March 6, 20179 yr I'm looking for and oil pump for a 86 GL-10 4WD Turbo wagaon. Its got the 1.8L EA82. I cannot get it through any Subaru dealer or parts store and I was hoping someone out there had one or knows somewhere i can get one. The part number is 15010AA001 or 15010AA004.
March 6, 20179 yr I recently bought one from Renton Subaru (dealer) here in washington. But that was for an EA81. I would think EA82's would be easier. Maybe give them a call. Good luck.
March 6, 20179 yr I recently bought one from Renton Subaru (dealer) here in washington. But that was for an EA81. I would think EA82's would be easier. Maybe give them a call. Good luck. GD recently said the EA82 part was discontinued. To the OP: Ebay or Carparts might be a place to get a used one. Might also try the WTB section of the forum. Good luck!
March 6, 20179 yr The EA platform is part way through its slow fade into oblivion. If no new ones turn up, you'll have to take the step down to used parts via craigslist, the classifieds section or car-part.com
March 6, 20179 yr Last one we had (about a year ago) went for $250 to a loyal customer. It was the last one in the country and we were told by Subaru they will not be manufacturing them as they "lost" their supplier of them and Japan said gone forever. Nationwide dealer search turned up nothing. AFAIK the EA81 pump is made by Hitachi and Subaru of Japan still has them produced periodically. I believe the US is out of stock at this moment but they might re-order. The EA81 was made for a lot longer and in larger quantities than the EA82 and was the engine of choice for a lot of other markets besides the US. GD Edited March 6, 20179 yr by GeneralDisorder
March 6, 20179 yr Now that I think about it, I saw an ea82 in the junkyard this weekend, still.had the engine, not sure about the oil pump as I wasn't looking for that, but the lot was Nisqually Auto Wrecking, 360-456-6222
March 6, 20179 yr There's lots of used ones out there but the problem is they are, by and large, NFG at this point. They are aluminium and they pump unfiltered oil so they get chewed up after 100k or so typically. GD
March 7, 20179 yr There's lots of used ones out there but the problem is they are, by and large, NFG at this point. They are aluminium and they pump unfiltered oil so they get chewed up after 100k or so typically. GD NFG??
March 7, 20179 yr I can check AUS stock if you want, we had the EA82 as long as you did and they may still be available here. Price could be insane though.
March 8, 20179 yr I can check AUS stock if you want, we had the EA82 as long as you did and they may still be available here. Price could be insane though. I would buy one from ya if they are still around over there...i got one of the last available ones myself, its going to be real hard to keep these motors going if the pumps are really gone forever.
March 8, 20179 yr According to local dealer all gone here also. And parts store (Repco) advises no-one offers an aftermarket alternative.
March 10, 20179 yr I am glad I put a new one in my Loyale last time I did the seals. I didn't realize at the time they were getting scarce or I'd have stocked up.
March 10, 20179 yr FWIW, I spoke to my Subaru mechanic and he said he usually just replaces the gears rather than the entire pump. He can still get these, and after I advised him on the lack of new stock he has ordered some gear stock. I don't have a price yet.
March 11, 20179 yr There has to be a way to rebuild them or maybe a aftermarket electric pump or something the biggest issue I see is the timing belt pully on the oil pump maybe there's a way to delete the pump pully and use 2 passenger side timing belts so you only need to carry one spare belt hay might even pick up a pony or 2 if there's no load from the oil pump
March 11, 20179 yr Sure with enough machine work you could do a dry sump system. But why? Just use an EJ engine instead. GD
March 12, 20179 yr Try this one: http://www.lovesubaruparts.com/Subaru-Part-Number-Index-p/15010aa004.htm
March 12, 20179 yr That's just a web listing. It's NLA (no longer available). They would simply call you and cancel the order. GD
March 12, 20179 yr I want to hold on to my ea82 till i can aford to go electric with the loyale im in the process of building another high output ea82 i also am building a 2000 ej2.2 for the forester its gona get ported and polished also and all the hop ups i can build in to it im just not sold on the ej in a ea bodied car if im gona go a swapin i want to go electric besides im realy enjoying building and breaking and rebuilding my ea82s so as long as i have parts im gona keep building them ill save the ej motors for my 4 ej bodied rigs
