Documented: The 1970 FF-1 Project car...
After all the shuffling around these past years I think Jesse has my dry sleeve 1400.
Jesse - refresh my memory please.
ctsuba might have one left. wagonsonly - outside chance too.
Non of those 1400 I got from you were dry sleeve. And non of them were good either. Thats why I ended up putting the 1600 in my car.
What did the dry sleeve 1400s come in?
I got one in the coupe, but I have no idea of it's condition or if it's wet or dry.
  • Replies 1.6k
  • Views 330k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
2 port is non sleeved , 4 port is the one we don't want. They put the 2 port into the last Gen I Stage I 4WD wagons and as I know it they also put them in 1976 automatics .
Like I said , been a while since I went through that stuff. Maybe Danny took it and it ended up there with you.
Hmm. One of thoes was a single port 1400. But I thought I had pulled the heads off it and it was a wet sleeve.
The first 2 port EA63 motors were wet sleeve just like the 4 port version. Only those produced after engine # 914674 were dry sleeve like the EA71.
Sux to hear about that Kost. I make trips from Socal to your neck of the woods if you happen to find one down here I'll bring up on a trip for ya. Good luck with everything and don't give up.
Holy Cow!
...I think this motor was scraped at some point and the dealer drilled holes in it to scrap it...
Why they do Drilled those Holes? ... I Don't understand the Point...
That situation Sucks... I Hope that you'll find a Good Replacement but also I Believe that it could be Fixed if you send it to a Shop for an Aluminium Filling Welding / Resurfacing.
Good Luck!
Kind Regards.
If he is right about the block being scrapped... then they drilled the holes because the engine block was not supposed to used again. It's only supposed to used for metal or as a door opener or paperweight, etc. The reason for scrapping could be for legal reasons.
I think you could get the matching cylinders re-sleeved with a steel liner and then run under-sized pistons. The side with the hole could have molten aluminum poured into where the back of the new sleeve sits. Then the rest of the block could be tapped and then threaded with a bolt. :) It's a low-power engine so the solution does not have to be crazy with the relatively low cylinder pressures...
Thanks for your Kind explanation.
So, Kosta; What you Gonna Do? :confused:
Don't Give Up! ... your Project is Amazing and I'm sure that you will Make it Run Great; Either by Fixin' the Block or obtaining another one.
Good Luck!
Kind Regards.
so im curious why do you need to run the same motor ? are you going for complete resto? is is there some mechanical reason you you need to run a 1400
The FF1 needs the dual port heads. Without going back through this thread to find it, from memory the suspension design of the FF1 does not allow for later Subaru engines which have the single exhaust port at the bottom of the heads.
Yes, holes drilled to insure the block was not serviceable because of tax write off (IRS). Unfortunately witnessed such destructive activities while working at a Suburu distributor back in '76. The warehouse guys were known to "dumpster dive" hoping to save parts. A lot of old 360 parts were lost when tax write-offs were taken on unsold parts inventory.
Kosta hope you are finding a way around your setback. I keep looking in the upulits around here. I never know what might pop up.
  • 4 weeks later...
Air cooled motor doesnt sound promising
Cheers Thierry
So, Kosta... How you are gonna Fix the Problem with your Engine's Block? :confused:
No idea.
Was the short block sold as is?
Yes, it was a craigslist sale.
I'd have a new cylinder liner/sleeve installed. But that's me. All the rest of the guts are good?
JB Weld the hole:) I mean, after the sleeve is put in.
Yea, what to do?
Doug
a good machine shop should be able to weld that hole up and then re hone the cylinder shouldnt cost much it would be just like repairing a cracked cylinder head
I don't have the money for that now, and I still haven't disassembled it either.
i know that feeling (just got laid off) just a thought i had
