Everything posted by xrturbo
code 420F
xrturbo replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
420 is normally the cat. subarus tolerances with the o2 readings for this are sooooo tight. just when it will start to read a difference in catalyst efficiency it will throw the light. -
about the only way you are gonna be able to tell is an air holds valve. you can hook it up like a compression tester and hook your air hose up and listen for air leaks through the intake and exhaust. i hate to be the one to sh** in your cheerios but the same exact car i tore down on thurs was slightly hit and nothing even came close to touching the cam covers and some how from the impact or something it broke the drivers side exhaust gear. and now the heads are at the machine shop with 4 bent valves.
if you have all of the bolts out of the flywheel/flexplate you should just be able to wiggle it off, if not tap it with a hammer to free it up. the crank bolt just hit with a 22mm on an impact and wiggle the balancer loose, same thing if it is stuck tap it with a hammer. i always just put the tensioners in a vice and pin them, i have done it a million times like that and had no problem. and do not forget to put lock-tite on the crank bolt!!!!!!!!!
My new lego
xrturbo replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
in the 95-99 body style legs the 2.5 dohc motor ran right to 99. the 2.2 switched for 1 year in legs in 99 when it became the phase 2 design (there aren't a whole lot of them out there) -
H6 Swap...
xrturbo replied to BruceyWV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
what about an svx swap? i dont know what you are putting it in but they are cheap, can be found easy, and run forever. -
you stated in the original post they told you it was the condenser, and then you said about the clutch on the condenser..... is it possible you are missunderstanding what they are telling you? and that maybe the noise is a wind whistle through the condenser? the condenser is the radiator looking thing in front of the radiator. not trying to make you look stupid or anything, but it would clear up confusion....
Just wanted to give a heads up to newer subaru owners especially 95 and up legacy's. I work at a shop that we sell, service, and parts subarus and I run the parts end of the business. I am starting to see a huge increase in fuel filler neck sales. What happens is the sheild that is supposed to protect the filler neck traps mud and all kinds of debris and then retains water and rots out the bottom section of the filler neck. My personal remedy for mine was to cut a window in the lower most section of the sheild, but other options would be to remove it. I will post pics when I think to get my car on the lift and take my camera to work. Just with gas prices and everything it would suck to pull up to the pump, start fillin and loose half of what you are putting in all over the place.
remove the caliper, than bracket, remove rotor, where the cable goes in to the rear of the hub there will be a little clip you can pop out with a small flat screwdriver, pull the hold down and return spring off the shoe closest to the rear of the vehicle, when you pull the shoe out you will see the cable hanging on the lever, slide the spring back a little with a needle nose and slip the cable off and pull it from the backing plate. just did my like 1000th one yesterday and it still nice and fresh in the mind:headbang:
