Everything posted by Loyale 2.7 Turbo
The "Zombie Outbreak Response Vehicle"! As Seen here, in ~► this Thread. and ~► Here.
More info taken from the " Strange & Weird Subaru Stuff Thread" The Subaru Flat 12 "1235" Engine went onto Another car:
Taken from the " Strange & Weird Subaru Stuff" thread, these are Old-School Subarus too:
Subaru XV for 2013
Loyale 2.7 Turbo replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes! I Had the Same Idea and I Posted that on the "Strange & Weird Subaru Stuff" Thread ... ... and the Answer was: So, Diesel Boxer Engine Swap, anyone? Kind Regards.
Gave it to her!
That is a Pretty Subaru, and will be Better with the Weber and Power windows... etc, that you Plan. But Also sounds like a Fun Project Car for you. My Wife somehow Preffer to Drive my Lifted 5MT BumbleBeast instead her Automatic Kia Sephia, she says that she prefers taller Cars... but I don't let her drive it too often. Kind Regards.
Weber carb for my 87 gl?
Without a Light Gun? ... I Believe Not... or it should be a Non-Easy thing to do. I Kindly Suggest you to Move the Disty a Little more to the Right to Advance it and go Test Drive the Subie, then a Little More and do another Test and So on; Moving it Right or Left untill you find the Better place for it. Good Luck!
Thank you for your Kind Answer. The Choke Still Hits there? ... I didn't knew it 'cos I removed all the Choke Stuff from my Weber and Sent it to another USMB Friend, in Australia. We Don't Need much the Choke here in the Warm Caribbean. That Means that Something is Wrong with the Timing... Running my EA82 with a Weber, made me to Swap the Two Port Vacuum Advance with a Single Port one, but not all EA82's Distribuitors are Equal... Mine uses two Clamps to hold the Cap. Pics & Part Numbers of that are on my Weber Writeup, Click on my Avatar. I Discovered that my Weberized EA82 BumbleBeast works Better with the ignition Timing in 20º Degrees ... Even if the Sticker under the Hood says that the "Normal" Timing should be Placed at 8º and could vary + or - 2º Could you Determine How much Advanced / Retarded is your engine's ignition Timing Right Now? ... I'm Almost Sure that it needs to be Advanced a Little More. Kanurys explained a Simple Procedure to do it by the Test Mode (Without a Light Gun) and that simple procedure could Work Fine, I used to do that also. Good Luck! Kind Regards.
89 loyal all wheeldrive turbo wagen
Thanks for Share... Looks like a Fun Project. Why the Previous Owner left it unfinished? The EJ engine has already its ECU Wired? Kind Regards.
Does your EA82's Disty still have the two port Vacuum Advance? There are Two Vacuum Ports in front of the Weber Carb... The one on the Right is for the Disttribuitor's Vacuum Advance. The one on the Left is for the EGR Vacuum Valve. There is a Question that I Asked and Remains unanswered, Just Curious: And I Drive my Weberized BumbleBeast between the Sea Level and up to 4,000 Feet over the Sea Level in my extremely mountainous country without any Problems. I've only noticed that it doesn't Like the Regular Gasoline, really my BumbleBeast works better with Higher Octanes. Kind Regards.
Subaru XV for 2013
Loyale 2.7 Turbo replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe Have very Few Subaru Diesels here, in Latin America. I Saw once one of those Brand New in its Crate, For Sale: Kind Regards.
I Have a Complete Explanation on my "Public Profile" just do a Click on my Avatar and Scroll Down to find it. _______________________________________________________ Now My BumbleBeast is Prepared to do the Undercoating... Pics Soon. Kind Regards.
Your Subie Weber Setup Looks almost Equal to Mine's... Did you Use the TransDapt Adaper? I Run mine at 140 on Low and 162 on High without Any Issues... Maybe yours only needs some Adjustment to the Idle Mixture. Kind Regards.
And This Shortened Subaru Loyale from Germany!
I Like the Lifted Subaru Justy with Tracks:
Thermoswitch temp
A 1983 model and 1.8L, its engine is a EA81, those use a Single Spade connector, because the Thermoswith takes the Ground from the Rad, which is Metallic. You can Use a Twin Spade there, by Grounding one of its Wires, usually the Black one; but you must be Sure to use the Proper Temperature Range. Kind Regards.
Dude!
http://www.powdersurfing.net/radical-rigs-beaches-mountain/2011/5/17/off-road-subaru-zombie-outbreak-response-vehicle.html Nice Idea "Zombie Outbreak Response Vehicle" I Found it on the Link Above. Also, the Impreza lineup has a "Official Zombie Scape Vehicle" Kind Regards.
1993 Loyale with ONLY 9k miles!!
Well... I've never had problem with Mine, which are Amber. Nice Subaru, Looks Like New, and yes, the Rubbers and Hoses would need to be Replaced, despite their Mileage, That includes somehow the Timing Belts; Because they become Dry with Age and could Fail. Kind Regards.
Patching rusted out panel
Click on my Avatar and You'll Reach a Link to a Complete Writeup, Plenty of Pictures, on the Subject. http://www.ultimatesubaru.org/forum/member.php?tab=visitor_messaging&u=17344&page=2#visitor_messaging Kind Regards.
An Old Sambar Bus in a Very Old Photo of my Subie: Note the Five Lugs 13" Rims!
...even More from my Li'l Country: Subies Crossing in a Corner at Capital City: Subaru Sambar 4WD on Saint Lucia's Mountain Village. Nice Sambar Mini-Truck Outside a Chinese Restaurant:
More Honduran Subies on the Street:
Well, I Agree... ...No Problem! _______________________ Here is Another Honduran Nice Subaru: I Took this Picture with my Cellphone, The Subaru Loyale Wagon was Parked at the Shoppin' Mall's Supermarket; it Sits on 17" Tires... ...That Subaru Belongs to Andres... here is his "CarDomain" Web Link: http://www.cardomain.com/ride/3867148/1985-subaru-dl More Pictures: I'll Try to Contact him and invite here to Join us... Kind Regards.
Simplifying the EA82 Hitachi hose nightmare
Well... I Agree as the BEST Way to do it, not exactly the ONLY way. Kind Regards.
From the edge of the world
Nice Pictures! / ¡Bonitas Fotos! We Have Many of those Sambars (E10 and E12) and Justys (J10 and J12) here, They're very Nice. / Tenemos muchos de esos Sambars (E10 y E12) y Justys (J10 y J12) aquí, Son muy Bonitos. I'll Share a Pair of Pictures: / Compartiré un par de Fotos: I Took this Picture of a 4WD Sambar on the "Saint Lucia" Mountain Village, in my Country. / Esta Foto de un Sambar 4WD la tomé en la villa de Montaña: Santa Lucía, en mi País. And I Took this Photo at one of the Capital Citie's Street Corners. / Y tomé esta Foto en una esquina de la Ciudad Capital. Kind Regards. / Saludos Amables.
Sunday morning 4/15/2012 Cafeine and Carburetors New Canaan CT Bugati Veyron to VW's
I'll Like to See Pictures, if you can shoot Some and Post 'em here... Specially of Subarus. I'll Love to Go but I'm So Far Away... Kind Regards.
