All Activity
- Past hour
- Today
Most are non turbo. How many miles on the block? Leak down and compression tests? Check the PCV valve system for blockage? Seems like a long shot but if you're confident the valves and rings aren't it.... Was it burning oil before you replaced the rings? After you replaced the rings did it burn less, more, the same, or can't tell? When rings were replaced were there any signs suggesting which cylinder was the culprit? Did you replace all the rings? There's only two ways for oil to enter the cylinder: valves and rings. Rings are most common
Great choice, the turbo's with age are highly problematic. Gas turbo's in general are be design more complex and don't age well. The turbo's fail, replacement turbo's often aren't good quality, any overheating or low oil situation quickly plants the seeds for catastrophic block failure. And by this age it's not uncommon for one to see oil or overheating issues at somepoint in the past.
- Yesterday
John in KY - you still on here, I know I just talked to you recently person to person but thought Id reply to this old post. Did this end up being an injector issue or oring issue? I have high oil level and it's also running poorly in a 2008 legacy EJ25. Orings can cause an internal leak into the cylinder? How does that happen? I have orings on hand, but not injectors....
That was what I was thinking about as you described the process.
Hello everyone, I'm back at it again with troubleshooting the TB and the fault code 24 (Duty C). The only progress I made since last posting was that I swapped TCU's. This led to no change at all. I think I'm going to swap out the Duty C solenoid again, even though this one is pretty new. When I did the ohm test at the T4 connector, it was out of range (between pins 4 and 11). I'm assuming that means the Duty C is bad? But there's is a strange thing I notice that I would like some clarification on. So when I probe the FWD fuse socket at passenger firewall (key off and no fuse installed) I get ground on both sides of socket. When I put the key on (no fuse installed) I get ground on one side and 7.9v on the other. When I install a fuse in the socket (key on), I get ground on both sides. Does this seem strange? If so, I was wondering if someone here on the forum can probe their FWD socket for me and see what readings you get? Reason is that it may help me further troubleshoot the Duty C. Another question I had has to do with sending power directly to the Duct C to by-pass the harness in case that's the problem. The schematic shows that the brown wire in the T4 connector is for Duty C. But when I probe that wire, it's ground. I thought that wire should have voltage, since the Duty C gets its ground inside the tail shaft housing. What am I missing here? Thanks guys!
Door Trim Repair
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Last night I managed to repair my grille that most would have looked at and considered a total loss. The deer hit the corner of the grille and shattered it like glass. Luckily my lower valence panel caught almost all the pieces. All you need for this repair is a bottle of THF (a chemical used as a precursor for polymer synthesis) and some applicator bottles with needle tips. The THF will wick to into thin cracks where it then melts the top layer of plastic. After the solvent dries, the molten plastic molds together forming a chemical weld. To better understand and visualize this process, look up how model builders weld their models. It's the exact same process. You could also use this process to repair interior or exterior trim pieces. THF works with most plastics but it does NOT work on polypropylene (PP). Look for the plastic composition molded into the piece you're working on. For polypropylene your best bet is using an adhesion primer along with CA glue (super glue). :] - Last week
Insane video!
Your biggest potential (though unlikey on a car this new) issue will be trying to get the ball joint out of the knuckle. It will all depend on how much rust/salt that thing has seen. The guys out west and down south don't have to worry about that and can pop ball joints all day long. The ball joint just pops out. Up here....sometimes they pop out, sometimes they don't. I've ripped t(metal shards and all) the ball joint shaft right through the actual ball itself which was left rust welded into the knuckle, then you're spending a lot of time chiseling/drilling to get the remnant of the ball joint outer casing separated from the knuckle housing and you'll need to replace the ball joint. Good chance a 2018 isn't that bad and comes right out...but if you ever do experience a rusty ball joint you will curse everyone who says "oh just pop the ball joint out" and realize they often live down south/west or are dealer guys only working on new cars under warranty. Are the current axles bad, these newer axles often run a lot of miles without issues and almost never fail. An aftermarket axle may very well fail before the originals with 200,000 miles. In rust prone areas many of us avoid the ball joint and just undo the lower strut mount bolts to replace an axle. The top bolt impacts camber, so you mark the HEAD (not the nut) of the bolt relative to the knuckle housing and make sure you install it exactly where it was before you did the work. EA81, EA82, ER27's are all front parking brakes, so yeah nothing newer than 1994!
Looking for a driver side rear door shell
SuspiciousPizza replied to SubsPNW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it comes to no other options, my parts guy may have a door. I remember seeing an early 4 door he had. Was fairly clean if I remember, baby blue. He's a bit of a... Collector... So he may be hesitant to let it go. But if you need I can always ask. It may take a bit for me to get it. I'd probably have to buy the whole car since it's in decent condition and he may not want to part it out. :] P.S. I believe the car is actually a first gen. I remember it having an EA63 in it. But he may have something laying around, he gathered up quite a few of these Roos. -
bushytails replied to SubsPNW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do have a door, and I think it's fairly straight, but if I remember right, it's rusted out along the bottom. I'm working 12 hour days until next year, and won't be able to dig it out until then. -
SubsPNW replied to SubsPNW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have done a pretty extensive search on the West Coast here. From San Diego up through Washington State. Lots of later years 86-91 wagons and 4 doors but no 80-84 four doors or wagons with an intact driver side rear door yet. We have a decent offer from the insurance company as we provided comparables, but we really want to save the car if we can. It belongs to my youngest daughter, and she loves the look and driving it. Gen Zer driving a manual shift and having a blast in an 80's sedan. 😀 The issue seems to be there are very few 80-84 cars that are available right now for parts which is good in one sense but we need a door. -
Power Steering Rebuilding
JerWass82 replied to JerWass82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very true. Rubber has a lifespan regardless. I’d bet even NOS boots would be running on borrowed time. I’d recommend trying the beck arnley boots. You can get them off amazing for about $20 a pop. -
SuspiciousPizza replied to JerWass82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used Lemforder 3015501 boots. I just replaced them a month ago so I cannot attest to their durability. They did feel and appear to be of OEM quality. They withstood my manhandling when installing (IYKYK) without cracking or tearing. -
bushytails replied to JerWass82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good used 40 year old boots won't be good much longer... lol. I tried the ones O'Reilly sells, and they cracked almost immediately. The ones when I got a rack rebuilt by Phoenix Rack And Axle lasted six months. Have been once again driving with open boots...
