All Activity
- Past hour
Well did the thing, so kinda pleased with myself, but also bummed.... dismounting went smooth, in italy they dont use salt on roads in winter, so cars here are very rust free, there was nothing frozen. I did have to make a 1/8" U shaped plate to add height to my fork tool as it wasnt tall enough to separate the taper, easy. 10 mins with an angle grinder to make second bigger issue was none of my fault, i mounted the first new ball in the arm, went to feed it into hole in the steering knuckle.... wont go in! Really? Turns out the SKF bodies were machined oversized due to an error in the factory, 38,10mm instead of the 37,95mm it should be! how the hell this can happen is a mystery. Options was to send them back to amazon and wait for new ones, but with the car on stands and the rubber boots destroyed during removal i couldnt go back to the old ones Luckily i have a lathe and been able to take a lick off the diameter and bring it back to dimension, but gee.... what the heck Now for the real bummer - As i was bolting back the torsion bar tie rods, i casually pulled on the bar and heard a knock.... well turns out that the free play making noise was in the tie rods, not the ball joints!!!!! Indeed after lowering the car and driving with the new ball joints, clacking was still there. The old ball joints had no free play to begin with. Ordered new tie rods, changed them in 10 minutes or so without even lifting the car, noise gone. Cant believe i did all the knuckle ball joints work (and SKF agravation) for nothing. So lesson learned, check your stupid little tie rods before changing your ball joints.
- Today
travelvw replied to pontoontodd's topic in Off Road
Nice to see the low range improvements/upgrades about to be put to the test: my favorite of all your upgrades is a proper low range. Keep up the great work. K - Yesterday
88 GL - Distributor not sparking.
88SubGL replied to Yarlissa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The best way is to compare the wiring diagrams for both distributors. Of course, if you don’t know if ‘87 distributor is off a carburetor or fuel injected car, that might make it more difficult. But I don’t know if there was a difference between the two. -
EA82 Cleaning & Assembly Questions
88SubGL replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you’re going to flip the engine, shoot carb cleaner in the holes. It should wash it right out. -
That sounds awesome. What size lift will you run in the cross trek? Should be an interesting and capable vehicle!
Yarlissa replied to Yarlissa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So is there anyway to know what the correct wires on the car that need to match the 87 distributor? If anyone can tell me the 12v, 5v's and ground or a way to test the 87 distributor side? - Last week
Divorced tcase and stock rear diffs/cv axles
SquigSprinter replied to SquigSprinter's topic in Off Road
Aye the welded center diff would be required in my case (this is a 23 Crosstrek with the dr 5mt swapped in, it has the viscous coupling center diff and came with 4.44 final drive stock) If I go with the Samurai tcase I plan to upsized tires to 31s to take advantage of the hi range reduction I know the older stub style cvs tended to explode from too much torque, this would be using newer style Subaru CV axles. I mostly want to avoid getting all of this low gearing in place and then start popping diffs/CV axles. -
Coincidentally when I typed up that post I was using our checklists for notes. There's always plenty to do on all of our cars, some issues more pressing <cough> than others. Don't hold your breath on the 5MT low range, the odds of me making those are extremely low. No way any of these modifications ever "pays for itself" but yes the rear knuckles with bolt on wheel bearings and big front axles and bigger rear brakes are a welcome improvement. B and I were discussing upgrading his drivetrain to 6MT low range/R180/billet rear knuckles over the winter. We have most of the parts and his rear diff has been making noise for over a year now. Spent some time this week on the trans removal. No major obstacles. Trans crossmember was nicely packed with dirt, took a few minutes to clean that out. Just got it out this morning. Missing one of the brass thrust washers in between the planet gears. Didn’t find any chunks of brass so maybe I just didn’t have it in there on assembly? The brass washers that are still there are worn about 1/3 of the way through from the needles. Going to see if I can find some steel washers that size but not before this goes back together. You can see it was breaking the needles inside the gears that were missing the dividing washer. Found a few partial needles in the trans. The parts of the noisy one in the black Outback that were worn/discolored are similar in this one but not as bad. Finally made parts to replace those with a different material/heat treatment, more oil holes, and an added bearing. Makes me wonder if the low range in the black Outback was missing some needles and that was what was really causing the noise. Still haven't removed and fully inspected it. I should have tried locking the center diff to see if that made the noise go away. Pretty sure we tried that in the black Outback and it didn't quiet down though.
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did, even with an adapter and a smaller hose, it helped but there's still gunk at the bottom of the holes. I'm going to try tipping the engine so the cylinders are vertical (and get myself bathed in coolant and oil), using a piece of wire as a pick to dig the gunk out and use a shop vac to help pull the gunk out. I know I'm making it more complicated than it needs to be, but I'd rather think it through rather than rush through. -
You could try using a shop-vac. -
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don’t recall the EA82 having head bolt holes that go into water jackets. I you have it on an engine stand turn the holes to be cleaned upside down and let gravity do its work. You might only need to agitate it with a piece of wire. Then run the thread chaser down each hole again. Or so it on the bench by “whacking” the deck into a soft surface like a newspaper or towel on the bench. Anything that doesn’t come out shouldn’t be a problem. -
So I've been spending the past few nights after work cleaning up my deck surfaces and head bolt holes. I ran a thread chaser down all the head bolt holes and they all cleaned up great, however some of the gunk it scraped off the threads is now at the bottom of the holes. I don't want to use compressed air as I worry some of the holes go into the water jacket and I don't want to blow the gunk into the water jacket. Any tips and tricks here? I thought about using a wood screw to auger the gunk out or using some safety wire as a pick to get the gunk out. I used a small amount of engine oil to help the thread chaser and the gunk is sticking to the oil. Obviously brake clean would help get the oil out but I still worry about the brake clean blowing the gunk into the water jacket. :] -
el_freddo started following Divorced tcase and stock rear diffs/cv axles and Trailing arm spacers
Measure whatever lift block you have on the subframe or above the strut. I believe you can get away with removing half an inch from this measurement and use this to fabricate the new trailing arm mounts. If you can make your own mounts, you have the advantage of making several sizes to see what works best for you and keeping your costs down in the process.
I have not done this and those that did this years ago are most likely long gone from the forum. One of the biggest factors is your driving style and mechanical sympathy. With a dual range gearbox and the dual range divorced transfer case and the addition of 4.44:1 diffs, you could run larger tyres and crawl really slowly - best of both worlds. What vehicle are you putting all of this into? If a vehicle with an AWD, you’ll need to weld the centre diff. Being a 1.44:1 low range it’s either an MY chassis or the sf forester (but I didn’t think you guys got the dual range gearbox from factory in the states).
el_freddo replied to pontoontodd's topic in Off Road
I love your checklist of stuff you worked through, very systematic! Interesting about the low range, you’re probably keen to know what the issue is. I’m keen to see a low range for the 5spd! That redesigned rear knuckle “just paid for itself” (quote from “The Castle”) with that bolt on bearing replacement! I bet the rally crew would be interested in a set of these knuckles! Keep up the good effort! -
Air Struts: Repair, Replace, or Swap?
el_freddo replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Metal zip ties are awesome to use too. Just ensure you get plenty of pressure on the boot before cutting the tag end short. Roll the remaining tag end over the zip tie’s clamping piece. This locks it in somewhat. -
SuspiciousPizza replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A few things when disassembling/assembling axles: Inner joints (transmission side): These have a large diameter metal clip close to the outer edge of the bearing cup. Just use a small flathead screwdriver to get this started and remove it. Take photos of the orientation of the outer bearing retainer, it is unidirectional. Remove the bearing carrier/retainer as an assembly, use your small screwdriver to pry the bearings out (be careful to not scratch the surfaces, use a cheap screwdriver they'll be softer than nice ones), then turn the outer retainer and it'll separate from the inner carrier. Outer joint: These joints have the metal clip I was mentioning above. If this joint wasn't accidentally disassembled when you were putting in the strut then leave it be. They're not supposed to be disassembled but they *technically* can be. Only use molybdenum disulfide grease when assembling the axle. Make sure the axle is clean of grease before regressing and reassembling. Zip ties can work as boot clamps, but I'd recommend actual boot clamps. -
88SubGL replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I love the technical terms used in the illustration. Haha. -
LaMamelle replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks, el_freddo, it truly is the highest quality of art. I was able to move the boot back and take a look at the inside, and it looks like the shaft thing has come apart from the spindle thing. According to the (1988) manual, there is a snap ring that holds it in, somehow? I will have to take the whole thing out and on the table to really see what's going on. I just got a 1986 service manual, so I'll be sure to take a look at that as well and confirm that snap ring was present in the 86 models as well, although I'm sure I'll find out once I take the thing apart. Hopefully when this is all done, I'll actually get back to working on those air struts lol. -
After doing a TON of research: Front Right KYB: 333234 Front Left KYB: 333235 These struts seem to only be available in Australia so you're going to pay out the keister for shipping but luckily for US residents the current exchange rate is quite good. I have one KYB strut on the way from down under so if you want to wait to see if what I actually get is the correct strut, I'll post back here when I get it and let y'all know. I needed a right side strut BAD, I had a spare left Sachs but I couldn't find a right Sachs nor TRW. Hopefully now I'll have a spare set to keep my GL running far longer than the engineers intended. :]
Drove white Outback around town a bit, seemed to be slipping at times. Hadn't realized the auto trans fluid was low, didn't realized it had lost much. Wound up adding three quarts but it is now slightly over full. Back to its normal amount of auto slushiness now I think. Washed it and put the front piece of sheet metal B made and license plate on. I've driven it over 200 miles and about five hours of driving, seems basically back to normal, alignment seems great. Haven't noticed any leaks. Hasn't been starting without using a jump pack so we cleaned up all the battery cable/starter connections. Didn't really help but the lead clamp on the ground post was due for a replacement, cut back those cables and cleaned them up. Eventually got a new AGM battery which seems to be working. Replaced the rear washer pump, old one was leaking. Replaced the RF headlight, one of the bolts had pulled through in the hit. Got a driver's side radiator fan and installed that. Exhaust was rubbing on driveshaft a bit, B had rigged something up that was almost preventing that, I tweaked it a bit and it seems good now but the middle section of the exhaust could definitely use some improvement there plus the cone gasket has been leaking for years because the flange bottoms out. B helped me replace the pitch stopper. The stock plastic one broke in the crash, which I didn't realize until fairly recently. Took some jacking up of the trans and prying to get the new pitch stopper to bolt up. On the plus side that straightened out the trans mount and probably gave us a bit more exhaust to driveshaft clearance. Pulled a vacuum on the AC system, seemed to be leaking a bit. Put a little charge in it and the o ring on the low side of the compressor seemed to be leaking. Replaced that, didn't seem to leak, put the rest of a can in it. Enough to actually run the AC, high side 50, low side slight vacuum, doesn't blow cold. Figure I'll check it in a week or so and see if it's leaked. We're basically past AC season here but it is handy for defrosting the windshield at times. Radiator fan runs with the AC on. We tried pulling the swaybar mounting bracket forward by using a come a long (hand winch) to the Impreza but I don't think it moved. Doesn't seem to hit the tie rod so I guess it's good where it's at. Rear portion of the driveshaft is bent, I'd say 1/8-1/4" (3-6mm). Buckled in the crash maybe? There's a high frequency vibration that's worst at about 50mph, I assume from the driveshaft. Got one on order from a junkyard. We went over some things on the Impreza. The rear wheel bearings had a little bit of play. Slight on the RR, about the amount we start to consider bad on the LR so I replaced that. Much easier with the bolt in wheel bearings. Replaced that CV axle too, inner boot was starting to cut/tear. Old wheel bearing spun freely and sounded bone dry, good thing I replaced it. B tightened down the aluminum bracket for the LF control arm, those bolts were quite loose for some reason. He adjusted the driver's door, hadn't been staying closed firmly again, catch probably just shifted out a bit. He found a leak in the RF tire, seems to be a decent sized stick or something. So I have a few tires to take to Discount sometime for their road hazard warranty. Unfortunately the trans started making a lot of noise Sunday on the way home from a day trip. Made it home fine. Most likely similar low range failure the black Outback had. Going to start transmission removal today. Have some new low range parts made up - different material/heat treat, more oil holes, additional bearing - hopefully will last longer.
LaMamelle changed their profile photo
lrgvanman started following ea81 OIL PAN REMOVAL AND INSTALL HELP
Man you’re nailing the MS-paint images!! -
EA82 lyfe! -
Thanks for the wisdom! What I did exactly was, unbolt the stabilizer from the from the transverse link, and loosen the bolt holing in the link so I could bring it down, I then took out the old air struts and then put the new one in. I couldn't bring the knuckle down low enough that I could slip the strut into the hole of the knuckle from the bottom, but I could bend the knuckle at an angle and then pop the strut into the knuckle (This is after I had loosened the bolt at the knuckle, and sprayed some WD40 to help it slide in). I had done this with the passenger side and it's not having issues, but I am now going to inspect that to make sure it's not about to fall apart. On the passenger side it was loose enough I could use my hands, however on the drivers side, I used my leg since I was close enough to the wall. Below is some MS-Paint art to illustrate my "infinite genius": I think I see what you're saying about disconnecting the joint. Tomorrow I'll take off the boot and see what's going on in there. I am assuming I'll need an extra pin, but we'll see, I'll reach out if I do and I'll gladly pay for it. -
Any SPFI throttle body will work. They were available on DL, GL, GL-10, and Loyales. They're all the same. Granted, just going off the model doesn't always work if there isn't any photos on the listing. For example a GL-10 could be SPFI, MPFI, or MPFI Turbo. There's a ton of overlap with fuel delivery systems on the different models. Vehicles could be optioned with a ton of different bits and bobs so there's really no hard line between different models. Generally the only real difference between the DL, GL, & GL-10 models is interior *broad generality*. If going off photos, the MPFI throttle body looks vastly different. Look for the cylindrical IAC valve on the front of the SPFI throttle body. The part number for the throttle body assembly is 16118AA380 OR 16114AA170. If that helps you on your search at all. :] P.S. look up "Subaru Loyale Throttle Body"
