Everything posted by fnlyfnd
I'm Back!!
fnlyfnd replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgraduating takes priority over anything else. good luck w/ everything
I'm so pissed...another gear oil thread
Well after running mt90 with minimal problems, I changed it because its not good for the diff. Now I am running uncle scottys cocktail but I get a faint whine when acclelerating (most of the time), and 2nd gear is a PIA to get into. Now I am going to change it again, prolly setright's suggestion of valvoline synpower. what do u guys think?? setright do you use this straight? how is it in the cold?
New Car Stereo Install
fnlyfnd replied to nzbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just reread my 1st post. There is nothing inaccurate. I did leave some stuff out, but its totally accurate and relevant/needed
fnlyfnd replied to nzbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRC instructions are way too inacurate you forgot: extend your arm with an open grip. grasp the handle of the phillip head screw driver. close your fist around the handle. Bend your arm at the elbow and retract your arm. Aim your eye sight at the center of the unfortunate screw. Extend the screw driver to fit percisely in the "x" pattern of the screw. Once in, twist your wrist as if you were unscrwing a bottle top. keep this up until the screw is fully protruded. Once the screw is dislodged extend your other arm (don't drop the screw driver) and open your hand. Place your index finger and thumb on each side of the screw. Grasp the screw. Pick up the screw an put it in an important place (your choice). Follow these directions for the second screw. And all others after.... Now back to seriousness.... Just stick a flat head (skinny) screw driver wherever you want to pop out the plastic, make sure there are no screws holding it in. If you break something you can always get another cheap one from ebay or a j-yard. This is how I learned, and have done many installs since (w/o breaking stuff). You're prolly going to have to shift into "1" to pop off the center trim. Once the center is poped off you should be able to pull the center radio trim piece off
new clutch problems
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
oem protenza's.....almost wrecked.
fnlyfnd replied to blatant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon subaruoutback.org they are also shamed upon. I don't like them- my g/f with her 05 leg doesnt like them.
new clutch problems
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits a 96 2.2L. I had a private shop do it.
Beginner Mistakes
fnlyfnd replied to xcracermg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnew oem plug wires, and a fuel filter is super eqasy to do. Its right on the driver strut tower.
Inappropriate charges for a transmission($3000CDN) !!!!
fnlyfnd replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont go to the tranny shp doing burnouts. They'll tell you its your fault. No, the tires aren't supposed to spin with conditions like that, but if u go to them slamming the gas trying to get them to spin they'll say you broke the tranny.
new clutch problems
new cluth, flywheel, and cable (exedy/genuine subaru). I am still shuddering slightly in 1st, and when downshifting w/o rev matching. I am going slow enough to not have to rev match, but the clutch shudders for a couple of seconds, then grabs. What should I do? Does the clutch cable need better adjustment? When I am bringing the clutch up the clutch will shudder when I first hit the spot. Then when the clutch is brought up just a bit further it will engage smoothly. This is why I am thinking better adjustment. ??
96 outback, rear differential?
fnlyfnd replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXauto rear = auto rear (4.44) manual rear = manual rear (4.11)
Synthetic Manual Transmission Oil ?? GL4 vs GL5
fnlyfnd replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat's this "fring of tranny" you speak of??
anyone have any luck with stop-leak
fnlyfnd replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1700 includes new genuine subaru parts and installation: flywheel clutch kit VC gaskets rear and front main seal cam seals oil seperator plate timing belt and tensioner v-belts oil pump oring water pump and thermostat clutch cable timing cover gaskets All new....and heat shields are now tack welded so they dont rattle anymore
99 5MT weirdness
fnlyfnd replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea 5mts are very unique. all are different. do a search on gear oil. check nasioc.com and search for uncle scooty's cocktail (look for the 400pg thread)
fnlyfnd replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just got my car back from the shop '96 2.2L 120k, EVERYTHING was leaking. so ~$1700 and I got a new clutch/flywheel/all seals (besides HG).
Fogging rear windows
fnlyfnd replied to Rallyx38's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust clean them really good on a dry day. Fog-x is the worst stuff ever.
buttons ?
fnlyfnd replied to oskar_subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI havent heard one fo those commericials in a long time....oo yea I don't hear no stinking commericals anymore.
buttons ?
fnlyfnd replied to oskar_subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can call the onstar service via telephone. They can unlock your doors when your locked out.
A friendly reminder to prevent fender rust-out
fnlyfnd replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnother way to clean it out is thru the door jamb. Just open the door and spray into the opening at the front, from inside the door.
I'm home...
fnlyfnd replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX....but the 2006 has 1.1" more ground clearance.
Anybody with a '95 outback
Anybody with a '95 outback please chime in. I want to know how long your bumper is. top ledge- to- bottom. not where it meets up with the grill, but the "face" of it.
speakers
fnlyfnd replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.crutchfield.com
10,000 miles later and I am getting that oh sooooo sweet smell...
fnlyfnd replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sucks man. My cousin just hit about 240k on his '99 taurus and blew a head gasket. He had a severe tick happining. I had no faith, but after putting in some stop leak from autozone, and chaning plugs and oil, and driving for a week - no more tick and no more HG problem. Amazing. (sorry for the run-on)
Oil level: overfill?
fnlyfnd replied to Forester Gump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe crank/pushrods...or something, will sluash around in the overfilled oil. Something like that anyways.
fnlyfnd replied to Forester Gump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOverfill is bad.
