientation does not need to be exact (as long as the hardware all clears, and the bleeder on the caliper is still at the highest point), it just needs to be mostly centered. Another interesting thread (with a lot of dead pics...) http://www.ultimatesubaru.org/forum/topic/93607-teaser-rear-ej-brakes-on-ea-car/ But a pretty awesome 2D technical drawing of bolt-on adapter rings similar to the crossbred ones was posted in there: Not a great picture, but here are some r160 EJ backing plates that Suberdave modified (you can see the centering ring welded in the middle: And here's an r180 backing plate modified and bolted to an EA82 trailing arm (also Suberdave's): Edited July 22, 2016 by Numbchux 1 Quote Link to comment Share on other sites More sharing options...
wagonist Posted July 27, 2016 Share Posted July 27, 2016 I'm trying to reproduce in CAD during my lunchbreaks the measurements of the adaptor. When I get it done, I'll post up a pdf so people can at least just print that out as a template. The alignment is reasonably critical at least on the later models as the handbrake cable has trouble getting along the swingarm, particularly if you've got a rear sway bay. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted August 9, 2016 Author Share Posted August 9, 2016 V2 hubs arrived today. Need to do some check/measure this evening, fit the studs, and bolt them up. 6 Quote Link to comment Share on other sites More sharing options...
dfoyl Posted August 12, 2016 Author Share Posted August 12, 2016 Pulled out the old XT6 hub from pass-side, quick photo comparison with the new v2 : 2 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted August 12, 2016 Share Posted August 12, 2016 I would like to be on the waiting list for a pair of these if possible. They look great Quote Link to comment Share on other sites More sharing options...
