Everything posted by DaveT
What does it take to find that “perfect for you” Subaru?
For me... I'm sticking with SPFI EA82 / loyale / GL 3AT 4WD wagons. I've been running them for 20+ years. For as long as I can keep them running, & ahead of rust. They do what I need. They cost little. I know the quirks to keep them going. I can fit bigger things into them than any of the newer models I've attempted. They are in the zone of no longer having to be emission tested here. So the "perfect" one to start with, is a SPFI 3AT 4WD Wagon, with no rust. Everything else, I can fix, no problem. Don't care about the miles. Don't care if it runs. I'd drive a stick, except 2 things: Operating the clutch bothers my knee. Wife can't drive stick, and it her car is being repaired, she can use mine.
My Exhaust project
Wow, thanks everyone! I used my [killed by rust] 1990 as a template. So the "bottom" side is pretty wrecked. I used a tire & the rear seat to pad it. It worked the first time, but the second, something hit wrong and broke the glass. Oh well. The front pieces are 1-3/4" pipe. From the Y back is all 2". Mostly because I could only find 2" and bigger flanges pre made. I might do mufflers in the next year or so. I was thinking of cutting an old one open to copy it - but make the holes slightly bigger. I did the "hot rod" muffler thing years ago, and it was fun - except on long drives... I did think I could make a stainless valve to go from normal / quiet to obnoxious... Sound... It doesn't leak. It does have a slightly different sound. It seems to wind up a little higher & smoother at the top of the tach. than the old aftermarket & original pipes I had on there. [the cats were hollow on those old pipes] I would have to find someone to cut the engine flanges. They are 3/8" thick. There is a shop locally that would make this kind of thing for any car. For about $1500.00. I think I remember them saying they would make me 2 for about $1000.00 each. The jigs were made from unistrut and various clamps. They would have to be re made. Once I was done with the Y, I needed the parts to do the mid pipe. I can ask around, see what I can find out about making a few.
My Exhaust project
I've been away from the forum for a while... I built a couple stainless steel exhaust systems: http://home.comcast.net/~davidtief/exhaust.html
loyale Ypipe?
The thing in the mid pipe is a second cat, not a resonator...
Loyale stalling at idle, poor idle. HELP PLEASE!
Try moving the harness more. I had a wire fail in the engine harness on one of my cars some years ago. I eventually found it by using an ohm meter while flexing the harness to narrow down where the break was.
Whats broke on your subaru lately.
The 4WD button is now momentary
Could this be the End of my 2.7 Project? :(
I'm sorry to hear this. Glad of no serious injuries. Annoyed by government crap making it worse. Yep, it might be fixable.
A little exhaust project.... The car in the pic is just for fitting. The system is going on my drivable cars.
ac to air compressor conv.
Yes, you need to provide oil to the input. Probably want an oil separator after the output. The output can run near 300PSI when running as an A/C compressor, so a regulator and a high limit switch to disengage the clutch it would be a good idea!
3at carb or spfi
I've got an carb'ed 86 3AT in an 87 SPFI. Before that it was in an 88 SPFI. Nothing other than bolting it in.
Evaporator Core Woes '82 Brat
That looks like a condenser core (the one in front of the radiator). The evaporator is up under the dashboard.
2000 Legacy stalls when clutch is depressed
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, we checked a few things tonight. Timing belt looks ok, the 2 cam pulley marks line up. Couldn't get to the Crank mark in the alotted time.., so I suppose it's not a complete check. There is only 1 switch on the clutch pedal, and it is the starter lockout, and works for that. We are pretty much stuck at this point... Short of getting an identical parts car, and swapping things...
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA few more notes: Idling in first gear, on flat road / driveway: cold, stalls out. Warmed up, rough at times, but doesn't stall. Traveling about 40MPH: Cold, let clutch out or slip shifter out of gear without clutch, dies. Smoothly to zero RPM. Warm, not as often, only sometimes. Sometimes, RPM drops smoothly to about 1000, then hesitates, drops to <500. & dies.
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi all, Thanks for the help so far. I've driven the car in question a few times now. When it's cold, the engine dies at idle. 400' from the garage to street, dies. 2 miles (down hill mostly) to the on ramp, dies. Restarted just by letting the clutch back out that time. After it's warm, it just idles roughly. This behavior is pretty consistent. The clutch isn't hanging up. We will have to check the switches mentioned above, and the timing belt.
Yes, The hood is painted! Why? Because I have discoverded the thrill of doing this: So far, it's only the hood... I can't decide what to do to the sides...
01 forester 2.5 stumble
DaveT replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX#2 & #4 changed out. Seems to have fixed the problem. I had to be very careful removing the plugs, to get them freed up. Turn a little CCW, then CW, for the first revolution or 2. Next time, I'll have to remove them w/ the engine warmed up. No fun to work on that way, but I've found almost any threaded part will come out easier with the engine hot.
DaveT replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the #1 & #3 plugs & wires changed out, it runs much better now. The old plugs had about .070 gaps! The only reason I haven't got the other 2 yet is time. It really is annoying that they are so buried. 2 & 4 get done this weekend.
DaveT replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel & air filters had no effect, didn't really expect them to. Plugs & wires ordered. Will Update in a day or 2.
Hi all, Our 2001 2.5L automatic forester has a problem. Starts & idles normally. Usually runs (cruises) normal. When "hitting the gas" to get going, the engine stumbles, then "kicks in". Low RPM + open throttle it doesn't like. Once the RPMs get up, it smooths out, seems normal. When driving normally with the auto transmission, each time it upshifts, dropping the RPMs down into the stumbling, until it revs up again. It seems worse when cold. When I pulled back into the driveway, it more does a little skip than a stumble when I tap the gas (in neutral). I read the codes, all I get is 0420 (slow cat / response) (very old news, never could get rid of that one, I'm not buying all oem parts for that, too many $). It's been running fine that way for years. I also have a new code 0303 cylinder #3 misfire. Any ideas? I'll have to do the usual plugs & wires, filters thing - probably time for them anyway. Thanks, Dave
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe connected a vacume gauge to the intake this evening. It read about 16-17. It varied with the roughness. The engine idles rough. Not like one cylender is always skipping, more randomly. And it was warmed up / operating temp. Sometimes smooths out a bit. A code reader showed 0301 & 0304 - missfires on cylender 1 & 4. Didn't find any bad vacuum lines. Cleaned the PCV valve. Noticed that the Idle air valve had been swapped by the dealer repair attempts, which made no difference. I'm surprised by the combo of shotgunning / guessing they did and the nerve to keep charging for all of their guesses! I'm glad I don't pay anyone to fix my cars! But I specialize in the older gens, so I need a little help on this newer version. We found the MAF sensor, decided to get whatever gasket / oring they use before removing it to check it. Checked the TPS, it seems to send a signal that varies smoothly with position. It got late, and the absolute reading didn't match what the Haynes and the FSM claim. Not sure what to make of that. If it were way off, I'd expect the ECU to throw a code for it. My ohmmeter read 517 ohms with closed throttle. The plugs were replaced by the dealer, (they would use NGK, no?) but if that is still a high likelyhood, we'll try them next time. Thank you, Dave
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX[quote=2000 Legacy; I think I spent 3 hours doing this 2000 Legacy I've had that happen on forums ocasionally. For long posts, I compose them on my email program, or the like, then copy & past to the forum window.
DaveT replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI may be able to help with those. Are you refering to (temporarily) connecting a vacuum gauge to the intake? I have a laptop based scanner program - and the cable that connects to a 2001 Forester - an OBDII ECU. I never had a Legacy, but by the year, I'm guessing it might be OBDII also. The other mention of the idle control valve sounds like a good thing to check also.
Your Suby Snow Stories Good or Bad
A few nights ago, I was driving back home from a friend's house in my 92 4WD wagon. Crusing along a state road, probably about 50MPH. Nice clear night, a little windy though. I see a little snow up ahead, switch on the 4WD, and find myself in blizzard conditions - can hardly see, 6-8" of unplowed rutted snow on the road! (the wind was drifting the snow across the road from the open field) Foot off gas, dropped the 3AT to 2nd, and lots of steering to stay on the road, until I regained control.
Roof rack picture post
My roof rack: http://home.comcast.net/~davidtief/Subaru/wagon87r1s.JPG
