Topics posted by hankosolder2
09 Forester with missing heated seat switch harness!
By hankosolder2, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 5 replies
- 587 views
"07 Forester EJ25 engine in an '09-'10 Forester?
- 2 replies
- 580 views
Drive by wire throttle "tip in" / manual /automatic differences?
- 3 replies
- 742 views
07 Forester, AC stops working after 15-40 minutes on
- 10 replies
- 1290 views
07 forester wiring diagram & locating HVAC components
- 2 replies
- 1227 views
Fuel pump relay & Main relay location '98 OBW
- 9 replies
- 20409 views
Oem coil spring color code 1998 OBW
- 4 replies
- 1039 views
ej22 oil pressure problem
- 8 replies
- 1872 views
07 forester 4EAT> 5mt swap
- 8 replies
- 947 views
07 Forester Trans issues / ATF type/color
- 13 replies
- 1901 views
Possible to set OBD II readiness monitors while car is in the air?
- 2 replies
- 357 views
Need wiring diagram 1995 legacy
- 4 replies
- 4593 views
Compromise snow tire size OBW & Legacy
- 8 replies
- 745 views
Remove driveshaft to solve torque bind? 02 Legacy 4eat 1 2
- 29 replies
- 4191 views
Converting ej22 from HLA to manual adj lifters/ frankenmotor
- 11 replies
- 2733 views
Header wrap in lieu of heat shields?
- 1 reply
- 609 views
Part number for Vent Solenoid valve?
- 6 replies
- 3835 views
'71 FF1 on craigslist NW indiana
By hankosolder2, in Historic Subaru Marketplace-for 50s-70's parts only all others use other marketplaces
- 3 replies
- 2285 views
Setting readiness monitors 1998 Legacy- drive cycle tips?
- 9 replies
- 6625 views
Fuel Filler Neck- what is that thing on the side called?
- 18 replies
- 13769 views
Camshaft plug sealing connundrum- can I get away with a single bolt?
- 3 replies
- 1153 views
External HG leak on EJ22?
- 8 replies
- 1020 views
Which type/brand ATF for 98 Legacy?
- 4 replies
- 523 views
EJ 22 timing belt kit differences
- 7 replies
- 969 views
'98 OBW stalling/ cutting out/flat spot
- 2 replies
- 642 views
