Everything posted by DaveT
No air from defroster
What model car?
HHO generator
I have not seen one comment stating that using hydrogen as a fuel wouldn't power a car..
HHO generator
There is also a chance that mixing the output of the device with the conventional consumption of gasoline that it changes the air fuel ratio or some other aspect. That is entirely different than what is in the video.
HHO generator
First video. I did not take long until the guys talking about powering an engine with water speaking scientific gobledy gook. The small "cells" that were shown do not come close to generating enough Hydrogen & Oxygen to power a car sized engine. Think about your engine displacement. 1.8 L of air gets pumped through it every 2 revolutions at full power. That is a BIG number of CFM. That is how much uncompressed Hydrogen & Oxygen you would need to supply it.
HHO generator
- 92 Loyale Battled a Camry :(
That might explain the single v belt.- 92 Loyale Battled a Camry :(
Mine all use 2 v belts - 4wd, power steering, A/C. All ea82 engines have 2 timing belts.- 92 Loyale Battled a Camry :(
That's not long ago, unless you drove it an awful lot... The V belts? if they have cracks or worse, replace them. The timing belts, every 50K miles to be safe. 40K really safe. All 3 Idlers at the same time. Way back when they cost $90.00 each, I made custom ones with replaceable bearings. So I just replace the bearings, for like $9.00 each.- 92 Loyale Battled a Camry :(
I just looked at one of my spare engines. You might be able to do it without removing them - But you have to remove the idler / tensioner for the belt that goes under the pump. If you put the engine in the position for installing that belt before you loosen it, and pop it off the pulley, you should be able to get it back on correctly. I just never bothered, having done the belts countless times, it doesn't bother me. How many miles are on them?- 1993 Loyale differential oil change
I think gear lube rated for LSD just has some additive / characteristic for the friction / clutch parts that make the LSD function. I don't know of a reason that it would hurt a non-LSD diff.- 90 loyale wagon 3peed auto RPM's seem really high
To replace the water pump, you have to remove the plastic covers and the timing belts. I would replace the pump also. If stuff got hit that hard, and the fan won't come off, something's messed up with it. Who knows if the seals and or bearings are still good.- 1993 Loyale differential oil change
I've been using Amsoil Synthetic gear lube in them since 1988.- 90 loyale wagon 3peed auto RPM's seem really high
- Coolant leak on a ea82
Could be intake manifold gaskets leaking into the intake. Also the gasket under the throttle body. It is odd in my experience that the recovery bottle level is dropping - unless you wait until the engine is cold- hate tight sump plugs ? try this ....
It may also stop the sensor from working as it is an insulator. Just be sure to check.- Mysterious Coolant leak from (under?) EA81 intake manifold
The easiest way I have removed the intake manifold bolts is to run the car until it's up to normal operating temperature. Then shut down. Immediately remove the bolts. If it can't / won't run, heat gun and a space heater to cause the same effect.- HHO generator
I'm curious to see what you find. I've read about this stuff various times over the years. I have a big electronics & science background, and fall more in the 2nd group. Most of the sites I've read about it, turn out to be someone trying to sell stuff, or someone that doesn't really know what they are talking about. For those who are running some variant of this, I'm not questioning that something you have done has made a difference in MPG, but why it's different.- Crushed heater core tubes
I recently bought a 1993 Loyale. I've had to do a bunch of work to get it ready for daily driver use. Among other things, I discovered that the heater core tubes were crushed by someone overtightening the hose clamps. I did not want to remove the core and replace it with one of my spares. I used my 1/4" drive deep sockets to un crush them. Put a little grease on the biggest one that wuldn';t slip right in, and tapped it in. Had to use channel lock pliers to pull it out. Turning the socket with the ratchet simultaneously helps. Once I got to where the next bigger was too big, I used brass shim stock to gradually get as far as possible to original ID. Place the shim in the pipe, then start the socket. I decided that since the tubes had already been crushed, it would be good to reinforce them. I found that sweat couplings for 1/2" refrigeration tubing are very close to the correct size. I had to grind them down on my belt sander about .010. Put a little grease on, the tap into the tube. Took a while, this is a job for patience and being careful, but still far less time than pulling the dash.- I've got a problem
Then use the spring compressor to safely unload the makeshift clamp / strap. Be very careful, lots of stored energy there.- I've got a problem
If my strut spring compressor wouldn't fit in there, I'd put the cat on the ground, use chain or straps to tie the coils in place. At least on 2 sides. Then jack it up. Depending on how much wiggle room to get it out then remove things mentioned in the post above.- Loyale 3AT Leaks Gear Oil
If you remove the a,le, you can see the seal. I have not done one of those yet... but I have replaced seals in similar situations. I've done it 2 ways. Either drill or punch a small hole in the seal. Screw a sheet metal screw into the hole. Pry on screw to pop the seal out. If you choose drilling, be careful about chips and slipping too far in when it breaks through. If you choose punch, be wary of pushing the seal into the case. It likely will only move in until it hits the bearing, but I am not sure of the design of this part of the 3AT.- Another heater question?
The lowest speed resistor often fails on it's own. Anything that would block airflow over the resistors would accelerate their failure.- Any of these have airbags?
I've thought about adding a 5 point also. Be curious to know how it shifts the risks.- How Does Subaru 4X4 Work?
