clutch life expectancy?
Just had to replace the clutch including the fly wheel on a 2005 2.5XT outback wagon with 13.5k miles. Does anyone have an opinion on how long subie clutches last? A friend told me she's done 3 on her car, the first with under 28k on the car. My experience with non subies is they go for at least 100k. Comments?? Please note all drivers of the 2.5 XT are experienced in driving manual transmissions.
I replaced mine at 162K (91 Sports Sedan w/turbo). It was still working ok, but it felt like the pressure plate was getting weak. The old clutch disc looked like it would have gone another several thousand miles.
If you burned up a new clutch and flywheel in less than 14K with normal driving, something is seriously wrong.
Mike
how old are the drivers of the car? :burnout:
Old enough to be your parents:cool:
Mine is still grabbing at 150K miles.
Our 1996 Legacy had the clutch go at 140k. I thought that was premature, but we have pulled a pop-up around some.
Wow, that sux. With the power of the turbo and traction that grips like glue it seems resasonable that the clutch is going to be the weak link. Course Subie's clutches don't have the best feel either. It's hard to be consistant. I got about 140,000 out of mine. 00 OBW
yeah, c&d's long term lgt (05) had an early clutch change (<30k) perhaps this is a problem? my clutch is almost gone at around 130k fwiw...
Typically a short life is 60,000 (new driver) , worst i've heard is 30,000. An exp driver can get over 120,000, more if you have a functioning hill holder. i've gotten 160,000 out of a soobie clutch
13K there is something else going on....
nipper
I agree that either there is another mechanical issue or driving habits are causing it (no offense, I know lots of people that are really hard on clutches).
Most of the ones I've seen have gone at least 100k. Sometimes around 50 or 60 if it's ALL city driving. Even my mom, who slips the clutch for about 30 feet every time she backs out of the driveway, had the clutch in her 97 OBW go for 110k before I preventively replaced it (still had another 10k or so in it when I pulled it out).
My 05 OB XT's clutch still seems good, and it has ~53k on it :rolleyes:
Thanks guys (non gender term). My wife has done most of the driving, me about 500 miles and some done by our son. It just seems that you would have to be really bad to fry the clutch and fly wheel this soon. I hope it doesn't happen again, soon!!
hrmmm ....
You know its really hard to do burouts in a sooby by dropping the clutch..... How ever, i know when i was somebodies son, clutch dropping was all the rage.....
nipper
hrmmm ....
nipper
Nippster's burnt some tires off before :rolleyes:
If was younger and had a 2.5T AWD I would beat the hell out of it. When I was 18ish I was doing ebrake slides and burnouts w/ mom's grand am gt. No turbo, no awd, no stick-shift, just a gas pedal and a handle e-brake. Yea, this was on dry pavement.
180,000 miles on the original clutch in a '95 legacy wagon. its just starting to slip.
97K on my '00 OBW. Not even a hint of slippage yet.
But my 15 yr old son started driving it last month. We'll see what happens:clap::headbang:
I've done 12k miles in a brand new Forester 2.5 XT.
At 31 tender years, I still enjoy using the power available. Even so, I don't let the clutch slip and get hot. Just give it 3500rpm and step off the clutch smartly...screech!
But seriously folks, a 14k clutch failure does sounds suspicious, but if the driver has a tendency to use the clutch pedal as a foot rest, then it is possible to kill a clutch in such a short distance.
(My 2.0 Impreza has lived with me since 40k miles and now has over 100k miles. Original clutch.)
I had to replce mine (2001 Legacy wagon) at ~60k after it started to slip on mountain accents. I had just bought the car used at 50K or something like that. While it is my first standard, it is certainly not my first time driving one.
Kevin
One thing I have always noticed on my 2001 2.5 manual Legacy is what can best be desribed as a burning smell anytime I get out of the car after I have been in stop go traffic. I am assuming this is the clutch? Car has 85,000 miles on it and still appears OK. Is this smell a common feature of Subarus?
burning clutches have a pretty distinct awful smell.
my '05 and '96 legacys have a coolant type smell when you walk past the front of the car.
'96 has a very minor occasional drip of oil on the hot exhaust that burns.
With my old clutch it took some major slipping to develop the smell, but on the replacement which I was told was OEM with all the fixins' it doesn't take nearly as much to make it smell. Almost to the point I think it's not quite right. However (big however) I havn't had any judder with the new clutch for 10K. So it's a little give and take I suppose.
97 OBW, first clutch lasted 70k, then 40k, now 25k on third (ok so far).
three regular drivers, obviously different styles. BUT no other car these three drivers have ever driven (regularly) had such short lives on clutches...
My 99 Forester's first clutch was just starting to slip at about 90,000 miles, this wwas an organic lining clutch and the new replacement is great. About 40,000 miles on this one and it feels fine.
