Loyale 2.7 Turbo
    239
Everything posted by Loyale 2.7 Turbo
  1. Also, you might want to do a Click on my Signature Below, it will take you to my Subaru "BumbleBeast" build Thread you'll find many Downloadable Files' Links at the top of page five; the earlier pages has Links to all my Writeups. Kind Regards.
  2. That is a Lot of Spark going on... You might try the Dodge Neon Coil Swap, Some people believes it is an "Upgrade" as you can read here: ~► http://legacygt.com/forums/showthread.php/eclipse-msd-coil-swap-149822.html Lots of Photos here: ~► http://legacygt.com/forums/showthread.php/msd-coil-into-subaru-step-step-photos-152338.html Kind Regards.
  3. Which Brands, and oil's SAE Number? I Run my "BumbleBeast" with 20W~50 since New... With Purolator 10028 Oil Filter. Kind Regards.
  4. You might ask to the AUSubaru forum Members, since they're in Australia, maybe one of them could receive your money, buy that cover for you and send it to you... Try: http://www.ausubaru.com/forum/ Kind Regards.
  5. Welcome! Share photos of your Subie, we Love photos here Kind Regards.
  6. For those who has never seen a Subaru Sambar "in Person" Let me show you this photos for comparison purposses: (Those photos aren't mine, but I signed them because they're hosted at my Photobucket albums, and I had bandwidth issues in the Past...) Kind Regards.
  7. You're Welcome! I added that photo to my Writeup as well. Kind Regards.
  8. I noticed that you were another person right after I posted that You're Welcome. That should be the Easier way to go... But where will be the Fun then? Kind Regards.
  9. You're Welcome! Don't forget to let us know if you solve the issue. Kind Regards.
  10. I'm glad to know that you got it Runnin' Again. Kind Regards.
  11. 2014? ... the title says 2013. Well, take a look here... ~► http://forums.nasioc.com/forums/showthread.php?t=2583921 ...and the third post here... ~► http://www.dirtyimpreza.com/forums/showthread.php?30675-2014-Impreza-Suspension-Lift ... Also here is a Writeup about how to install the Lift Kit: ~► http://www.subaruforester.org/vbulletin/f153/how-install-subtle-solutions-1-lift-kit-107084/ This one: ~► http://www.subtle-solutions.com/index.php?cPath=21_23_36_88 Kind Regards.
  12. Appreciated Nico, While it was really Sad to see your Awesome Subie with that hit, it is really Awesome to see how you managed to use the situation to improve your Subie even more... which seemed impossible. By the way, I mentioned long time ago, in another thread, the H4 Headlamps with Plastic housing / front Glass, which was widely used in the LADM (Latin American Domestic Market) Specs subies, starting in year 1990. I only know about another USMB Member who obtained similar ones from Germany. Also, the Yellow Halogens with Self moving Covers are Really Awesome!!! ... ... and it is something really New for me, which explains the rare Switch I Found long time ago in an Early EA82 Turbo at a Local Junk Yard, this one: . . I Bet it is the one which activates those covers, because it features identical symbol than the Older Subarus with the "Third Eye" in the middle grille; I mean this Switches: . . Would you like to share photos and info of those Subaru Halogens with Automatic Covers, on the thread about Rare optional parts on Subarus? Thank you for sharing those beautiful photos and the repairs of your fantastic subie. Kind Regards. Underlined words are web links ☺
  13. I bet you'll find Useful info on the Subject, here: ~► http://www.ultimatesubaru.org/forum/topic/118004-the-unofficial-how-to-lift-your-impreza-thread/ Kind Regards.
  14. Awesome! You can share photos here: ~► http://www.ultimatesubaru.org/forum/topic/90572-the-one-behind-the-wheel-pics-of-us/ Looks light Green to me. Nice EA71 Sedan. Kind Regards.
  15. I took a Photo of the Metal Base, on the Air Filter Box of my "BumbleBeast" to show you better where goes the two openings, which are intended for: ► The one on the Left was added by me, welding with brass a 3/8" nipple; ....that opening is the pressure Relief, which goes to a "T" to the Driver's side Hose. ► The one on the Right, is the 5/8" opening, which goes to an Elbow, ....then directly to the Passenger's side Hose, to deliver Fresh, filtered Air.
  16. You're Welcome. Well, I am not sure, because I can not see your car "in Person" and I'm trying to imagine if there is a difference in the Wiring between the Manual & the Automatic, for the Engine Management... as I've seen very Few Automatic Loyales here, and all of those came from USA like the one you can see here: (Scroll Down) ~► http://www.ultimatesubaru.org/forum/topic/87725-an-open-request-to-loyale-27-turbo/page-5 So I don't have experience with Automatic Loyales. I kindly suggest you to check the Wirings and be Sure if there are not mismatched ones plugged, nor a safety switch that might need to be bypassed. Kind Regards.
  17. Yes... ...try to Clean the Clogged nozzle first. Kind Regards.
  18. Mass Air Flow Sensor. I bet that the different wiring between Automatic & Manual cars, has something to do with your "No Spark" issue, in example, Automatics usually have a Sensor for the Position of the Shifter, so if it is not in Park (Nor in Neutral in some Cars), it will not let it Start... maybe there is a missing "Sensor" or unplugged Wiring, and some Loyales has the same Plug with the Same Colour and same Quantity of Wires, that could be cross-plugged each other in the wrong way... Kind Regards.
  19. OK If the Motor came from a Different Year / Model of Loyale, Maybe you forgot to swap the ECU and Wire Harness along it? You're Welcome. Kind Regards.
  20. Yes... However, an electrical False Contact on the Fusible Links, could cause same problem also. Here is said Writeup, with Photos: ~► http://www.ultimatesubaru.org/forum/topic/129601-how-to-easily-test-an-ignition-module/ It is about Carbureted EA82's Distributor; but maybe it could be Helpful. Kind Regards.
  21. The confusion must be due to the angle of the Photo... Let me know if you want a photo with the element on its place. Kind Regards.
  22. Hi! You mean This one: ~► http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ Thank you for your Kind Words. Nope! the Elbow is Not under the Filter Element, it is next to it, on the inner side: Kind Regards.
  23. Sounds Good! Please, share photos of that Subaru, As long as you Can... We Love Photos here. Kind Regards.
