The Beast I Drive
Everything posted by The Beast I Drive
  1. You can run 30" tires. The best combination for this would be a 5 speed dual range swap (5 speed has a lower low range), and a 6" lift kit, and lengthen the radius rods 1", then pound away at the inner fender and cut any unwanted fender interference . For the record, with a 6" lift 27" tires fit with no cutting. I find I have plenty enough power in my wagon with the EA81 and 31" tires, the only things that get me are long, steep hills. I can still go 70 on the freeway if I have to though -Bill
  2. I heard that they are illegal in the woods around hear, mine are pretty loud... Guess Ill just try my luck -Bill
  3. Someday I will have a orange GSR with RX AWD and a 1600 built with 1400 dual port heads, radical cam, and dual carbs. :cool: Ill also have the only 1973 Tailgate wagon with EA81 4wd drivetrain swapped in and completely restorerd body and interior I have big dreams -Bill
  4. I would put at least a 4 point cage in that bad boy just to be safe, other than that I like where this is going -Bill
  5. Looks like Ill be bringing my Brat if it cooperates, with either no lift or a 6" lift and 5 speed swap, depending on if I get any time to work on it or not. Just gotta check one thing though, Im sure all you West siders would know, how big of a fine will I get if a ranger cites me for having glasspack mufflers in the woods? -Bill
  6. I would say use 5 speed 23 spline stubs just to be safe, but I really dont know if the 4 speed stubs are the same or not. As for the rear diffs, yes your brat should have 3.9 ratio, so you would need to swap in the 3.7 diff to match the RX trans, otherwise bad stuff happens -Bill
  7. Awe, you can totally take on Open Class! just put a cage and some extra chassis supports in that beast so you can jump it higher and harder and get more points! -Bill
  8. Just whipped this up a half hour ago: That is the axle puller tool. Works like a charm! made this one with about 9 inches of 3/4" threaded rod, an axle nut, about 8" of 2" exhaust pipe, and a pair of 3/4" flat washers and nuts, then welded a handle on it so it wouldnt turn while I was turning the nut. Shazam! Thats all just crap I had layin around, I did have to do a little lathe turning, but nothing I couldnt have just as well done with a grinder (had to round the points on the axle nut to go into the pipe) -Bill
  9. If it is a Turbo with an RX 5 speed D/R with Diff lock then it should have 3.7 final ratio and 25 spline axles. You can swap the stubsout of the tranny with some 23 spline stubs and then it will work with your EA81 axles. All turbo EA82s with manual transmissions had 25 spline axles while it appears the turbos with automatics had 23 spline axles... About the only things of interest for you to swap to your brat would be the trans, rear disk breaks, and the LSD rear diff if it has one. The power steering can be adapted, but you will need a custom bracket. -Bill
  10. Ill try to get workin on it this week, tryin to finish up 5 6" lift kits and some other projects as well, but Ill get it fit in my schedule. -Bill
  11. You could do some home made beadlocks, I seen that alot on superstock and other drag race cars here, just make sure everything gets balanced when youre done. Are you running those 14" Desert Rat wheels? If you went to say a 15" wheel I think theres more available, since its a pretty popular size in most motorsports. -Bill
  12. Hey, I am always down in Sunnyside, do you live just off Ray road on E. Edison, just north of my uncle Allen George? -Bill
  13. I hope youre gonna paint the car black to go with the lime green wheels man, the Strawberry/Kiwi look is gonna be kinda weird -Bill
  14. Yeah Im aware of the tool I need, I think Im gonna whip one out on the Mill at work this week or something... I gotta get the right bearings first though :-\ -Bill
  15. Ok that does help a bit, the parts my guy gave me are not right. he gave me 4 bearings, but 2 of them are smaller than the others. Im gonna check out those pictures you have, they will help a lot. -Bill Edit: Upon further thinking and looking at those pics, it looks like he gave me 2wd wheel bearings, where the outer bearing is smaller than the inner. Is this possible? Also, there is supposed to be an outer and an inner seal right?
  16. Beadlocks man, if they'll let you run them on that course, Im assuming that is not a street vehicle at all, so it should be ok? That seems like about the only solution, unless you superglue the ************ out of the beads with the best superglue money can buy -Bill
  17. I searched, and found this http://ultimatesubaru.org/forum/showthread.php?t=79586&highlight=bearing+part+numbers Does anyone have the Federal Mogul part number for the Rear wheel bearings for EA82 and also for EA81 4wd vehicles? Im a little confused because my parts guy seems to have given me the wrong parts, and that really does not happen that often. Im lookin at an 85 DL rear subframe with the 2 bearings instead of the 1 like was mentioned, and any info that can help clear my confusion would help. Thanks! -Bill
  18. Hmm, I never thought much about it, I just got used to muscling the Beast around with no P/S, but Im sure I could whip something up, Ill just have to find a SPFI manifold, but Ill try to make something that works with the EA81 carb manifold, the ea82 carb manifold and the SPFI manifold. The real tricky part about the EA82 manifolds on the EA81 motors is the thermostat housing is right next to the disty, not leaving much room of any kind.... Ill see what I can do :cool: -Bill
  19. It just needs a custom bracket made to mount the steering pump on the EA81, but its kinda tricky cuz the best place for it is taken by the distributor. -Bill
  20. Now thats what Im talkin' bout! :mulletbang: -Bill
  21. The camber is off because he wanted a little bit extra lift on the front struts, so it has 4" lift blocks on the engine crossmember and 5" on the struts, which will create possitive camber. -Bill
  22. Not to be an rump roast, but perhaps you should look at every coil-sprung suspension system on any American made car from the 60's and newer sorry, I just feel mean today :-\ Brian, you plan on using these as the suspension or with the suspension? If you want to mount them in the front in place of the struts its really easy to make a plate to mount them to, but if you need some help figuring it out let me know and Id be glad to help -Bill
  23. Just for the sake of arguement towards GD, not all GLs came with power door locks. I have 3 GLs on my place that do not have power door locks, and one has manual steering. And they came from the factory that way. I do have a GL with power locks, and both the GL-10s I have had power locks. But my point is not all GLs had power locks or power steering. Those things were options. Oh and I like that wagon, EA82 wagons are my thing -Bill
  24. It was a great time, and nice to meet some of the other board members and here stories and eat food I enjoyed it -Bill
