239
Everything posted by Loyale 2.7 Turbo
"Backyard"/substitute tool thread
Loyale 2.7 Turbo replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well... I don`t know exactly the correct english Translation, but I use a Pair of Large "Non-Ended" Screws (we call `em here "Esparragos" -asparagus-) of 5/8" diameter and around 24" tall, with a nut in each extreme, that holds a 1" X 2" piece of Metal, angled in 90º, to compress (in a Hurry) a suspension Coil Spring. The metod is Simple: first put one of those large Screws in one Side (Left), the other on the oppossed 180º Side (Right), then start turnin` the nut down, around two turns each side at time, and securin` the spring coil with Metallic Wires & Knots... I know it is Rudimentary, and some sort of Risky; but properly Secured it Works Fine, specially in a Hurry at a Junk Yard... or at Home! -
learning more about Soobs/cars
Loyale 2.7 Turbo replied to RdNkBrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is a "Must" for a Subaru Owner! ... (HTKYSA) is a Nice Book. -
More Datsun Similarities
Loyale 2.7 Turbo replied to Durania's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subaru and Nissan did some Projects together, long time Ago... even the Key of a EA82 Subie is the Same of some 80`s Nissan`s. Also, subaru did sell a Nissan -diesel- as the "Subaru Leoné II" in some Markets, as Greece... Look a this Thread for mo` Info: http://www.ultimatesubaru.org/forum/showthread.php?t=53434&page=9 -
Thanx!
I Like it!
bigger/ more injectors ????
Loyale 2.7 Turbo replied to spokanesoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, Trully... If you Just get Bigger Injectors, and No More Air, the only thing that Will Increase, is Fuel Consuption... -
The Subaru Flat Twelve is from around 1990 (So Basically maybe it is a "Evolution" of the EA82, as is the ER27) it was for the Subaru´s Formula 1 Racin´ car... but That´s another Story. In other old Thread, I suggested to install that Flat Twelve in the Back Side of a Loyale Wagon, as Rear Engined... Crazy but can be Done... Theorically...
Weber Rebuilding
Loyale 2.7 Turbo replied to bigjim5551212's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you Offer New Air Filter Elements for Webers? -
Just a li´l Question: What´s the Meanin´ of "Bob" a Car?
We got here the Long Bed Model Too... Me Too!
86 subie, ecu light
Loyale 2.7 Turbo replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/...ad.php?t=49918 Ignition Pulse System... I´m not Sure... it´s Somethin´ about the Crank Angle Sensor. Look Here too: http://www.obd-codes.com/trouble_codes/subaru/1983-1988-subaru-carbureted.php -
ignition pulse system 86 subie
http://www.ultimatesubaru.org/forum/showthread.php?t=49918 Ignition Pulse System... I´m not Sure... it´s Somethin´ about the Crank Angle Sensor. Look Here too: http://www.obd-codes.com/trouble_codes/subaru/1983-1988-subaru-carbureted.php -
I just wanna say for Information, that Imprezas came here to my Country in late 1991, and Legacies came in mid 1989, as I remember... Also if you Check the Subaru History at their website, there`s a page when say that our "Loyale" shaped model, came out in 1981 as the new "Leoné" ... http://www.subaru-global.com/history.htm l
Me Too!
Yes! ... Search `bout. I just wanna Add that (I Think) the worst of the EA82 is the Timin` Belts. The Better is that is more easier to Upgrade. But with much effort (and Money), a huge upgrade can be done to the EA81`s, Look at this, a 200Hp EA81: So, Both are very Good Engines.
Problems with Acceleration / No Power, seems to be the Secondary Stage of the Hitachi Carb. ... Maybe the Vacuum is improperly hooked to the Wrong point... but you can test if the Cable is Wrong, by Disconnectin` it and try to "Manually" accelerate... if it Returns to normal Idle, its the Cable. But if not, is a Carb Issue, I Suggest to try with the Secondary... But Even Better Solution is to Swap a Weber instead... I done that to my White Wagon, and it Never did perform better than with the Weber, and we got it since new in 1985... Good Luck!
