Everything posted by Crawlerdan
Documented: The 1970 FF-1 Project car...
i have no idea, they are in 73 coupes in a wrecking yard in idaho
i have access to a few 1400s around here, will that help?
that is sexy!!
Lady looking for engine
Crawlerdan replied to !NGr!d1998's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhi jen- i spoke with you a few weeks ago about your car- i have a motor here with only 99k on it-cheaper then what youve been finding. your welcome to call me again-493-0901
so how many subaru's have u owned? lets see some pics
yesterday i scraped #92, an 88 xt6 and last sunday i bought #93, A 99 LEGACY WAGON i would say ive had40 or so gl/loyal/dl 40 or so first gen legacies half a dozen second and third gen legacies, 3 brats, and two xt/xt6 cars three rx, one was a sedan i love me some subaru....s
hybrid axle help- asap!!
i left the xt6 seal in, no complaints yet, i wrote down your timkin number for future referance if needed, as for now, its done and driving well
moved
hahaha, you said what the whole forum was thinking i personally would think its the most badass rig ever with all the parts you have- and two feet lower:)
Freshly Stanced BRAT !!!
+if ea82 parts will work, i have some
Is this possiable or did i do the math wrong..
my old lexus averaged 26- driving calmly behing a u haul for 400 miles it did 32 my lifted 4runner does 18 ave, did 24.5 behind large u haul for 800 miles....i move alot
Help! Roll pin stuck ( and my punch, too)
it should slide out, gentle bfh persuasion sometimes needed, dont whack your wheel studs, protect them with the lug nuts
New subie!
im here....well, montanas a huge sate, but im here want some xt6 parts?
i bought a car that someone did this too, and the solution was exactly what you said- i pulle d the trans, sooooooooooo much easier on a bench
so- i installed impreza axles, they are too long- so i lengthened the control arms 1 inch worked perfect used full xt6 spindles, control arms, sways impreza axles, 99 outback struts with xt6 springs and top hats xt6 rear brakes, plates, hubs someone less drunk then i needs to do a how too for other members the end result was a 1.25 lift in front, sits level now
ive read all the posts- there are vauge answeres. i purchased 93 fwd 5spd imp axles, 23 trans side, ej outers, they fit well but are too long it seems again- ive read this before, but theer are no solutions posted
ya- question is-the doj from the ea does not fit the xt6 axle- what is the solution
ya, tried the pipe trick= no go
im doing a 5 lug swap, 88 gl d/r 23 spline at tranny i have xt6 axles the ea82 inner cups do not fit, the xt6 axles are larger inside sooo...do i put the xt6 outer onto the ea axle?? if so how the hell do i get them off? im a big guy and have wailed on the doner axle to no avail. help!!
My '96 Outback
Crawlerdan replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1300.um...crap....its going to be a few before i have that kinda dough- ill let you know, thanks
My '96 Outback
Crawlerdan replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you plan on not using the aussie ej d/r- i will buy it thanks
Subaru To Porsche engine swap
porche- expensive, garbage, hard to work on- subaru, cheap, well designed, and easy to work on you will see subaru engines in vws and porches, but never the other way around
Did any Subaru engines have gears instead of timing belts?
the ea81. and its predacessors
xt6 value???
i can purchase an xt6 pretty cheap, bad heads, was a driver prior to that what is teh 5speed with diff lock worth? the full 5 lug swap? any other parts worth anything? ill make this clear- i would only buy it to make money, if i cant make what i want- ill pass it on to the board members
bigger turbo on 86 gl10?
the legacy vf11 and even the wrx tdo4 are great upgrades, but in the end, adding power to that engine is going to make a bad situation worse. i agree with the above- an ej22 is an easier, more reliable, and more powerful upgrade
W series Toyota trans adaptors
Sorry,I'm behind
i discovered today that ej pilot pearings are the same as toyota 22r...if that helps
