Everything posted by ocei77
P 0032 Code on 2003 Legacy
ocei77 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXP0032:Upstream oxygen sensor heater circuit, high input O.
Pick and Pulls NE Large ?
ocei77 replied to pmichaud's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGary's U pull it in Binghamton, there's another similar yard near them. Call for availability. O.
R12A Refrigerant
do a google local prices I've seen are only for 134A. Believe R12a is illegal in US and no longer available O.
Easy to "check" to see if the timing belt was replaced?
ocei77 replied to JayCog44's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWay too much in my neck of the woods. Check craigslist for going prices in your area. Here( hudson valley, ny), price would be no more than 5K, if that. for instance http://hudsonvalley.craigslist.org/cto/2418630603.html and that's an 06 O.
band adjustment
ocei77 replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFollow link for manual, should have procedures http://www.main.experiencetherave.com/subaru_manual_scans/ O.
In The Middle Of A T Belt Change
ocei77 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWorks for me also, tho I don't do it all the time. Had an 8" screwdriver break on me once and you can't imagine the horror I felt as I heard the small piece fall in between the flex plate and flywheel. Wound up using the old style jack handle after that! Works every time, off and on. O.
Overheating?
ocei77 replied to MATTinTHEhat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat issues did the previous owner tell you the car had? Mileage? Were head gaskets replaced? If so when? Is the lower radiator hose hot? O.
2006 Forester Timing Belt Replacement
ocei77 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=51554&page=2 There is an access cover. Its hidden under the throttle body. Use a needle nose to grab it. If you turn the crank (22mm) with a flashlight you'll see the slot in the flex housing. If you don't have a 2nd person to hold the brakes, do it this way. Make sure it is a sturdy screwdriver. One popped on me and you can't imagine the horror I felt as the broken piece fell down! Put that off til later and on turning the crank the glorious sound of falling metal greeted my ears. Went under with my magnetic pickup tool and was able to fish it out. Used a lug wrench after that. I take the radiator out, as the screwdrivers I have always hit it as I try to lever the lower sprocket into place. Do search proper "burp" procedure if you remove the radiator. for future ref. http://www.main.experiencetherave.com/subaru_manual_scans/ Have fun O.
Overheating at Idle
ocei77 replied to tillothehun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like air in the system or a failing pump. System properly "burped" when coolant ran low? When was the pump last replaced? When a pump starts to fail, it may not go all at once. The temp will rise when engine is at a certain rpm then come down. Varies as to how long this will happen before it completely fails. O.
Head gasket on the Legacy Again!
ocei77 replied to papalobster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have the place to do it, by all means pull the motor. The dealer sells the HG as each, so you need 2. You don't have to replace the head bolts though. If you decide to do it in car, give yourself an extra 2 hours.The passenger side is easy, but the driver's side is a REAL PITA to get back in.Frustrating to say the least. 5 of the bolts have to be in the block when reattaching.The upper left could be inserted after catching the other threads. I used paper towels to keep the bolts from sliding all the way in, so I could manuever better. But you can use rubber bands or similar. Don't hang the gasket until after you have the head basically in place, or you'll mess it up in the twenty attempts to line everything up. To remove my egr pipe, I had to first remove the egr unit, to give me that 1/2 inch of movement I needed to use my 17mm flare. I wouldn't have done it in car, but after the first time and having to do it again ( a long story for another time) I chose to do it in car. O.
97 legacy brake lines rear
ocei77 replied to jim milewski's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is link to parts etc. You can backup to home page to keep for future ref. I used a 2.2/ auto as base, tho I don't think it will make a difference. http://opposedforces.com/parts/legacy/us_b11/type_6/brake_system/brake_piping/ for future ref http://www.main.experiencetherave.com/subaru_manual_scans/ have fun. O.
Duty C Solenoid.... stuck
ocei77 replied to goms187's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpecs say 21.7+/- 3.6 ft lbs. So lets say 22 O.
oil pumpseal replacement
ocei77 replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOpposeed forces does not list a gasket as a part of the oil pump assembly. I used the red amaerobic when I did my ej253. Goes on in a small bead and does not harden in the air. Expemsive but so much easier to use. O.
ocei77 replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo quote "aye there's the rub". Getting it started. Changed T belt and pulleys etc while doing a HG job on my BD and wanted to check oil pump screws and change O ring. Can't get the sprocket off yet. the holes are not threaded on mine and after the first ping of a broken screw driver tip and the horror that came over me looking for cracks in the oil pump, I have given up on that idea. So, it was reassembled w/o changing. I've PB'd it and am waiting to see how the OP gets his off. Maybe that'll help my situation. O.
1995 Subaru Legacy wants to over heat - WHY?
ocei77 replied to jboymechanic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf burped properly and still doing this, it sounds like your water pump is on its way out. When was it last changed? O.
97 Legacy Brighton with broken timing belt
ocei77 replied to mulefoot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn an effort to put this to bed. ie 97 ej engines, I wrote to the source. SOA. asking them for production date of when they went to interference style and for any and all distinguishing features. When I get an answer I will post. O.
ocei77 replied to mulefoot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^Well sir your knowledge, as most of ours has a few gaps. If you will check phase 1 and phase 2 info, you will find that about 03/97 Subaru went to the interference style. Although GD and others have disagreed with ability to see by external differences such as valve cover design. When they went to phase 2, they changed the spark plug location to go through the valve covers and no longer had HLA lifters. I have a 97L and it does not have the interference design. O.
2007 Impreza brakes
ocei77 replied to steelers1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHawk HPS or similar They have good initial bite, great resistance to fading, but they do dust a little more than stock. Upgrade your brake fluid while at it. Motul, Super blue or similar. O.
crank pully , 98 forester, question
ocei77 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tensioner has to be compressed in a vertical position, to make it easy to understand. I used a c clamp,and just hung it from a wire in between turns as I did other things. There is a small hole that goes through the tensioner. Find an allen key or nail that will go completely through it. Once compressed put the tool in and do not remove until after the belt is reinstalled properly. O.
SOHC EJ25 Valve adjustment
ocei77 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuestion. Don't the pistons have to be in a particular location when doing the adjust? O.
Best Souce For OEM SVC Manual
ocei77 replied to Hoshwa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this link http://people.csail.mit.edu/ilh/vacation/ Have fun O.
Hydralic lash Adj.
ocei77 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse link for FSM for your model year. You will find all info you need there. http://www.main.experiencetherave.com/subaru_manual_scans/ O.
Another Brake Problem
ocei77 replied to Dontoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFluid level too low? Air has gotten into system. Lastly possible rotors worn too thin. O.
Part # request
ocei77 replied to ernestedward's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor future ref on part #'s also check out http://www.opposedforces.com O.
A few problems with 04 outback.
ocei77 replied to Jack Foulard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThink you have to have at least 10 ten posts before the system will allow you to add attachments. O.
