Loyale 2.7 Turbo
    239
Everything posted by Loyale 2.7 Turbo
  1. No, I did Not painted anything on the instrument Cluster and your eyes are not fooling you. My "BumbleBeast" is an "Early Edition" 1985 Model, and thus explain the reason why it has Amber tinted instrument Cluster + Dashboard buttons from factory, instead of the factory Green everything, found on Later models. Here you can see a Comparison between the Newer and the Older instrument clusters on the same car, that is Not my photo, I found it online, and in it, both instrument clusters are lit with regular incandescent Bulbs: On previous page, post Nº 65 of this thread, you can see Photos and even a Video of how it looks the original Amber instrument cluster of my "BumbleBeast" after I changed all its incandescent bulbs, with white, multi tip Leds: Kind Regards.
  2. So, I decided to change the Whole set of Coolant Hoses on my Subaru "BumbleBeast" and I found that the water inlet pipe, known as the thermostat housing, was covered with some kind of scales plaque, and when I tried to clean it, a chunk of metal broke off from it. This is not the first time I dealt with a broken inlet pipe, I managed to get made a brand new one for my '69 coupé, long years ago; that was made of Brass. So this time, I decided to get another one "Made in Honduras" but this time done in thick aluminium; So this is the Results: I made this Photo Collage, just for Fun: The original material from those Thermostat Housings, is known as "Pot Metal" The upper threads aren't needed on my Subie, so the new aluminium inlet pipe looks cleaner; also I don't use thermostat on that engine, since late 1985, it isn't really needed in the Caribbean climates... The full story is Here: ~► http://www.ultimatesubaru.org/forum/topic/99881-what-have-you-done-to-your-soobie-lately-please-post-in-here-and-keep-it-going/?p=1275128 Kind Regards.
  3. From October 1984 to October 2014, a great Journey for such an Awesome Sedan. Have you solved the Spark Problem? Kind Regards.
  4. Oh, yes... I was lost in translation, once again... sorry. [/mistake]
  5. Those Black 15" rims are nice looking! and seems to have the Proper offset for the Loyale. May I ask you an Update about the Honda Fit Rear Wiper? I'll Like to know how it performs on the SafariWagon. Kind Regards.
  6. I'm Glad to know that your Subie is runnin' Great. Yes, the Weber Swap is Awesome! You're Welcome! Kind Regards.
  7. I agree that the Writeup is not so Descriptive; the Reason is because it is written / intended for people with previous Mechanical Experience and Knowledge on Carburetors, they'll understand easily the ideas. So if you are newbies in the Carburetor escenario, it is better idea to take your Carburetor to a Professional mechanic, or someone who has more experience with carburetors, otherwise it could be Dangerous to play with it, for your safety and health. Remember: Carburetion is somehow an Art, while Fuel injection is a science, to play with a carburetor is like playing with Fire and Gasoline, so please do not misunderstand me, I'm not disrespectful nor rude, I'm only concerned for your safety. Kind Regards.
  8. That is Awesome! Thank you for Sharing. Ha Ha! ... He in that Photo is placed Perfectly for a comic-style a Bubble Dialog... ...now to find a Caption... Kind Regards.
  9. Yes, I knew it. Which adapter plate you chose, from the two options pictured on the Writeup? Kind Regards.
  10. Many thanks to you, I really appreciate your Kind offer. However, since I lost my Job after fourteen years working there, I am in "Low Budget" Mode, 'till I could find another Job; now I'm only purchasing the mere necessary things. Kind Regards.
  11. Yes, it is Not Exactly identical to the EA82... ...but what I meant, is that the four Stud bolts are placed at the same distance and position than the EA82, plus that water jacket should be removed / Closed, also like the EA82; so since I have not worked much on Subaru Justy J12 carburated... in Honduras the Carburated is J10, and J12 was an EFi optional... ...you might want to try the EA82 adapter plate first, before removing that water jacket and closing the water passage, But what I don't know is if the Taller "Trans-Dapt" single plate adaptor I found, will allow enough room to use the Weber Carb with its standard Air Filter, which comes in two different tallness measurements. If the Weber carb fits with the Tall or the short Air Filters and the hood closes without hitting it, then, you can proceed... if not, you might want to try if the Snorkel / EFi cone style, "Remote air filter adapter" for Weber carburetors... ...allows enough Room; otherwise you should chose the Redline two-Plate adapter, which is much shorter than the Trans-Dapt one. Kind Regards.
  12. All your Answers, with Photos, are Here: ~► http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ Despite that the Writeup is intended for the EA82 and could be applied to the EA81, The Subaru Justy Three cyl engine with Carburator, Shares the same base mount for it, from the EA82. Kind Regards
  13. Yes, You're Right about the 4Runner Struts. Please, let us know the Results. Kind Regards.
  14. Yes. Yes, but I don't know if the mounting perch on the XT6 Body is equal to the Loyale Body, since my experience with XT6 is mainly limited to their ER27 Motors...
  15. In example, take a look at this Post, here: ~► http://www.ultimatesubaru.org/forum/topic/50983-strange-and-weird-subaru-stuff/page-25?do=findComment&comment=938387 Kind Regards.
  16. No need to be Sorry... No Problem. There are many cars outside the USA that looks alike the Subaru Brat, and since they're not common for you, is understandable how easy could those be confused with a Brat, especially if the stream movie's quality is low. Kind Regards.
  17. You're Welcome! Please let us Know what route you'll choose... and the Results. Kind Regards.
  18. Since my internet connection is extremely Slow and unstable to let me see stream videos, instead I had to Download the whole movie in .mp4 format, 720p resolution, with the idea of making screen captions of the Subarus I could find ... to download that took me the whole afternoon for 168 Mb to see 13 minutes... wasted of my Life, because, as Bantum wrote: There is Not a single Subaru in the whole movie. Kind Regards.
  19. Of Course you're Wrong! "How to Keep your Subaru Alive!" covers almost Everything on EA71, EA81 and (Because it is the Second Edition) EA82. Download & Read it it Before commenting. Kind Regards.
