All Activity
- Past hour
subawu joined the community
- Today
Hey all, as mentioned in a post on FB in the Old school Subaru group or 4x140 or GTFO group that we are absolutely purging our stage two 1977 through 1979 and gen one Brat parts. Pardon the warning shots. But time has come to admit I’m getting old and narrow down the focus of my classics as well as pare down the hoarded stock. Over the years we’ve had numerous parts cars and also bought New Old Stock from aged dealers around 1999-2012 My suggestion to you all would be to take advantage this situation. So to be clear it’s late summer 2025 and we are looking to sell lots of parts for the stage two 1977-79 model cars and Gen One Brat from 1977 through 1981. Only Subaru parts I’d trade for would be for 1972/3 Coupe and maybe 74-77 stage one Coupe parts or solid body, and also stage one 1977,1976, and 1975 FOUR WHEEL drive wagons. Thanks for looking. Remember the name for eBay - cashingmystuffin Currently have some tasty items up and lots more to come. Enjoy !
'79 Brat EJ22 Retrofit Build Thread
moosens replied to mka's topic in Historic Subaru Forum: 50's thru 70's
The old “how do you eat an elephant?” dilemma. One bite at a time. -
mka replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Thanks for the check-in and the compliments, all. In addition to the busted leg, the absurd heat of where I live and some other personal life stuff has held me up more than anticipated. Other paying work also got delayed as a result of the bum leg, so this took a backseat for a bit out of necessity. That being said I'm out of the boot now and I am the proud new owner of a higher-clearance jack I got on sale recently - so I'm hoping to get a couple early-morning sessions in on the rear subframe here in the next week or so. Progress will also likely speed up again around October when temperatures generally start to come down a little and I can do driveway fabrication without cooking myself. Anyways, long story short, I'm dipping back into it - updates of more significance soon. - Yesterday
Takes about 3 gallons for a full flush this way.
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
Drain Pull the trans coolant line and put on temp lines into a drain jug. 1- Fill Trans 2- Start it up and let the trans pump all the old fluid out the line you put on the trans coolant into a gallon jug. 3- When the drain jug is 3/4 full - Turn car off. Repeat 1-3 until the fluid is nice and clean. Put the trans radiator coolant lines back on and start it up. Fill to full COLD. Test drive, check fluid Full to HOT.
- 7 replies
- 1
- dexron iii
- outback
(and 1 more)
Tagged with:
- Last week
Huge thanks to @2brat82 for shipping me a set of rear hatch struts so that I could use the brackets off of them to complete the hatch replacements.
Went to the local dealer. The parts guy said use HP. When I questioned that he went and asked the main mechanic and he said use dex/merc. I guess I will either use Valvoline maxlife or the HP. I use the Amsoil products but their ATF is just so expensive and you need like 12 qts to do a complete change.
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
Well, it's more complicated than I implied. The current part number, 11044AA610, is steel as far as I can tell. There are 3 older part numbers that were replaced by the 610, I am much less clear what the material of those were, either from my memory or service manuals. So the factory installed ones might have been a different material.
mahoganyman_57 joined the community
I definitely considered buying a different H6 Outback and swapping the suspension over. Overall this seemed like less work and definitely less cost. Exactly. Yes, my brother bought this one for me in California, and while it's no longer completely rust free it's still pretty solid. Figure at least $3000 including transportation to replace it. Which makes these things a bargain really. And this car is relatively stock aside from the suspension and bumper/skidplate. But it's still cheaper to fix this one. Plus either way we'd wind up refabbing the skidplate and radiator/bumper support or whatever you want to call it. And I've been thinking for years about fabricating a better lower radiator support for these cars from scratch rather than just adding a piece of tubing underneath. On that topic. We started by getting the radiator support back into place so the hood would latch and line up. Then remounted the bumper so it sat level and square with the lights and fenders. 2" square tube going back at least a foot into the stock "frame rail" with a mounting flange for the bumper welded on the end. This is the only part that will be permanently welded on the car. Below you can see the square tube is only tack welded to one side of the frame rail. When we get things more solidly mounted the plan is to hammer at least two more sides of the frame rail flush with that tube and weld them also. Then B cut and fit a piece of 3" square 1/8" wall tube where the stock lower radiator support was. Since this is about 3x as thick as the stock radiator support and significantly larger section, plus an actual piece of tubing rather than a couple of stampings folded/spot welded together, I think it's easily 10x as strong as stock. Not that what it's attached to will be very strong. We will pick up about 1" of ground clearance/approach angle. Also by chance the stock radiator mounts we unbolted should line up great by just welding them to the backside of that tube. Got the main part of the engine skidpan straightened back out, bolted back up, and replaced some tubes. Have tubes almost fit from the big square tube radiator support to the bumper beam. Need to figure out exactly how I'm going to make the tabs and piece of sheet metal there. I know what I want just need to figure out the most efficient order of fitting/assembly. Then we still need to add a few more tubes but it's coming together. Ordered some new hoses and tubes for the oil cooler.
Numbchux replied to pontoontodd's topic in Off Road
It is here, too. But getting another rust free shell is no small feat in this part of the world. IIRC he travelled to California for this one. Not to mention the modifications already done to this one. That looks pretty nasty, but all ahead of the suspension mounts, so it doesn't need to be mm perfect. -
The 4EATs are not picky about what fluid to use. You can buy Dex III, it's usually labeled Dex/Merc (Dexron/Mercon). That's the cheap conventional stuff, works great, meets all the specifications. I buy 2.5g house brand jugs of it at Fleet Farm. All Dexrons are backwards compatible. So you can use those. Most will be synthetic (certainly anything you can find new) Subaru officially superseded to HP. So anything that meets Subaru HP will also work. This will all be synthetic. This is what we carry and use (I work at a Subaru dealership) I honestly think the change to HP was just to use a synthetic so they can extend suggested service intervals and/or in an attempt to reduce resistance for better mileage. I have not found any part or seal that changed part number when they switched to the HP. If I had a newer 4EAT, I'd dump conventional dex/merc in it.
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
You mean dexron VI? IV & V apparently don't exist. Most word is the VI is not the same as III and often doesn't work well in older trannys, even though the claims say it is backwards compatible.
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
el_freddo started following 2003 Outback H6 time for tranny flush but what fluid?
Check out dextron IV - the description will no doubt tell you that it’s suitable for vehicles where dextron III is recommended/required. Cheers Bennie
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
dburton97128 started following 2003 Outback H6 time for tranny flush but what fluid?
Manual calls for Dexron III, but since that is no more what is best to use? I see so much conflicting and indeterminate information. Subaru HP? Valvoline Maxlife? Dexron VI? Aisin T-IV? Has Subaru issued any kind of definitive recommendation? Thanks.
- 7 replies
- dexron iii
- outback
(and 1 more)
Tagged with:
I checked the troubleshooting table in the FSM for "Engine stalls after initial combustion". All the following are what it says for the fuel injector: Poor contact at terminal (could be at the injector connector itself, an issue with the wiring in the harness, poor connection at the wiring harness connectors (large black connectors near the driver side strut mount), or poor connection at the ECU. Performance characteristics unusual (maybe the mesh "birdcage" on the injector is dirty or it's sticking.) (To check if it's sticking, place the business-end of a screwdriver on the metal body of the injector and put the handle on your ear. Put voltage to the injector BRIEFLY LESS THAN A SECOND and listen for the "click-click". One click for power on, one for power off.) Clogged filter. I'd check the injector, mate. You've got a good pump, lines are clear, new filter, good regulator. Really the only other component in that fuel circuit is the injector. Maybe the mesh birdcage sieve is dirty? Either that or the injector is borked? Injector resistance should be between 0.5-2ohm (measured on the connector on the injector). If the injector tests okay and is clean on the sieve/not sticking, check the engine harness for damaged wires or poor terminal contact. (I doubt it's a contact since squeezing hose has nothing to do with electrons) :]
I believe my model only has one fuel filter in the engine bay which I swapped out. I blew out the hoses with compressed air and reconnected. Didn't seem to make any difference. Out of curiosity, I pinched the outlet hose on the pressure regulator with my pressure gauge still attached (in line after the filter but before the regulator) and was able to get a reading of 40psi. With this in mind, could there be an issue with the fuel injector being stuck partially open and not allowing enough pressure to build for a correct psi reading in front of the regulator?
- Earlier
Did you check that fuel filter down near the fuel pump? Too bad you had to go buy that pump but it'll give you more peace of mind in the future. Plus you can keep your old one in the car as a spare if you're ever in the situation you need it. If you do have to replace any rubber fuel hoses, Codan makes hoses that are the right diameter and are very good quality. Check out Volksbolts, they've got a good write up on fuel hoses. If you ever need some reading material.
el_freddo replied to pontoontodd's topic in Off Road
Geez, that front end took a fair hit! It’s worse than I thought it was going to be. I love how you look at the issue and go “we got this” and get stuck into it. Over here that would be a write off for a regular vehicle unless it was something special to its owner and they either know how to fix it or know someone that does and is willing to do the work. Looking forward to the detailed pics of the work done! Cheers Bennie
