All Activity
This stream auto-updates
  1. Past hour
  2. Lots of thoughts on going forward. But in general for now to just rehabilitate the carb’d EA82 that’ll be a bit of a project. Not so bad really but these days we see most folks immediately ditch the old power plant and sometimes as needed the drivetrain too. You have the last of the carb’d engines. In 1987 it’s a split year. You’ll find DL wagons and sedans with the carb until a certain production date. Then they’re SPFI. You can swap blocks and blank off the EGR ports in the exhaust should you want to try making it SPFI. Been ages for me since I’ve had that era but we had so many between parts cars and drivers. Pretty much all my stash is gone from that era. I never had any real trouble with the Hitachi in general from the 70s through the last of them. But those last run carbs have more emission crap and can in my opinion be more finicky. Less manageable. But they’re carbs so it’s always a little bit of luck and black magic. lol EA82 engine parts - the timing belts are hard to find or at least the drivers side which is the one that typically craps out. Oil pump. Reseal kits, you can imagine what it’s like now. There is zero support with very little exception. Carl Porter has some NOS from that era. He might see this here or find him on FB with the usual old school Subaru groups. West coast dealers you might get lucky. This era unfortunately comes with the New Subaru World Order when they made lots of threats to the new wave of dealers to scrap outgoing inventory and damage panels, components, etc so nobody could dumpster dive. So the spares left or much harder to come by than the 70s. It’s a sad story but at least parts lived on. History story: when the Subaru finally caught on here the kind folks at SOA headquarters decided that no longer would their cars be dealt out of mom n pop corner garages and such but they’d have to have a large parcel and big $ to invest. So many mom n pop dealerships closed up and we NOT allowed to sell their parts to the new dealers or back to SOA. Seversl large lots of NOS came to the public. I’m still selling off some of mine. But come the 80s it’s corporate control. Hope you enjoyed the read and enjoy that wagon. Took my young family on many vacations and romps in those. Another several paragraphs of stories there at least. Cheers!
  3. They replaced the slave. If they give me the old one, I might investigate rebuilding it and keep it with the other spares I have for the car. With fresh fluid and a bleed, maybe the master will be ok, if not, it's the onley thing left so, I might tackle it myself but really guys, maintenance and repair work is getting to be a challenge for me nowadays.
  4. Yesterday
  5. That's a lot cleaner than any you see here! Good choice for a project. Stuck thermostat also can cause overheating and foaming, but head gasket isn't too bad of a project. The stock carbs aren't terrible, and often can be fixed with just a cleaning, being careful not to tear gaskets. Brake booster and master cylinder are usually reliable; no need to replace them unless you have issues. Try ebay or junkyards for better headlights.
  6. Good morning to everyone on this beautiful Sunday, I'm posting here because this is the first time I've ever purchased a Subaru in my life. I completed the purchase of 2016 Subaru Impreza on Friday, after my 2019 Mitsubishi Mirage G4 ES was totaled on 8/20. I wasn't in the vehicle. It was parked and I was already in bed when I heard the crash, so I went outside only to discover that my car was sitting in the street, plowed into a Mercedes-Benz. I came across the Subaru after two weeks of search and used Cars.com. It came from Emerson, NJ and I drove it home this weekend. I rented a car, one-way rental, and drove the Subaru almost 400 miles over the weekend, back home. I admit, I'm taken with this car. 91K miles, one owner, no accidents, no rust, immaculate interior, except for the boot around the emergency brake that has to be replaced since it's ripped, mostly due to age, but what a car! Jade Green, 2.0L engine, 5 speed manual transmission. It had been sitting on the lot since July 18th because no one wants a car with a manual transmission anymore, but I did, so here we are. Thanks for entry into the forum, Steve
  7. Hello. I apologize if this is the wrong place to post this. I recently acquired this 1986 Subaru GL Wagon AWD/3spd auto. I made an account here a few years back while helping a friend with his '87 Brat. If I'd never worked on that Brat I wouldn't have given this $500 listing the time of day. The car is relatively clean for sitting in field in Odessa, TX exposed for a decade. Some rust under the cowl visible from the engine bay from debris sitting in it. Then some from a failed brake booster or master cylinder that was leaking. I'm technically the second owner since the guy I bought it from didn't register it, tried getting it to run off the fuel tank, failed, and gave up on it. Today I got around to setting up a Home Depot bucket fuel pump setup and ran it straight to the carb. I changed the oil and filter because the filter looked ancient, topped the radiator and reservoir off with some distilled water, and charged up the battery. I was surprised when the car eventually was able to run on it's own at about 1200-1500rpm. The carb was dripping fuel so I didn't want to run it long. The temp gauge climbed up a bit past halfway, so I quickly set some bricks around the tires to test the transmission without rolling away. I was able to roll forward and backward so I called that a success and shut it down. I noticed a burp in the coolant reservoir and some bubbles inside for about a minute after shutoff. I'll do a combustion leak test on it to verify. I'm going to list some major items that will need to be addressed before it even goes on a test drive. Engine - Verify if this engine needs head gaskets. Then go through cooling system and timing belt. Carburetor - Weber swap or try and work on this stock Hitachi Complete braking system refresh - Including the booster, master cylinder, and rubber lines. Transmission Drain/Fill and filter. Some less major items that will need to be addressed. Headlights housings are rusted through and don't work (I guess from filling up with water?) I'd probably try and find some sealed beam DL headlights and grille. CV Axles - All 4 CV boots are leaking and they'll probably fail pretty quickly. Suspension looks original. Door locks don't work and the passenger rear door is stuck shut. Rear hatch struts. left turn signal works with hazards but not stalk. No spare tire. But I have all the hardware that retained it. I think the battle going forward is going to be parts availability. I'm spoiled from working on Toyotas. I remember struggling to even find shocks for my friend's '87 Brat. The automatic transmission is also a downside if it ends up having issues. I've found a number of great write-ups on this forum and some other websites so I have that on my side. Here are some pictures and videos to go with my random assortment of thoughts.
  8. Last week
  9. The socket itself is amazingly good. One of the electrical contacts has a hole for wire to run through it. I re-stripped the wire, threaded it through the hole and it is working for now.
  10. When you say the master cylinder was done - what was done? Replaced or flushed and bled? If replacing I hope they replaced the slave cylinder too. It’s a lot of work for not much more effort. And typically if the master cylinder needs attention the slave will most likely go shortly after…
  11. slave cylinder I had the mechanic do it since it was in for its inspection sticker. pricey, intercooler had to come off. thanks everybody
  12. Belated follow up: I did the battery disconnect thing several times with no effect. I did the key on/engine off and cycle the throttle 3 times slowly with no effect. I took off the cover to check the TPS. I removed ~1/8 slack from both throttle cables. I disconnected the TPS and checked the system voltage and ground connections. I did not check the TPS action since I didn't have time to take off the air box to access it's pins. I noticed when I had the TPS disconnected and ignition on that here was a continuous low buzzing sound going on some where in the engine compartment. I disconnected the battery again, pressed the brake, turned the ignition on and off. After hooking it all back up I found that it had greatly improved. It's like a new car taking off or trying to accelerate into traffic. Not sure exactly what did it, but the only real new thing I did was disconnect the TPS for a while and take the slack out of the cables. I would have thought the cable slack would only cause some initial dead action at the beginning of throttle application. Cruise control engagement is also much quicker and I don't have to hold the throttle set for a few seconds waiting for it to pick up the slack anymore. Hope this helps someone else.
  13. Stop by an auto store and ask them to try reading it with their scanner. If they can, at least you know the wiring is good.
  14. @itb482 - what’s your dizzy doing or not doing that requires it to be replaced? My first thought was to have the cam belts checked to make sure they’re not broken. If the LHS belt is broken your dizzy and cam won’t spin when cranking. I doubt you’ll find a turbo any better than the one you have now. You might be able to adapt a new one from a turbo ATV, they’re probably about the right size. Cheers Bennie
  15. I have a parts guy, we're going to get in contact this weekend (he's busy out of town at the moment) to see when we can meet. I need to get over there asap to pick up an engine while mine out of my GL is being rebuilt (6 months at this point). I know he's got a turbo car, no clue on his prices. If you PM me a list of parts (stuff you'd want for the future?), I'll ask. I know he's got a turbo car sitting there. I also have a turbo cylinder head I'm not going to use since mine is N/A. I just got it for a really good price. If you're interested PM me and lmk. :] P.S. https://turbochargersdirect.com/turbochargers-direct-remanufactured-oem-turbo-for-subaru-gl-xt-rx-and-loyale-1-8l-tur-106018-tdr/?srsltid=AfmBOoqOzF6v587m_TyQszG6yslhtNdmZ1ZJRiWPfLog9jMkZBbPHLPI
  16. Heyo everybody! Recently joined the Subaru clan back in 2023 with a 6mt Crosstrek I got the manual with the goal of drivetrain modifications (CVTs, Eyesight, and other modern Subaru features don't always lend itself well to modifications). I started with a 2 inch lift and changing tires/wheels to 235/75/r15s and have slowly added upgrades from there. Last summer I put in a dual range 5mt with the 1.447 reduction with a torsen LSD in the front diff. The 6mt came with the diffs with the 4.44 final drive, with the dual range lo gearing it gets me a 23:1 crawl ratio Custom fabrication that I've done to upgrade my rig: rear tire swing out, high clearance front bumper, dual range shift lever with a Polaris side-by-side shift cable. Currently upgrade I'm putting in is a Torq locker in the rear diff, I'm curious to see how that helps with traction My long term plan is to get a divorced tcase setup running. I think this will be fun to do on a modern Subaru.
  17. I have a 1982 VW Vanagon with a 2.5 Subaru conversion. Need some help getting my OBD 2 scan tool/Veepeak dongle to connect with the ECU. The van came with a Veepeak OBDCheck BLE and on my phone I am using Car Scanner. Given the van came with the Veepeak dongle, I am presuming that at one time it all worked. The Veepeak dongle does work fine on my 2011 Dodge Ram. I have checked for 12V at pin 16 and ground at pins 4 and 5, all good. I do have an aftermarket radio but I can’t see it connected to any K Line; my voltage at pin 7 is less than 9 V so even if that was the case it would apparently be fine. I have replaced the OBD 2 port with a new one to ensure the pins are connecting well. Would really like to get this working for both diagnostics and dashboard instrumentation. Any thoughts?
  18. Hello all! I have a new to me 1986 GL10 Turbo that I attempt to daily for work. It was working and then it wasn’t (the story of all things great). I work in EMS so my mechanical knowledge is pretty 101 level. it does while driving and then was dead at the key. I check all of the obvious stuff and tried jumping it. No dice. Had it flat bed towed to the shop we take our cars to and they said that the distributor and corresponding parts needs replaced. The mechanic was a former Porsche/Subaru guy so generally what I’d call reliable. the problem is that it’s old and parts are super hard to find. The ones found online didn’t match the ones in the car (rock auto for example). I’ve tried reaching out to a local shop in Salisbury (Higgins) that deal in old Subarus since they often keep old cars on site. They have insisted that they will get to the old cars that might have the part but those cars are buried on their lot and I’ve waited five weeks. I just want my car back and working. It was also suggested to me to start looking for another turbo for replacement. Not critical to the function of the car but would be strongly advised. where can I find these parts? Does this forum have folks who are selling this stuff? I’m sort of at the end of my rope and don’t want to sell a non functioning car that I know would work with the correct part. thanks in advance. point of clarity. My Subaru is at my shop- not Higgins.
  19. I have a 2001 Subaru Forester L trim automatic, last owner put ej253 from 2005 outback. Both are SOHC but new engine is cam actuators (left unplugged as ej251 wiring doesn't have plug) Engine block is ej253 (with cam actuator) and everything else including timing gear is from 2001 forester (ej251) Now i am facing CEL light with P0341. I have checked and done diagnostic as per subaru repair manual. Link to photo and video gallery for reference
  20. I would check fuel pressure regulator if it has fuel in top vacume hose or that hose is loose or cracks. I prefer to use subaru named brands only because subaru cars don't like aftermarket or other brand parts in my experience. After fuel pressure regulator would be fuel rail and injectors. Then maybe bypass fuel filter if its fuel issue. But there must be other signs like at idle, normal speed, top speed response.
  21. 2001 subaru forester with engine swap from 2005 outback and now having P0341. Its well taken care of by its age
  22. I own multiple classics and rarely install extra gauges in any of them. I'll confirm the OEM gauges are operating normally and leave it at that. The KISS principle makes life much easier for me. I don't need to know the exact numbers, only that I'm in a normal range. Engine temperature is all I really monitor closely since I drive my wagon through the Phoenix summers with A/C always cranked to the max. I know from using an infrared gun that 3/4 needle sweep is normal in the summer and about 206F measured at the thermostat housing. In winter, the needle reads about half way and equates to around 190F. For oil pressure, I installed a temporary T with a mechanical gauge at the filter and after a good hot freeway trip with the engine at idle, I still have good pressure. When you have good oil pressure at hot idle, you will always have good oil pressure at any other engine temperature or RPM. Since I have an idiot light for oil pressure, I make sure the bulb is working as I start it each day. If I let the clutch out a little fast and almost kill the engine, I'll see the oil light flicker when the RPM's drop below spec. That's another confirmation that the oil pressure switch is working fine. For fuel pressure, I only check that if I install a new pump. Again, I have installed a temporary port under the hood and confirmed pressure is in spec. After that, I remove the gauge and forget about it.
  23. I wouldn't mind the stock gauges, but they are so vague. My GL has the fancy gauge cluster with voltage, oil pressure, and temp. But I'd like actual values rather than relying on a 35 y/o gauge without values. I actually don't know if my oil pressure gauge works. The P/O had a mechanical gauge installed where the dash clock was and this leaked oil all over the dash wiring harness and he cut into the defrost vent to get the gauge to fit. That really didn't help on a Wisconsin winter morning. I just like numbers for monitoring and diagnostic. :] If I had to choose one gauge to not get, it'd be the fuel pressure.
  24. I'll agree that extra data is fun to work with but constantly monitoring your fuel and coolant pressure in an EA82? I have the ultra basic (no tach) factory instrument package in my 87 DL 5-speed. The coolant temp gauge and the oil pressure idiot light are enough for me and got this wagon to 255K miles so far. Sometimes less is best for simplicity sake.
  25. ISSPRO has them. I'd go all ISSPRO since they're good quality and come with sensors and harnesses. But they cost a pretty penny, thus this discussion before I spend that chunk of change. Plus you can program in custom warning lights and change the backlight colors. :]
  26. I Tee’d my mechanical coolant temp gauge into the heater hose on the outlet from engine hose. Works a treat. Personally I wouldn’t like to Tee into the factory location, moving both sensors away from the direct flow of the coolant wouldn’t be an accurate reading. I’ve not seen a coolant pressure sensor as a standalone aftermarket gauge, but I’m not looking for one either. Many ppl feel comfortable with electric sensors and gauges over the older mechanical equivalents. I’d buy from a reputable brand that you can get some after sale service with if it’s ever needed. Cheers Bennie
  1. Load more activity
