Everything posted by beataru
Yeah but remember this is an EA82T not an EJ STI block... those things have ribbed cylinder walls and forged internals! this thing does not... so im planning on setting the boost and leaving it! $200 for my car... thats like 1/4 of what its worth!
hehehe... i found out how to make a manual boost controller... any of you guys know of ppl using one of these??? http://www.geocities.com/chmwatson/FAQs/mbc.html and their success??? I my car is intercooled and i hope to be pushing it up to at least 10lbs ive heard of people doing up to 16 lbs... thats crazy although the gl-10 has a 7.7 comp ratio THATS SO LOW i could probably sleep in that combustion chamber at TDC
yeah but how long do you take to pour in a million little things... well..... how many are there? and how big are they??? i can if they were the size of powder but... i dont know....
JB weld or propoxy... sorry i make run-on sentances!
idle problem , 88 turbo a/t full time4wd
beataru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1800 is at cold idle.... it makes sense but i thought its supposed to be at around 800 rpm warm??? -
JB weld or propoxy it babey... no torchy though.... hehe (sounds like something stupid i would do! BOOM!)
1987 GL Turbowagon 4 WD Switch
beataru replied to Dog1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hehe... bring it up to redline and N-Bomb it and then come back and look at the tiremarks!!!! well... you might loose your tranny! -
I fixed my car with vacuum cleaner parts!!!
beataru replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice job man... i gotta remember to add a vacuum to my on the road emergency kit... which consits of: teflon tape, oil, adjustable wrench; nedle nose pliars, water, ductape, and of course.... a big rump roast hammer -
850 to 6500 wow thats a powerband!
That stuff looks cool.... but it seems like a pain to take off the tire... put the crap in it... and then hope you have just the right ammount so you dont have to do it again... i like stickEm weights its quick and easy to spin a wheel and then "Stickem" on!
Wait.... my car is having problems idleing too... so could the sensor be bad on my rig as well? it idles at around 1100 after its warm but when i fire it up it goes to as much as 1800 -
Just a suggestion... and question.... You should be running premium... if your knock sensor is doing its job its probbably sensing knock and retarding the timing to compensate... but then again.. youve had the car like this for a while right with no problems so... hmmmm -
Your sure that your coolant system is pressurizing right??? if its not.. those bubbles that your hearing are boiling water.... its not supposed to do that unless its not pressurized! Just wanted to throw that in...
did you disconnect your bat for about 20 mins and then reconnect it and this still comes up immidiatly?? it should take about 3-5 mins for the ECU to figure everything out again... like a goldfish hehe:banana:
Front diff interchangeability: The true answer
beataru replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I wana do both!!! But the rears easiest for me to get-to!.... Or im just 2 lazy to go to the front!!! and if i did do an only front lsd it would understeer more than a fwd car does anyway!!! are you guys using this for street or for off-road! -
mwahahahahaha! It's Alive!!!
beataru replied to Mr. Carb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Give us an update on what it can dooooooo!!!!! -
i wana put a lsd in my gl-10... not that it would do much since its not in 4wd all of the time..... but hey... why not!!! -
Go for it man... And make sure you let that exhaust scream like one pissed of machine!!!! subies sound so good!!!
Hill Climb Overheating?
beataru replied to Subaru Jim Maple Ridge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or in my case 13 lbs compared to 0 lbs hehehe... im gonna fix it this weekend i hope.. gotta get out the torch.. good thing me pops a plumber... comes in handy ya know! -
Southwest Subaru meet 2/15/07 MLK jr weekend
beataru replied to s'ko's topic in Meet n' Greet. Your USMB Welcome Center
Hmmmm that sounds interesting... i hope that i still have money then..... oh well.... ill keep checking up on this as it gets closer to see how many people are really really goin!!! -
Hey check your rad cap.... makesure its able to pressurize the system... or a pinhole leak!!! my rad is leaking from the right tank!!! -
Gl-10 EA 82 Timing question
beataru replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I JUST DID IT MYSELF AND AFTER ABOUT 1 HR OF TINKERING!!! IT FIRED IT FIRED IT FIRED.on all fours!... i am now considering my self...."master of the blueroo!" -
So I wrecked my wagon.....again
beataru replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I totaly agree!!! Cars were built to be driven... wether it degrades there value or not!!!!!
