July 20, 20205 yr I've been trying to find a good replacement for the shift bushing and springs. My shifter has gotten so bad you can't even tell it's in gear anymore. I have to shift it up and down to check!
July 26, 20205 yr On 7/21/2020 at 6:17 AM, Subarule said: Maybe a new flywheel is in your future? Is there something to this statement?
July 26, 20205 yr Let’s read the theory behind this one. As for shifter bushings , I sold what might be my only set to someone not too long ago on eBay. I can’t recall who at the moment but discussion was that they should be copied. FYI you folks should be aware that there is also a seat bushing at the end of the lever where it meets the transmission. And also the seal should be replaced. This info is for the single range on demand 4WD Good luck with it. Edited July 26, 20205 yr by moosens
July 26, 20205 yr 1 hour ago, moosens said: This info is for the single range on demand 4WD Which will be relevant to the dual range too. @Ionstorm66 - are you talking about the bushes in the shifter knuckle or the bush at the base of the lever/stick? 3 hours ago, 573417h said: Is there something to this statement? Who knows? Maybe @Subarule could enlighten us..? 6 minutes ago, Step-a-toe said: Assuming OP is talking EA81 4 speed????? Good point Steptoe, in which case I’d suggest the slot and bolt trick. Worked nice on mine. I recommend a metal lock nut. Nylon just doesn’t cut it with potential oil etc. Cheers Bennie
July 26, 20205 yr Get our your lathe and some bushing bronze. Only way any of that is going to get fixed at this point. All those parts are NLA. GD
July 26, 20205 yr 11 hours ago, 573417h said: Is there something to this statement? Sorry, replied to the wrong post.
July 27, 20205 yr Author If you had the dimensions it would be nothing to get a custom seal shop to make bushings, Ive had them made that way before. I guess ill pull it apart and check them all. Its also a e82 5 speed. The odd thing is up and down is 100% clapped, but left/right only left is clapped. Going into 5th and reverse actually has resistance.
