Everything posted by edrach
Service Manuals
edrach replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.books4cars.com
Anyone got a donor xt and cutting skills??
There is a white one at the Everett Pull a Part. Rear fenders looked just fine. You'll need a portable sawzall to get it off though; they don't allow cutting torches into the yard.
Need counsel of Subaru Masters...
Do a search of the archives. ASV from the dealer is in the $75 price range if I remember correctly. You can buy the reed switch portion which is the working part for $18 and just replace that portion alone for the repair. I remember that being written up quite well but can't remember the part numbers.
Emmisions nightmare!!!
I can't tell what can stay and what can go, but drop me an email if you need to get your car through emissions, legally and with a minimum of cost.
Clock issues?
edrach replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the resistor powers the display but the clock is actually running all the time. So much for the theory about the resistor supplying 5V to the clock.
Clicking Axle: Worry Or Not?
Another vote for www.cvaxles.com. However, they click for a long time. Check the rubber boot it's probably torn; if not, it'll last quite a long time. When my son's roommate lost a front axle, he called and I went out with an old coat hanger and tucked the axle out of the way, put the car in 4WD and drove it home. Fixed it with another junkyard axle.
4spd D/R to 5spd D/R swap
For me the primary difference is that you no longer have to over-rev in third or lug the engine in fourth. With the 5 speed, there is always a gear that will put you into the power band of the engine. Additionally, on the highway, 500 rpm less at cruising speed is nice too. I'd never go back if I can avoid it.
Guess what I got?
That is pretty; where did you get him? He looks like a Red Baron to me.
New blue 84 wagon to add to the family!
I have a soft spot for blue wagons and Brats also.
FOR SALE: Cargo Bin
edrach replied to brew333's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou've got mail.
Need YOUR input as a Soob owner!
Discount on Redline or Castrol oil by the case. I've been there before and only don't go more often since the stock seems limited for Subaru stuff. However, Zap is correct in their good follow-up on weber stuff. Interesting turn of events since I tried to get a donation from them for last year's event; I guess I just didn't talk to the right person. They did let me leave our flyers on their counter.
does anybody know anything about these tires
edrach replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey have a DOT rating of "A" for traction and temperature which is quite good. A 200 for treadwear means they won't last very long. You might have to buy two sets to get any meaningfull longevity out of them.
new member- car trouble
edrach replied to badgah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBrian, welcome to the Board. I'm sure someone here could point you in the right direction with your ABS problem. I would suggest you re-post this on the New Generation forum. You'll likely get more response there. Sorry I couldn't help you with the actual problem; altho I have an older Legacy with ABS I don't have enough experience with that.
A clutch kit for sale on Ebay!!! Hurry ends soon
This sounds like the smaller 2WD only clutch assembly. Not really such a good deal if you have 4WD.
rear disc brakes to Brat?
Seattle PAP's--about $60.
Who sold this GL-10 Turbo sedan?
Oddcomp, check with qman on the roof; I'll even bring down the wheel to his house if you come up for the roof.
Thanks for all the replies. This is more entertaining than I thought. I'll give you a call tonight, Ken.
Who sold this '86 GL-10 Turbo sedan to jrach? Car was originally qman's who sold it to you (located near Shoreline, WA) and then was parted out and finally the carcass was sold to jrach sometime in 2003. Car needs to be crushed but we need a title; I'm trying to track down the last owner of record so we can generate a certificate in lieu of title. Contact me at edrach@spamcop.net. Thanks.
Clock issues?
edrach replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, a voltage regulator to dissipate that much current would not have fit on the board. Even the resistor they used is not doing the job since it apparently burns out very consistently. A clear case of poor design.
Automatic Seat Belt in '91 Legacy
edrach replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Josh. I'll do the search again later--first try came up with > 750 matches. No time to do this right now.
Heater Resistor fix
If I remember correctly, Bill Putney published a schematic diagram of the resistor pack. It should be in the archives somewhere. If not I can figure it out and I'll get it posted.
Seattle Group Meet
If this discussion gets any longer, it'll be Daylight Savings Time again and there'll be plenty of light!
Clock issues?
edrach replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPalouse Rider, you give me too much credit. I just suggested that it looked like a resister was missing on the board--two large solder pads with nothing between them--a pretty lucky guess as it turned out. You did the hard work of finding a working value and getting it in there. Interesting that it appears to be a pretty common failure.
Where is the fabeled Edrach Axle Tutorial?
Inner bolt from the frame is what I meant. Sorry. There's lots of ways to do this as the posts indicate. Cool idea using a steel wire to pull the axle through; very clever.
Heater Resistor fix
Nice piece of work. Do you remember the resistor values you used. It's been so long that I didn't think anyone could find those old posts. I haven't even tried to look for them recently.
