john in KY
7
Everything posted by john in KY
Same car. Everything swaps.
Actually quite a bit.
85 1800cc coil blues
john in KY replied to Dog Town Skater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The next time the engine quits after that 30" run, check how warm the coil is. If the coil is hot to the touch, my guess is you are using the wrong type coil. Coils sort of come in 2 types: high and low impedance. Really can't be swapped. Position of the coil has nothing to do with the problem. As an aside, the coil bracket has to be tightly bolted to the car body as it serves as a ground. -
Bent exhaust valve dropped guide
john in KY replied to 2Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The guide is junk for no other reason than that bent valve moving up and down in it has wallowed it out. Just take the head to a machine shop and have a new guide pressed in. -
Dead wagon, weird symptoms
john in KY replied to SoobieDoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's the timing belt. -
'87 Turbo wagon 5 Speed question.
john in KY replied to markjw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably wrong but always thought the turbo versions came with a 3.70 ratio. -
NEED HELP 86' turbo wont start-code 12
john in KY replied to losingalltouch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you 100% sure you installed the distributor correctly? One tooth off is enough for the engine not to run. -
My 86 GL 4x4 wagon. Not many this green?
john in KY replied to kybishop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Elkton. Down on the KY/TN stateline. 42220. -
Also my favorite color for the wagon. Saw one that color in Ohio many years ago but only the one. Subaru really should bring that color back. -
Ignition problem...what is this part?
john in KY replied to King of Poop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The entire bracket has to be grounded for the part in question to work. No grounded bracket=no spark. -
1990 loyale died and won't restart
john in KY replied to logang1k's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the rotor. May be loose. -
can anybody help me with my first subaru?!?!
john in KY replied to alectheamazing's topic in Subaru Retrofitting
Run from this "deal". You are very close to receiving the hosing of your life. Edit: Too late. Just reread original post and see you now own this car. -
1989 XT - Transmission questions
john in KY replied to loonysalmon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Left side of vehicle is in fact the driver's side. Left/right referenced from the driver's position. -
Check your email.
