Everything posted by torxxx
sharp lookin car... good to see another ak member.. now when i come down to anchorage we'll have to get together and go hit up some trails. Jim creek in the spring would be a blast!
hahahaha.. yours weighs 2700 lbs and you are worried??!?!!? my lifted wagon weighed in at 3500 pounds last year. that was before a spring upgrade. They handle just fine as is in offroad situations. You could be running a 4500 lb jeep or a 8000 lb truck with 1 ton axles. I really dont see why you are worried about weight. Adjust suspension accordingly and go for it. You mentioned a EJ swap, the EJ will have more than enough power to deal with added weight of winches and big tires
*sigh* going to take the plunge into EJ swappageness!
torxxx replied to Caboobaroo's topic in Subaru Retrofitting
Been there done that with a carb'd EA82.... Front Pinion gear had 6 teeth missing, 1st gear was gone, 4 hi gear has 2 teeth missing and 4 low was spun completely bald........ funny thing was I drove it like that for a while... til I found another dual range This was before I put my lift on -
I'm with the guys that are sayin SPFI... sounds WAAAAY easier... and the only time german and japanese go together is world war 2.. as far as cars go, dont mix em
so SPFI on any of the L-series wagons/sedans? I'm tryin to think what you guys call them down there. the legacy is the liberty correct? so any EA series from 94-90 should have SPFI... unless they kept carbs on them in those years.. if they did, I want one!
Oxygen sensor thread size?
torxxx replied to GeneralDisorder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
12x1.0 IIRC. If no one else posts up an answer I will check one at work tommorow for ya -
Eeewww... EA82 rear main seal tear-apart pics
torxxx replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
man I swear you took those pics from my car. it looks identical. problem with mine, its had a slight rod knock for almost a year now. No use in resealing an engine that could die at any time. lol -
any tranny shop should sell the rebuild kits for the AWD. Its not a 800 dollar job. You can do it your self. Remove your y pipe and rear drive line. loosen engine mounts, put a hoist on the engine to hold the engine where it is. go under the car and remove the tranny x-member and the tail shaft will sag down enough that you can get to all the bolts on the tail shaft. take out the bolts, pull off the tail shaft, make sure you unplug the wire going to the selinoid and theres your AWD clutch pack. there should be 6 steel and 6 fiber clutch discs in there. just make sure you have the end rings in the right place and replace the steel and fiber discs in the order they came out of the tail shaft.
Sacrilege? De-turboing a subaru ea82T car...
torxxx replied to kayakertom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dave, why not just run conventional exhaust if he's gonna remove the turbo? I've heard bad things about running a turbo exhaust on a N/A engine. (damn uneven header lengths = no power) -
I've been told the same as snowman, but I have my doubts about the subaru dealer. When I first asked them about the tranny ratios, they said "we only replace parts with new factory parts" sO I said, you know I figured a subaru tranny was a factory part and hung up on them. Do a search, I had a thread about this that I started a few months ago.
Winter Oil
torxxx replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just make sure you keep running synthetic. Once you run synthetic your engine basically becomes addicted to the thinner, smoother oil. Switching to conventional and back to synthetic again will make all your seals in the engine leak. 10w30 synth should be fine for a winter down there. I've ran 15w-40 fleet oil at -50F up here in alaska before. Car wasnt happy, but its still alive. -
Strut Swap in Progress...Need Help
torxxx replied to patkennedy78's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First off, unhook the sway bar link. Use channel locks to twist the strut and use a big pry bar to pry down on the control arm. When you get the old struts off, makes sure to anti-seize the end of the strut that goes into the knuckle. that way next time you gotta work on it, the strut will pop right out -
Alright a guy at work rebuilt a EJ22 Auto tranny for a car I'm working on. Got the tranny put back in the car and went for a test drive. One the snow, no problems but the second you hit dry pavement its getting rear diff bind. It is the matching rear diff to the tranny. I pulled both out of another car and installed in this one. The car drove on dry pavement for a month no problems until after the tranny was rebuilt. The only thing I can think of is the guy left one of the selinoids in the tail shaft unplugged. Would this cause the rear end to want to bind up? I'm not too familiar with the auto trannys so I'm lookin for you new gen guys to give me some advice. thanks in advance.
honda accord springs KICK @SS!
torxxx replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hell yea, it makes frost heaves AWESOME. like a roller coaster. Now just if I could find a little longer travel strut and it'd be ready for some jumping. -
as for the 86-89, I think it actually goes 85-90. Mine may have been off a 90, or I saw a 90 at the yard that had the same springs on it. I got mine off a car with a manual tranny and no air conditioning. I'd hate to see how stiff the automatic with AC springs would be. Best bet for mating the springs and struts is goto napa and buy a new set of sensatrac struts they are like 35 bucks a piece. well worth it because the peice of all-thread that the holds the top cap on, is VERY small on EA82 struts and I wouldnt take the chance of the threads stripping when you let off the spring compressor. -
yes 90-94 legacy rear diffs use stubs in the rear. The biggest problem I've had with my legacy diff is they arent bolt on stubs. they are put in with a snap ring like the front diff. I've yanked mine out a few times when I had the 4 inch lift and accord springs in the rear. I would go for the RX 3.7 LSD unit with the 4.11 ring gear and pinion. that would solve the problems with the stubs yanking out of the diff
Bleeding cooling system on Ej22 swap ea81 turbo car
torxxx replied to ShawnW's topic in Subaru Retrofitting
idea! flip the car on its side drivers side up, open raid cap. -
Calling all Alaska members
torxxx replied to northguy's topic in Meet n' Greet. Your USMB Welcome Center
I got some trails up here we could go down. Its supposed to snow tonite and tomorow, but it hasnt started yet. Other than that, I dont know about trails south of me. -
seems like thats the popular thing to do with soobies noah. I had 3 this week come into my shop with that type of tire mismatch. IDIOTS!
the EA82 series cars use the diagonal braking also, IIRC when I blew out a rear hard line, I pinched it off with vicegrips so I could get home. Still had the opposite side brake in the back and the same side in the front
cleanin up around the shop today and decided to haul off all the burned up tranny's layin around. I was amazed at what my car will haul with the accord front springs in the rear. 1035 pounds in the back, suspension dropped about 2 inches. Probably coulda fit another 400 in there, but decided half a ton was enough weight. I highly recommend doing the spring upgrade.
Hatchers Pass! nah I really dont know. the only time i spend in Hickville (trappers creek) is driving through, and I try to get outta there as fast as I can. Kelly still in Haines? -
Torxxx is available depending on how far he has to drive. remember, it costs me the most for these meets!
